Results 1 to 40 of 42
    Veteran Member Three Rings whats77inaname's Avatar
    Aug 09 2018
    ¯\_(ツ)_/¯ Tx
    For those using metal water pumps....
    ....specifically the Graf from @FCPEURO.....I put my unit on in 9/19....I noticed a small leak a few weeks ago. Looking around the forums, it seems like I'm not the only one having that issue. It looked like was coming from the same place as it did when the pump failed. I pulled it to check it out....but it looked fine. Gasket looked fine. Everything looked good. Then found it was gathering on the ledge under the manifold, so no, not the same spot. I put it back on and re-torqued it down. The next couple days, I noticed it was still leaking. Instead of sending it back for a replacement, I went ahead and ordered an OEM water pump gasket. Given that it was 100 degrees today, I waited until tonight to pull it and replace the gasket. I removed the old one, and when I opened the package for the new one, I noticed the difference immediately.
    I could feel the difference in my hands, that the OEM gasket was heftier. So I found a level surface and took a picture. Pretty sure you can determine which is which. Hopefully this'll resolve it...I'll keep y'all posted.
    The OEM part number is 06J121119. You have to snip off a little nib that correlates to a slot in the OEM plastic pump. After that, drops right in.
    K04 | Work | Snow/USRT | IE | 034 | Eurocode | H&R | V1 | ECS | Alu Kruez | CR-15 | AfE | Audi | MCP | Misc
    Build
    Jan 03 2013
    Baltimore
    Interesting. I recently replaced my second failed pump with the graf unit. The one that failed previous was leaking slightly, I cannot recall the brand. There has been discussion that the pumps leak due to oil leaking from the VC/cam covers onto the seal of the WP weakening it making it leak.
    Sent from my Pixel 3 using Audizine mobile app
    Aug 09 2018
    ¯\_(ツ)_/¯ Tx
    Quote Originally Posted by elscotto80 View Post
    I saw that. My original pump gasket was swollen when the pump came out, and you can see oily residue on the pump itself.
    I had my valve cover resealed earlier this year as there was a slight, visible leak coming from the driver's side front corner of the cover. When I pulled the GRAF, no oily residue, either time.
    As I was researching this the 2nd time around, I stumbled on someone going through this w/their Graf pump, and the OEM recommendation to torque the bolts to 9lbs. I feel that, given the difference in the amount of material, that 9lb recommendation might not necessarily be doing the trick for the GRAF unit/gasket over time.
    Senior Member Three Rings ericA6's Avatar
    May 03 2012
    Dallas, Tx
    Interesting you bring this up. I’ve been battling a very small coolant leak after switching to the metal GRAF pump. I’ve changed a few o-rings, but not that gasket, and am still having intermittent small leaks. Seems to be worse in cooler weather. I’ll have to order the OEM gasket and see if that resolves my annoying leak.
    Current - '10 A4q S-Line
    '16 Honda CB500F - I like my bikes naked
    Past - '05 A6q 3.2L
    Aug 09 2018
    ¯\_(ツ)_/¯ Tx
    Quote Originally Posted by ericA6 View Post
    Yeah, I saw your thread and was going to cross post to this thread, but I figured you'd see it anyway. That's what I have, too. Small leak, like, I couldn't tell where it was coming from until I let the car sit for about a week, and I could see it start pooling along the ledge under the manifold.
    Build
    Feb 24 2004
    Minneapolis
    Now I don't feel so damn inept. I put on a Graf aluminum last summer. Had to keep adding coolant every month or two till I took it off a few months ago. New gasket, (don't remember what I used) and cleaned it up good. I snipped off the little thing too. I still have a much smaller leak. I'd guess I"ll have to add every six months now. I can live with that.
    Here's what my gasket surface on the block looked like when I took off the Graf a couple months ago, then after I cleaned it up good. I was tempted to put some silicone on there, but Permatex web site says gasket maker + neoprene = bad idea.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Senior Member Four Rings
    Mar 05 2020
    NewYork
    Quote Originally Posted by mtroxel View Post
    I put a skim coat of black RTV on everything I dont care what anyone says lol
    I drive a 2011 Audi A5
    Aug 09 2018
    ¯\_(ツ)_/¯ Tx
    Quote Originally Posted by NitroViper View Post
    I don't know if that's really possible in this case. The pump doesn't press into place. You have to slide it from right to left to get it into position due to the belt. You'd end up smearing the RTV, pretty much rendering it ineffective.
    Wow, that's interesting. My mating surfaces didn't look anything like that, both were clean as a whistle. Your situation definitely lends credence to a failing aerobic valve cover gasket causing the pump to fail.
