Results 1 to 4 of 4
    Sep 07 2016
    New York
    Code P2188: Bank 1; System too Rich at Idle HPFP, N80, or PCV?
    Over the past year I've had about 5 intermittent occurrences of a hard start while all other starts were normal, on a B8 2013 Audi Allroad. When this happens, the engine will crank but not fire until after ~5-10 seconds. Once it fires it will run on a cylinder down for a second or two before running normally.
    This issue disappeared for a while but has recently resurfaced. On a recent day, after driving to a store, came back out and car would not fire. I put gas pedal to floor and cranked and it immediately fired. Check engine light came on and the following DTCs were pulled. Of other note: fuel mileage was noticed to have dropped 3 mpg/hwy recently as well. There are no issues at refueling (N80 purge issue), nor does the engine ever misfire, stall, or stutter. It is only a rare issue at initial start. I sense a hint of gas smell in oil but I'm unsure if it is excessive or not. Engine oil has always stayed at full level, but has dropped a quart (@8k miles) which was unusual.
    Any opinion whether these issues, and 4106 - Bank 1; System too Rich at Idle, P2188 00 [096], point more toward N80, or PCV, or HPFP as the culprit? Any thoughts are appreciated.
    Code:
    Sunday,07,June,2020,08:39:18:02305
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
    Data version: 20200331 DS317.0
    www.Ross-Tech.com
    VIN:    License Plate:
    Mileage: 98110km-60962mi   Repair Order:
    Chassis Type: FL-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
              6C 6D 72
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: Malfunction 0010
    Address 01: Engine (DET-CPMA)       Labels:. 06H-907-115-CDN.clb
       Part No SW: 8K5 907 115 F    HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H09 0008
       Revision: ECH09---
       Coding: 722A0013242600062000
       Shop #: WSC 54964 001 1048576
       ASAM Dataset: EV_ECM20TFS0118K5907115F 001009
       ROD: EV_ECM20TFS0118K5907115F.rod
       VCID: 3537DC2F05C1E6B3B0D-8060
    1 Fault Found:
              P2188 00 [232] - -
              MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 3
                        Mileage: 97906 km
                        Date: 2020.05.28
                        Time: 16:34:15
                        Engine speed: 827.00 /min
                        Normed load value: 23.5 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 96 °C
                        Intake air temperature: 21 °C
                        Ambient air pressure: 970 mbar
                        Voltage terminal 30: 14.442 V
                        Unlearning counter according OBD: 40
                        Median injection timing: 1.585 ms
                        Engine operating condition: Idling
                        Engine operating condition-Test_Program_Channel 87: 5
                        Brake actuated status-Bits 0-7: 59
                        Engine torque: 60.3 Nm
    Readiness: 0000 0100
    Address 02: Auto Trans (J217)       Labels:| 0BK-927-156.clb
       Part No SW: 8K1 927 158     HW: 0BK 927 156 AL
       Component: 0BK 20TFSIUSA H16 1006
       Revision: --H16---
       Coding: 000002
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_TCMAL551211 002022
       ROD: EV_TCMAL551211_002_AU48.rod
       VCID: 74B1212B4E3BBFBB473-8020
    No fault code found.
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
       Part No SW: 8K9 907 379 M    HW: 8K9 907 379 M
       Component: ESP8 quattro  H09 0100
       Revision: --------    Serial number: --------------
       Coding: 0E1D18
       Shop #: WSC 06334 000 00000
       VCID: 4CC199CB76CB877BFF3-8018
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 8K0 907 064 FP    HW: 8K0 907 064 FP
       Component: BCM2 2.0      H10 0602
       Revision: 00002001
       Coding: 0D820000000000000000
       Shop #: WSC 06335 000 00000
       VCID: 035372F71B1588034E9-8056
       Subsystem 1 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Component: J764 ELV MLB  H40 0046
       Serial number: 2312000100185014
    1 Fault Found:
    00955 - Key 1
                002 - Lower Limit Exceeded
                 Freeze Frame:
                        Fault Status: 01100010
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 78
                        Mileage: 97895 km
                        Time Indication: 0
                        Date: 2020.05.28
                        Time: 16:04:28
    Address 08: Auto HVAC (J255)       Labels: Redir Fail!
       Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
       Component: KLIMA 3 ZONEN H04 0123
       Revision: C1000000    Serial number: 01110520121266
       Coding: 6480208000
       VCID: 3333E2370B35F8839E9-8066
    Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
       Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
       Component: BCM1 1.0      H14 0103
       Revision: 08014001    Serial number: 00000030437701
       Coding: 26000091803CAFC00000480300003D0D0F1C4708A2090221000008000000030100000030000000
       Shop #: WSC 08185 444 103375
       VCID: 78A9151B52D3DBDB6BB-802C
       Subsystem 1 - Part No SW: 8K1 955 119 A    HW: 8T1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 110512  H07 0070
       Serial number: SWF12050115803
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0002
       Serial number: 20271225
       Coding: 02005D
       Subsystem 3 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000305120151
       Subsystem 4 - Part No SW: 4G0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R1NZ702
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Component: AQ_Hum_Sensor  H02 0002
       Serial number: 2908C126000000000001
    Address 15: Airbags (J234)       Labels:| 8K0-959-655.clb
       Part No SW: 8K0 959 655 M    HW: 8K0 959 655 M
       Component: AirbagVW-AU10 H46 0610
       Serial number: 003KEDA014G
       Coding: 303844354A32303030304A55304C384B3053
       Shop #: WSC 00040 002 1048576
       ASAM Dataset: EV_AirbaECUVWAUDI010 003010
       ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
       VCID: 47CBA6E76F2D6423D21-8012
       Seat occupied recognition:
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Component: BF-Gewichtss.  H02 0040
       Serial number: 5810000R1200008MMA
       Crash sensor for side airbag: driver side:
       Serial number: 6334MSME6E514072C
       Crash sensor for side airbag: front passenger side:
       Serial number: 6344MSME6F222D3BS
       Crash sensor for side airbag: rear: driver side:
       Serial number: 6352QSME441653628
       Crash sensor for side airbag: rear: passenger side:
       Serial number: 6362QSME4F15014CK
       Crash sensor for front airbag: driver side:
       Serial number: 63732SME6D14325A0
       Crash sensor for front airbag: front passenger side:
       Serial number: 63832SME4C145162Z
    Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
       Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
       Component: Lenks.Modul   H02 0171
       Revision: 00000000    Serial number: 20120514001084
       Coding: 000017
       VCID: 4FFB8EC787DDBC639A1-801A
       Component: E221 - MFL  H03 0003
    Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 982 A    HW: 8K0 920 982 A
       Component: KOMBIINSTR.   H35 0540
       Revision: 00000000    Serial number: NTC23475D
       Coding: 8B3629020301D705020000
       VCID: 323DE733F42FF18B95F-8066
    Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
       Part No SW: 8R0 907 468 C    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H10 0025
       Revision: 1Y030014    Serial number: 1441Y125030368
       Coding: 00C303FF00
       VCID: 3FDBBE07377D2CE36A1-806A
       Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
       Component: J367-BDMHella  H03 8041
       Serial number: 8175957401
    Address 36: Seat Mem. Drvr (J136)       Labels:. 8T0-959-760.clb
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0076
       Revision: AA000000    Serial number: 00000029145580
       Coding: 00581B00000000000000
       VCID: 3B23CA17236530C3469-806E
    Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
       Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000029908343
       Coding: 011C13205E00410001
       VCID: 4DC794CF8DD18E73E8D-8018
    Address 44: Steering Assist (J500)       Labels:| 8K0-909-144.clb
       Part No SW: 8K0 909 144 F    HW: 8K0 909 144 B
       Component: RCEPS         H36 0507
       Revision: 00001000    Serial number: 0020526803
       Coding: 100000000001
       Shop #: WSC 08185 444 122181
       ASAM Dataset: EV_RCEPSAU48X 008014
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3431E12B0EBBFFBB873-8060
    Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0176517259
       Coding: 0126023A20BA709580B0023200000000
       Subsystem 1 - Part No SW: 8K0 959 719 B    HW: 8K0 959 719
       Component: GTO BF  H01 0080
       Serial number: 00000000000000519778
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J245 PS150  H08 0043
       Subsystem 4 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J394 PS240  H08 0043
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOM.clb
       Part No SW: 8T1 035 223 A    HW: 8T1 035 223 A
       Component: DSP Prem      H04 0030
       Revision: 00004001    Serial number: 94814003201301
       VCID: 2D07F44FED11AE73C8D-8078
    Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
       Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000029772602
    Address 53: Parking Brake (----)       Labels: 8K0-907-801-V2.clb
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 00000000048809
       ASAM Dataset: EV_ParkiBrake 001027
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3829D51B12D31BDBABB-806C
    Address 56: Radio (R)       Labels: Redir Fail!
