Results 1 to 20 of 20
    Mar 19 2016
    70 Nova
    Long Island, NY
    Audi S3 *V rotor and pad recommendations
    I will be needing to replace my rotors and pads soon and was wondering if someone can recommend a good replacement set. I'd like something that has the hub painted black and sloted or drilled rotors options. I know Adam's rotors makes them but they are a bit too pricey for me. Are there any alternative lower priced options that people have had good results with?
    2016 Sepang Blue Audi S3
    Emmanuele Lowering Springs; Blacked S3 Emblems, 30% Tint, Black diffuser panel
    Unitronic Stage 2 ECU & Stage 2 TCU, Unitronic Intercooler, CTS Turbo inlet, ECS Air Pipe, K&N Air Filter, LED Cabin Lighting
    19x8.5 ET35 VMR Flow Formed 803 Rims - Powdercoated Semi Gloss Stock Vspoke black Optics rims with Conti DS06 tires for winter/fall
    AWE resonated Downpipe and Cat Back Track Exhaust
    1970 Chevy Nova 1000hp 540cid. Too many mods to list.
    Veteran Member Three Rings TheDude420's Avatar
    Mar 07 2018
    S3
    Florida
    Quote Originally Posted by bent View Post
    There are some good options out there for drilled performance rotors that are lightweight (13-15lbs total reduction from stock). Weight (sprung and unsprung) can have a big impact on launching, braking, mpg, wear, etc. Those go for about $1,000+. ECStuning and Neuspeed have some nice lightweight rotors for the S3. You can also buy replacement rotors and hubs that weigh the same as the stock ones for $300-400. Check out Emmanuele Design or Stoptech for the lower priced options. The hubs on all of these are black so you don't have to worry about rust. You can also clean the rust and paint the stock hubs black to save money.
    2016 S3 P+, Tech Pack, Black Optics, Super Sport Seats, Mag-Ride, Facelift-Style Headlights, APR Stage 2 High Torque & DSG Tune, Carbon fiber Intake, Intercooler, RS3 Coils, RS7 Spark Plugs, Boost Hose System w/Bypass Hose, Catch Can, AWE Downpipe, AWE Switchpath Exhaust, 034 Motorsport Dynamic Lowering Springs, RSB End Links, Neuspeed RSE102, Dogbone Mount Insert, Neuspeed Rear Sway Bar, EMD Carbon Fiber Diffuser, Carbon Fiber Spoiler, Milltek Cerakote Black GT-100 Exhaust Tips
    Mar 19 2016
    70 Nova
    Long Island, NY
    Thanks for your response. Quick question regarding isntallation on my S3. Do you need to reset anything in the S3's system? I thought I remember hearing something about using a VCDS cable to reset something.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    I really like the StopTech stuff (performance line made by Centric).Their sport pads, slotted rotors and stainless lines were a dramatic improvement over the stock setup. And yes, the hubs are black.
    2019 SQ5 Prestige
    Apr 03 2018
    2018 S3, 2013 VW CC
    I went by the other forum member. R1 Concepts and Z23 pads. No complaints at all.
    https://www.audizine.com/forum/showt...light=concepts
    Mar 19 2016
    70 Nova
    Long Island, NY
    Can someone please comment on my earlier question? Do you need to reset anything in the S3's compuer system? I thought I remember hearing something about using a VCDS cable to reset something.
    Apr 04 2020
    Pittsburgh, PA
    You def need something like vcds, obd11, or maybe carista to reset/release the e-brake for the back.
    Sent from my SM-G988U using Audizine mobile app
    Apr 01 2007
    houston texas
    Besides the e-brake you also need a similar devise to properly bleed the brakes.
    2019 SQ5 Prestige
    Mar 19 2016
    70 Nova
    Long Island, NY
    Quote Originally Posted by texasboy21 View Post
    Thanks, I will not need to bleed the brakes as I am not changing the calipers. Does anyone have a video or a PDF that details the brake change? Also, anyone have instruction on how to perform the ebrake release in VCDS?