    In my situation, given that it would leak just sitting, plan is to:
    a) cover the alternator,
    b) spray out all the coolant under the hood, where it leaked (and I spilled *lol*) then
    c) leave the car outside with the hood up to evaporate all the water (it'll be over 100 degrees the next couples days). Verify no coolant anywhere.
    d) Fill the fluid reservoir to level, start it, let it get to operating temp, turn it off, leave it overnight
    e) Repeat "d".
    f) let it sit a few days
    g) check for a change in the reservoir level and check for leaks.
    Build
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by whats77inaname View Post
    e) Repeat "d".
    Our problems are pretty different. Your test wouldn't work with mine as it will go weeks with no leak. Then suddenly I'd see it on the bottom of the block, right under the water pump belt....yet that area around the belt was gone dry. From my pics, it appears my leak was on the forward-most water passage. Your gasket pics were interesting to me, especially given the truly shitty job Otto did when he machined my block the day my motor was built.
    Oct 30 2019
    Colorado
    Switch back to plastic and get the Rien kit.
    Aug 09 2018
    ¯\_(ツ)_/¯ Tx
    Quote Originally Posted by CRI View Post
    Have no clue as to what you're referring to. Link?
    Jan 03 2013
    Baltimore
    It's an aftermarket pump. Come to think of it this may have been the one that failed on me a few months ago that I replaced. Had a two year warranty, which was nice. I only had to pay for labor for the graf unit.
    Aug 09 2018
    ¯\_(ツ)_/¯ Tx
    Full disclosure: Been studying for my CCNA and a couple other certs, so my time hasn't been that focused on the car. Given that, here's the update: Shortly after posting the original post, I did the install. As I started filling up the reservoir, water started pouring out by the pump. Everything was put back together correctly, so I pulled it apart, reassembled it, same thing. I couldn't find out where it was coming from, but I already knew the pump had to come off, so I pulled the pump again, and that's when I noticed that both o-rings for the plastic elbow join for the pump were torn . I tracked down the part number for the elbow + gaskets, and came across this:
    https://www.ecstuning.com/b-uro-prem...6h121131c~upr/
    Figured I'd pick it up instead of the OEM union. The reasoning is that plastic and aluminum both have different heat expansion rates, so since the pump is aluminum, and the block is aluminum, it made sense to have an aluminum join. Yeah, I know they're probably different alloys, but eff it. Will it even make a difference? Not even sure, when it comes to most parts, I'll take machined aluminum over plastic anyday.
    Finally got around to installing it Wednesday, and realized that the OEM pump gasket I JUST PURCHASED I apparently tore on the previous install. Dealer wanted $26.xx for 1. I picked up 2 from fcpeuro for $3.xx each, paid for 2 day shipping (and *still* paid less than what it would cost at the dealer), and they arrived this morning. I didn't want any more surprises, so it was insurance to have a spare on hand. After coating the rubber surfaces with a thin coat of vaseline, I installed everything, then sprayed out the engine compartment to remove any standing coolant. Operating temp check, no leaks. 10 minute test drive and cool down, no leaks. A little harder run about 5 hours ago, no sign of the coolant seepage, and the cardboard is still dry. So, it appears this chapter is closed...finally.
    More good news: I can pull a pump in about 40 mins from drain to off the car, w/out pulling the mani. So I guess there's that *lol*. Gotta find the silver linings where you can.
    Build
    Feb 15 2016
    Cambridge,Ontario
    The block is steel. Head is aluminum
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Aug 09 2018
    ¯\_(ツ)_/¯ Tx
    Ah, thanks for the info. The oil cooler where the join connects the pump is aluminum, though, no?
    Build
    Feb 15 2016
    Cambridge,Ontario
    Well.iron. not steel. My bad
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    Yeah I think the oil cooler is aluminum..would make sense..
    1976 Yamaha XS 360
    Veteran Member Four Rings RockJGC's Avatar
    Sep 28 2014
    NY/NJ metro area
    I realize this is an older thread, but has there been any consensus on aluminum water pumps that actually work without leaking? I've read so many different opinions that I'm even more confused about these aftermarket aluminum units.
    Feb 15 2016
    Cambridge,Ontario
    if i were to buy one, it would be in cost alone, i see zero other benefit to it.
    my OE factory plastic one has been leak free, just like the one before it.
    1976 Yamaha XS 360
    Sep 28 2014
    NY/NJ metro area
    You might be lucky. I've heard and seen many, many people experiencing cracked waterpump housings with the OEM plastic pieces.
