So here is what I would suggest for a RS level upgrade.
ECU: APR Ultra Charger STg2 dual pulley.
TCU: HP tuners/BG SQ5 ZF8 tune (shifting @ 7200 @ WOT). Make Drive more exciting(less boring) but not over the top and set up Sport and Manual mode for maximum fun. Sport mode hanging revs between 2 and 3K before the upshift during normal throttle inputs and Manual mode set up with a 7400K redline and the auto downshift turned down for a truly manual experience. This is how my tune is set up and it's extremely fun drive.
Heat exchanger: Merc Racing or any of the other major Manufacturers out there if you want it to be shiny and silver.
Grill: E Bay RS with the Quatro bage on the lower portion
Exhaust: Gutted stock cats or test pipes with a AWE touring (hit up Mops) or even stock exhaust. Either one needs to exit in a pair of large oval tips centered in where the daul tips would go in a SQ5 rear valance. I can't remember if you own a SQ5 or a 3.0T Q5.
Suspension: Bilstien PSS10 coilover kit (hit up Mops).
Supporting suspension mods: 034 rear sway, 034 tranny inserts and 034 aluminum X-Brace Chassis reinforcement.
Brakes: Voshmods upgrade with Cadillac CTV (Brembo) and Gyrodisc rotors. Look up Ignition tubes build thread to get the skinny on these, it's the last video he just did. Paint the calipers the same anthracite gray that Audi uses on all its RS calipers and add a the RS/Audi Sport decal. The one in the attached picture is a full carbon ceramic but you don't need to spend that kinda money. You get your choice of paint color with the Vosh Mods set up and it's probably the best bang for the buck going in a BBK.
Rims: hang out on the RS classified pages and scope up a set of used OEM RS rims. Or find something else you love and get it 10 inch wide so you can run a 295 tire.
You already have APR STG 1 so you may as well stick to APR unless there is something about I.E or one of the others you have to have. But once the Cats are out of the way a APR Ultracharger STG 2 is going to give you just about all the power your going to get before you start running into having to blend Ethonal or run Meth injection.
Originally Posted by
a=m/s2
Ok. It’s a start. Practically speaking, a swap to the 4.0 is no dice. By the time I get there, I’m thinking I could pickup a used RS5 for near the same money with selling my car.
Stage 2 is going to take engine most of the way. What about breaks - Brembo Big? Coil overs - ok. Which? Cross car beam (CCB) - how do I spec it?
I am a 1 month newbie with little background knowledge.
Sent from my SHT-W09 using
Audizine mobile app
