Quick story; two buddies and I all ended up with a 2.7 on stands, with zero end game. One day we are starting at them and each other and all decided to have a build off. There are some categories to win like; first to pull the trigger on turbos, first to zero MILs, most power/dollar invested, cleanest, etc. Only thing on the line is bragging rights really. The other two are doing swaps into B5S4, so they have a clear advantage, except that they are the type to never finish a project! I took the B7 approach, since I've always wanted a wagon, and like the B7 lines more compared to the B5/B6, and my fleet is primarily B6/B7s. Making my parts hoard that much easier to manage with a B6/B7
Here is the recipe:
- 2001 APB motor, stock bottom end/valve train
- BW S257
- Tial MR44 waste gate
- XS Power STK Piping
- 630cc Bosch EV14 Injectors
- Hitachi 85mm MAF
- OEM B7 2.0. to start DMIC to FMIC, not committed yet
- 1.8 or 2.0 coils, valve cover dependent
- 01E from a B6 3.0 with JHM 1-2 collar/syncros and 4 to 1 bias center diff washer mod, with complementary 4.11 rear diff
- Fuel pump, tbd
- TTV SMF 15lbs flywheel with OEM RS4 pressure plate and disc
- Catch can, was trying to avoid this, but cant with the planned VCs
Things to delete:
- After run coolant pump and sensor
- N249 diverter valve controller
- Ignition Control Module(ICM)
- Exhaust Gas Temperature(EGT) sensors
Hoping I can clean/tuck the wiring a bit, but dont know if I have the skill for this.
Other things that will evolve throughout out all this:
- Maintain AC, plan to use 2.0 compressor
- 2.4 BDV timing belt cover
- 2.8 ACK valve covers
- 2.8 AHA/ATQ coolant cross over pipe
- 2.8 AHA/ATQ main pipe from rad to cross over pipe
- 2.8 AHA/ATQ power steering pump and bracket
- power steering hoses tbd, custom?
- 2.8 AHA/ATQ exhaust manifolds
- B6 ABS pump/module
- B6 cluster
- 3.0 fuel return line
- DTM front bumper, side skirts
- DTM rear bumper, needs to be molded
- BC Coils
If I make 500hp at the crank then I'll be happy. I'm keeping stock bottom end, stock valve train and these seems to be the limit for those components. I have a Borg Warner S257 5761 0.82 external waste on the way. I'll be the first to say, I am not very well versed with turbo sizing and the tuning side of things. A local tuning guy/buddy and I deliberated for many hours and settled on this thing based on the amount of jam I loosely described that I was looking for.
So lets rewind a bit, here is the chasis; 2006 3.2 s-line automatic when I picked it up in 2018 with 170,000kms/106,000miles on it:
I saved it from the PO who wanted to cut the springs and stretch some 215s on 10" wheels. Since it developed a chain tensioner issue, which he couldnt get past how to change a spark plug, lead him to sell cheeeeeap. I fixed the tensioner and drove it while picking away at the 2.7 block. I did a bunch of things in the mean time to the chasis: s5 peelers, 2016 s4 front seats and steering wheel, but first had to trailer it home 5 hours:
It lived its first couple months like this:
Drove it for 20,000km like this:
Fast forward to last weekend, I decided the only way to kick my build into gear is to rip out the perfectly running 3.2:
Sold it in record time, 2 days from being pulled:
The Magna seats:
Still prefere B6/B7 Recaros.
The wheel:
I also got the front DTM bumper repaired and shaved the marker and headlight washer, yet to be installed, have the grills, just need to source the CF lip:
Here is the 01E pulled from the yard and the competition, hard to beat $102usd:
Just waiting on the JHM 1-2 rebuild for this thing.
My dad is always looking to pitch in the mitts even at the junk yard! He is awesome:
I've been working on cleaning the engine bay:
I removed the stock sound deadening material from the strut towers and 2nd fire wall, but will keep the stock heat shielding. Been reviewing whats necessary for the ABS retrofit and will hit a yard shortly to grab what I need.
Since we didnt have a crane when we hauled the drive train out, we elected to remove it with the subframe, and you cant just remove a subframe without powder coating it. Which lead me to removing bushing, and now its at the powder coater, and starting thinking about intake and valve cover colors:
And for the 2.7 itself, I removed the heads to inspect, obviously did the timing and water pump, front crank seal, oil cooler seal, cam seals, etc... I wont bore you with the maintenancy stuff, but the STK piping came in finally and started mocking it up and that is where I stand now:
Need to modify the 2.8 cross over pipe since these interfere, but nothing a welder cannot sort out:
I also chopped up the fuel rail of the N75, N80 and N249(delete). Still looking to relocate the N75 and N80 under the manifold, we'll see how that goes :/ its tight:
I may have missed a thing or two, but at least this give me a place to start, organize and track my progress. I hope it wasnt too short in content, mod; delete if not allowed.
