1) Press Ignition Button : car fires and immediately stalls
2) Press Ignition Button Second Time: car continually cranks for ~5s before starting, after which it seems to run normally
I ran a scan and received the following. I'm looking at fault 4106 - Bank 1; System too Rich at Idle, since it gives a date when it occurred, although this wasn't the date of the most recent occurrence for some reason. I was thinking the N80 valve might be faulty but wasn't sure if that could lead to an intermittent hard start I'm experiencing. Any help is appreciated.
Code:
-------------------------------------------------------------------------------- Mileage: 98110km-60962miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine (DET-CPMA) Labels:. 06H-907-115-CDN.clb Part No SW: 8K5 907 115 F HW: 8K2 907 115 L Component: 2.0l R4/4V TF H09 0008 Revision: ECH09--- Coding: 722A0013242600062000 Shop #: WSC 54964 001 1048576 ASAM Dataset: EV_ECM20TFS0118K5907115F 001009 ROD: EV_ECM20TFS0118K5907115F.rod VCID: 3537DC2F05C1E6B3B0D-8060 1 Fault Found: 4106 - Bank 1; System too Rich at Idle P2188 00 [232] - - MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 3 Mileage: 97906 km Date: 2020.05.28 Time: 16:34:15 Engine speed: 827.00 /min Normed load value: 23.5 % Vehicle speed: 0 km/h Coolant temperature: 96 °C Intake air temperature: 21 °C Ambient air pressure: 970 mbar Voltage terminal 30: 14.442 V Unlearning counter according OBD: 40 Median injection timing: 1.585 ms Engine operating condition: Idling Engine operating condition-Test_Program_Channel 87: 5 Brake actuated status-Bits 0-7: 59 Engine torque: 60.3 Nm Readiness: 0000 0100 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb Part No SW: 8K1 927 158 HW: 0BK 927 156 AL Component: 0BK 20TFSIUSA H16 1006 Revision: --H16--- Coding: 000002 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMAL551211 002022 ROD: EV_TCMAL551211_002_AU48.rod VCID: 74B1212B4E3BBFBB473-8020 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K9 907 379 M HW: 8K9 907 379 M Component: ESP8 quattro H09 0100 Revision: -------- Serial number: -------------- Coding: 0E1D18 Shop #: WSC 06334 000 00000 VCID: 4CC199CB76CB877BFF3-8018 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 FP HW: 8K0 907 064 FP Component: BCM2 2.0 H10 0602 Revision: 00002001 Coding: 0D820000000000000000 Shop #: WSC 06335 000 00000 VCID: 035372F71B1588034E9-8056 Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E Component: J764 ELV MLB H40 0046 Serial number: 2312000100185014 1 Fault Found: 00955 - Key 1 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 78 Mileage: 97895 km Time Indication: 0 Date: 2020.05.28 Time: 16:04:28 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8K1 820 043 N HW: 8K1 820 043 N Component: KLIMA 3 ZONEN H04 0123 Revision: C1000000 Serial number: 01110520121266 Coding: 6480208000 Shop #: WSC 06335 000 00000 VCID: 3333E2370B35F8839E9-8066 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 DH HW: 8K0 907 063 AH Component: BCM1 1.0 H14 0103 Revision: 08014001 Serial number: 00000030437701 Coding: 26000091803CAFC00000480300003D0D0F1C4708A2090221000008000000030100000030000000 Shop #: WSC 08185 444 103375 VCID: 78A9151B52D3DBDB6BB-802C Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 110512 H07 0070 Serial number: SWF12050115803 Coding: 00FD11 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0002 Serial number: 20271225 Coding: 02005D Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS Component: E1 - LDS H03 0031 Serial number: 00000000000305120151 Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A Component: USHL4.2 H30 0030 Serial number: 0000002274555R1NZ702 Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H02 0002 Serial number: 2908C126000000000001 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8K0-959-655.clb Part No SW: 8K0 959 655 M HW: 8K0 959 655 M Component: AirbagVW-AU10 H46 0610 Serial number: 003KEDA014G Coding: 303844354A32303030304A55304C384B3053 Shop #: WSC 00040 002 1048576 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 47CBA6E76F2D6423D21-8012 Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C Component: BF-Gewichtss. H02 0040 Serial number: 5810000R1200008MMA Crash sensor for side airbag: driver side: Serial number: 6334MSME6E514072C Crash sensor for side airbag: front passenger side: Serial number: 6344MSME6F222D3BS Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME441653628 Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME4F15014CK Crash sensor for front airbag: driver side: Serial number: 63732SME6D14325A0 Crash sensor for front airbag: front passenger side: Serial number: 63832SME4C145162Z No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q Component: Lenks.Modul H02 0171 Revision: 00000000 Serial number: 20120514001084 Coding: 000017 Shop #: WSC 06335 000 