    Veteran Member Four Rings JLAllroad's Avatar
    Nov 11 2017
    Denver, Colorado
    Quote Originally Posted by RockJGC View Post
    Sounds like the installer not the part
    Feb 24 2004
    Minneapolis
    I would tell you that I've read a few like that...the OEM ones crack or leak. But that's usually after 70-80 K miles. Then you've got people like me who did the aluminum ones and they leaked from day F'n one. I don't hear any OEMs leaking from day F'n one. My aluminum Graf? Leaked from day F'n one.
    Junior Member One Ring
    Nov 06 2022
    EU
    Replaced mine at 62k miles. I choose aluminum Metelli 24-1359 running it for around 3 months and 3k miles with no leaks or problems. I'll see how it goes ...
    Sep 28 2014
    NY/NJ metro area
    Quote Originally Posted by JLAllroad View Post
    Yeah, doubtful since it they are the originally installed water pumps that came with the engine.
    Feb 15 2016
    Cambridge,Ontario
    lol ,well that pretty well says it all... that was a mic drop moment.
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    there was a recall for it ( or extended warranty i should say ) i know that. but overall i see no advantage to gong to the metal one.
    1976 Yamaha XS 360
    Nov 11 2017
    Denver, Colorado
    Well my experience (and Audi’s) is these last 80-100K miles before failure, hence why they only extended the warranty to failures up to 80K.
    Mine started weeping in the 90k range, but just barely, 2015 Allroad for reference.
    Senior Member Three Rings MongoMcG's Avatar
    Apr 15 2022
    B8 A4, C2 Corvette, Austin-Healey 3000 BJ8, SN95 Mustang, 36 Ford hot rod truck, A4 B9 S-line, A3 8V
    Michigan
    Reminder: for the coolant return pipe (from the heater matrix) is mounted with two bolts, and the bolt that holds the pipe to the water pump is short (M6 X 14mm - T30, part #N10405604). If you use a longer bolt it will crack the housing. The 14 mm length also applies to the bolt that holds the same pipe to the cylinder block according to the ETKA.
    “The Force is strong with this one.”
    My K04X build thread
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    Hmm. The ext warranty for my 2013 is 10yrs/100k miles.
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Sep 28 2014
    NY/NJ metro area
    Does anyone have the most current revision part number for the OEM plastic water pump?
    Feb 15 2016
    Cambridge,Ontario
    call your dealer and ask .. ask to confirm part number ask for price and availability .. and what lead time they need for ordering.. they always cough up the part number no problem.
    never had an issue doing that
    1976 Yamaha XS 360
    Sep 28 2014
    NY/NJ metro area
    The local dealer around here doesn't like to give part numbers. They are weird like that. Not sure why.....but that's why I asked if anyone happens to know the latest part number.
    Dec 29 2017
    Phoenix, AZ
    https://parts.audiusa.com/p/Audi__/E...H121026DR.html
    Just use the Audi parts catalog if the dealership won't help you.
    2010 Avant // 2015 Allroad
    Feb 15 2016
    Cambridge,Ontario
    that's weird,,,, and likely illegal actually. but no one is going to press it.
    1976 Yamaha XS 360
    Nov 11 2017
    Denver, Colorado
    Quote Originally Posted by k.sigota View Post
    Typically better pricing here for OE
    https://www.genuineaudiparts.com/oem...QtZmxleA%3D%3D
    Sep 28 2014
    NY/NJ metro area
    Thanks, that's a great resource. So I'll always be able to pull up the latest revision of any part on that website? I'm only asking because I've seen soooo many revisions of many different parts.
    Dec 29 2017
    Phoenix, AZ
    I use a combination of etka and Audi online parts catalog. ECS also lists MFG PNs which can help.
    Use JLAllroad's link:
    Apr 15 2022
    Michigan
    Parts and bolts for water pump replacement, plus torque specs for components
    Established Member Two Rings the-quattro-man's Avatar
    May 16 2018
    Sunshine State
    I'm about to tackle this as car is getting to 90k soon no leaks yet but I figured replace it anyway. Did replacing the gasket with OEM gaskets on these metal water pumps fix the leaking issue?
    DAILY DRIVER - 2014 B8.5 A4 Quattro S-Line | IE Stage 2 Tune | Eurocode Test pipe | ECS Valved Cat-back Exhaust | TR8 Intercooler | Solo-Werks S1 Coilovers | RS4 Grille | ECS Trans Mount | Silicone Charge Pipes | Macan calipers
    WEEKEND WARRIOR - 1990 MK3 Supra 1JZ | PTE 6266 CEA Turbo | Custom everything else | 526 WHP @ 22psi
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by the-quattro-man View Post
    I did that........twice.
    Continued to leak........twice.