    Apr 03 2020
    FL
    http://wiki.ross-tech.com/wiki/index...#Basic_Setting
    In OBD11, the same is done with Brakes>Basic settings>Start line change mode or something like that. End line change mode when you are done.
    Mar 19 2016
    70 Nova
    Long Island, NY
    Thanks. Question, would compressing the caliper and pads with a clamp manually do the same thing as the codes you posted or is this mandatory?
    Apr 03 2020
    FL
    Thanks. Question, would compressing the caliper and pads with a clamp manually do the same thing like you would do on any car or is that not possible?
    Front you compress like any other car with a clamp. Rear you have to retract the EPB and then compress. There is a slider and a screw mechanism inside the rear caliper piston.
    Apr 01 2007
    houston texas
    When what the last time it was flushed? Should be done annually, and seems silly to service the brakes and NOT flush the fluid.
    2019 SQ5 Prestige
    Mar 19 2016
    70 Nova
    Long Island, NY
    Ok i just purchased the Power Stop K7253 - Z23 Evolution Sport Brake Upgrade Kit and Dupli-Color BCP102 High Performance Brake Caliper Paint to paint the rotor hubs black.
    Here is the interesting thing. Apparently depending on where you go to order the K7253 kit, the website will tell you this kit is not for an Audi S3. It's for a 2015 Golf VW. If you goto Power stops website, it lists the K7253 for Audi S3. https://www.powerstop.com/product/po...&mk=AUDI&mo=S3
    I called Powerstop and the rep told me to use K7543, i said on your website it says use K7253. Also, the K7543 is $100 more expensive.. The rep said she will talk to techsupportt and call me back. She called me back and said that they are discontinuing the K7543 and to use the K7253. I asked why, she said the K7543 is more expensive because it includes Audi brake sensors in the kit and they've decided not to sell and supply a kit with sensors.
    I ordered the K7253 as I found it on-sale for $375 but wanted to hear if anyone can confirm that the K7253 is what they've used. I'm concern that I may need these sensors. I am going to spray paint the hubs in advance before installing and I would be very upset if I painted the hubs and install, and it doesn't work because the sensors are required. Can someone please shed some light on this? Are these sensors mandatory or do you use recycle the original ones?
    Apr 03 2020
    FL
    I bought z23 pads for my A3 also, just the pads. Mine did not come with the pad wear sensor even though IDPart description says it should’ve. So, I’m a bit annoyed by that. I’m replacing my pads early, so the OE sensor was not touch and in good shape. I was able to carefully take it off the OE pad and put it on z23 pad.
    By the way the wear sensor looks to be a plain wire that would get cut once the pad is low and trip the warning.
    Mar 19 2016
    70 Nova
    Long Island, NY
    So what happends if you cant salvage the sensor from the old pads? Will it throw off a fault code? Do i need to cancel the order and get the other kit?
    Apr 03 2020
    FL
    Yes, i think you’ll get a warning on the dash. I don’t know exactly what that looks like on our cars. I’m sure there is a fault code also.
    If you can’t save the sensor, you can buy a new one. Or... I’d just cut the wire, close the open circuit, tape it up, and zip tie to something to keep it out of the way and be done with it. I don’t need my car to tell me when my pads are low.
    Mar 19 2016
    70 Nova
    Long Island, NY
    how do you remove the sensor? does it pull off or do you have to cut it?
    Mar 19 2016
    70 Nova
    Long Island, NY
    Looking up part,
    https://www.ecstuning.com/Audi-8V_S3...sors/Pad_Wear/
    It looks like there are only front sensors? is that the case?
    Apr 03 2020
    FL
    You can pull it off. Just use a small pick to loosen the metal clip and carefully pull it off the pad. If the wire that runs across it is not damaged, you are good to go.
    By the way, the ECS bypass that they sell, basically closes the circuit to avoid having sensor plugged into the pad to remove the warning. Electric tape works too.
    And to answer your other question, on my car there is only one sensor. It’s passenger side front pad.
