Results 1 to 4 of 4
    Jun 07 2020
    Dallas/Texas
    torque specs on bell housing aluminium bolts
    2010 A4 quattro avant B8/2.0LT
    I am seeking the torque specs on bell housing aluminum bolts to get my car back together.
    can anyone offer up suggestions
    Jan 01 2012
    2004 A4 Avant
    CO
    They are all 30nm plus 90 degrees except for the bottom 3 bolts (15nm plus 90 degrees) and lower starter bolt (65nm).
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Jun 07 2020
    Dallas/Texas
    just to confirm b8/2.0L engine?
    thank you !
    Jul 16 2018
    Atlanta
    Notice the footnote 4 regarding the aluminum bolts can be reused once. The repair manual is particular to note you should mark the bolts with paint or other manner, that won't wear off, when you reuse the bolt the first time. So the next time you know the bolt has to be replaced instead of reused.