       Part No SW: 4G0 035 080 G    HW: 4G0 035 080
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 158H10E7505942
       Coding: 020007010000000001
       Shop #: WSC 01238 002 1048576
       VCID: 221D1773A4CF610B65F-8076
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Part No SW: 8R1 035 746 G    HW: 8R1 035 746 A
       Component: H-BNT-NA      H42 0901
       Revision: --------    Serial number: 096E 0C7510836
       Coding: 010200050006A1EF41028F4E00000403140000000000000000
       Subsystem 1 - Part No: 8R0 060 884 AD
       Component: NAR 2011  0505
       Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
       Component: DU7 High  H41 0104
       Serial number: A130EG0CS169387
       Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
       Component: E0380 Bedient  H02 0030
       Serial number: 00000001153298
       Subsystem 4 - Part No: 8R0 060 961 B
       Component: CD-Database  3371
    Address 62: Door, Rear Left (J388)       Labels:. 8K0-959-795.clb
       Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
       Component: TSG HL        H01 0506
       Revision:             Serial number: 0000030049731
       Coding: 010C13204000210001
       VCID: 43D3B2F75B9548030E9-8016
    Address 6C: Back-up Cam.        Labels: 8T0-907-441.clb
       Part No SW: 8T0 907 441 D    HW: 8T0 907 441 D
       Component: J772__Rearview      0140
       Revision: --H06---    Serial number: 525PA8-J229325
       Coding: 1000007
       VCID: 392FD01F255902D3545-806C
    Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
       Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
       Component: J605  Master  H52 0330
       Revision: --------    Serial number: 8K9827851A
       VCID: 3C21C90B266B37FB4F3-8068
       Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
       Component: J756  Slave  H52 0330
       Serial number: 8K9827852A
    Address 72: Door, Rear Right (J389)       Labels:. 8K0-959-795.clb
       Component: TSG HR        H01 0506
       Revision:             Serial number: 0000030050712
    1 Fault Found:
    02115 - Locking Unit for Central Locking
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 132
                        Mileage: 98050 km
                        Time Indication: 0
                        Date: 2020.06.04
                        Time: 18:52:02
    End----(Elapsed Time: 02:02, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
    Veteran Member Three Rings Stazi's Avatar
    Aug 27 2019
    2012 Audi A4 S-Line, 2019 Jeep Grand Cherokee Altitude 4x4, 2017 Moomba Craz
    Michigan
    HPFP is going bad I bet. Is your oil level rising as well and stinks like fuel?
    Same thing happened to me. Changed e HPFP and after clearing the code it never came back.
    2012 Audi A4 2.0T S-Line
    K04 // IE Stage 3 K04 tune // USP HFC // Becker Cat-back // ECS Intake Pipe (w/modded airbox + K&N) // ECS Luft-technik FMIC Intercooler and pipe kit // GFB VTA // RS mesh grille // CF M4 style spoiler // ST rear sway bar.
    Established Member Two Rings audiyadosir's Avatar
    Jun 13 2017
    San Francisco, CA
    +1
    Had this code when I bought the car. Spent the $650+ to get the full rebuild kit from FCP euro and the code went away with the piece of shit fuel pump. Whomever at Audi thought it was a good idea to put the fuel pump where it could leak fuel directly into the engine was smoking something I never wanna try! Dumb, dumb, dumb.
    I just recently discovered my intake manifold runner flap hex connection has popped out the back of my IM leaving me with a Hoover of a vacuum leak just as 1000s of others.
    Now, I’m thinking it was the degradation and eventual failure of this piece that has been the cause of my shit gas mileage for the last two years. Change the HPFP, the cam follower that pumps it, change your fuel filter, check your lines, and check that runner flap arm!! It may save you 1000s of dollars
    Aug 27 2019
    Michigan
    And change your oil!!!!