00000 VCID: 4FFB8EC787DDBC639A1-801A Component: E221 - MFL H03 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 982 A HW: 8K0 920 982 A Component: KOMBIINSTR. H35 0540 Revision: 00000000 Serial number: NTC23475D Coding: 8B3629020301D705020000 Shop #: WSC 06335 000 00000 VCID: 323DE733F42FF18B95F-8066 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8R0 907 468 C HW: 8R0 907 468 C Component: GW-BEM 4CAN-M H10 0025 Revision: 1Y030014 Serial number: 1441Y125030368 Coding: 00C303FF00 Shop #: WSC 06335 000 00000 VCID: 3FDBBE07377D2CE36A1-806A Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181 Component: J367-BDMHella H03 8041 Serial number: 8175957401 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb Part No SW: 8K0 959 760 D HW: 8K0 959 760 D Component: MEM-FS H06 0076 Revision: AA000000 Serial number: 00000029145580 Coding: 00581B00000000000000 Shop #: WSC 06335 000 00000 VCID: 3B23CA17236530C3469-806E No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 P HW: 8K0 959 793 P Component: TSG FA H02 0506 Revision: Serial number: 0000029908343 Coding: 011C13205E00410001 Shop #: WSC 06335 000 00000 VCID: 4DC794CF8DD18E73E8D-8018 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb Part No SW: 8K0 909 144 F HW: 8K0 909 144 B Component: RCEPS H36 0507 Revision: 00001000 Serial number: 0020526803 Coding: 100000000001 Shop #: WSC 08185 444 122181 ASAM Dataset: EV_RCEPSAU48X 008014 ROD: EV_RCEPSAU48X_008.rod VCID: 3431E12B0EBBFFBB873-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 FP HW: 8K0 907 064 FP Component: BCM2 2.0 H10 0602 Revision: 00002001 Serial number: 0176517259 Coding: 0126023A20BA709580B0023200000000 Shop #: WSC 06334 000 00000 VCID: 035372F71B1588034E9-8056 Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719 Component: GTO BF H01 0080 Serial number: 00000000000000519778 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591 Component: J245 PS150 H08 0043 Subsystem 4 - Part No SW: 8K0 959 591 B HW: 8K0 959 591 Component: J394 PS240 H08 0043 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb Part No SW: 8T1 035 223 A HW: 8T1 035 223 A Component: DSP Prem H04 0030 Revision: 00004001 Serial number: 94814003201301 VCID: 2D07F44FED11AE73C8D-8078 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 P HW: 8K0 959 792 P Component: TSG BF H02 0506 Revision: Serial number: 0000029772602 Coding: 011C13205E00410001 Shop #: WSC 06335 000 00000 VCID: 4CC199CB76CB877BFF3-8018 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb Part No SW: 8K0 907 801 L HW: 8K0 907 801 J Component: EPB-4 H01 0003 Revision: -------- Serial number: 00000000048809 ASAM Dataset: EV_ParkiBrake 001027 ROD: EV_ParkiBrake_AU48.rod VCID: 3829D51B12D31BDBABB-806C No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 080 G HW: 4G0 035 080 Component: Radio U SIRIU H60 0133 Revision: AB001007 Serial number: 158H10E7505942 Coding: 020007010000000001 Shop #: WSC 01238 002 1048576 VCID: 221D1773A4CF610B65F-8076 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8R1 035 746 G HW: 8R1 035 746 A Component: H-BNT-NA H42 0901 Revision: -------- Serial number: 096E 0C7510836 Coding: 010200050006A1EF41028F4E00000403140000000000000000 Shop #: WSC 06335 000 00000 VCID: 3B23CA17236530C3469-806E Subsystem 1 - Part No: 8R0 060 884 AD Component: NAR 2011 0505 Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604 Component: DU7 High H41 0104 Serial number: A130EG0CS169387 Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C Component: E0380 Bedient H02 0030 Serial number: 00000001153298 Subsystem 4 - Part No: 8R0 060 961 B Component: CD-Database 3371 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 D HW: 8K0 959 795 D Component: TSG HL H01 0506 Revision: Serial number: 0000030049731 Coding: 010C13204000210001 Shop #: WSC 06335 000 00000 VCID: 43D3B2F75B9548030E9-8016 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8T0 907 441 D HW: 8T0 907 441 D Component: J772__Rearview 0140 Revision: --H06--- Serial number: 525PA8-J229325 Coding: 1000007 Shop #: WSC 06335 000 00000 VCID: 392FD01F255902D3545-806C No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb Part No SW: 8K9 827 851 A HW: 8K9 827 851 A Component: J605 Master H52 0330 Revision: -------- Serial number: 8K9827851A VCID: 3C21C90B266B37FB4F3-8068 Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A Component: J756 Slave H52 0330 Serial number: 8K9827852A No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 D HW: 8K0 959 795 D Component: TSG HR H01 0506 Revision: Serial number: 0000030050712 Coding: 010C13204000210001 Shop #: WSC 06335 000 00000 VCID: 43D3B2F75B9548030E9-8016 1 Fault Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 132 Mileage: 98050 km Time Indication: 0 Date: 2020.06.04 Time: 18:52:02 End----(Elapsed Time: 02:02, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
