Results 1 to 10 of 10
    May 23 2020
    alberta
    need help opening exaust flaps and OBD 11
    new here so i apologize for any errors. own a 2017 S3 technik and new to OBD 11. been watching youtube vids on how to open the exhaust but mine dont seem to work the same way. while running and in park, i jammed a stick up into the exhaust and notice the noise difference when i hit the flaps and feel the exhaust. they dont seem to open while the car is running in dynamic mode. i could be wrong as i cant actually see if its open or not. im tring to open then then longcode it to keep them open at all times. what am i doing wrong? any ideas?
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    on cold start they open up.. have a look right after start. If not, maybe an issue? For a bit, I did cold start, then unplugged them so they were open all the time. With a downpipe and resonator delete it sounded obnoxious, so I hooked them back up. Its not like these cars will every sound particularly good no matter what you do.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Senior Member Three Rings johnruan's Avatar
    Oct 01 2014
    Audi Q5
    chicago,il
    Did you check obd11 long coding exhaust valve still shows disable or enable? If disable means open.
    Sent from my SM-G955U using Tapatalk
    Dec 06 2018
    Pacific North West
    ... chances are you know this, but just wanted to make sure you knew to have the valves open (putting the car in Dynamic Mode) BEFORE making the adjustment with OBDeleven otherwise it won't work
    Senior Member Three Rings A4_n00b's Avatar
    May 27 2007
    Pittsburgh, Pa.
    Quote Originally Posted by Bobbybrown View Post
    This. Start the car and put it in Dynamic and then turn it off. The valves we now be open. You can code it from there and it will accept the changes.
    Current:
    2022 Audi S3, 2023 Audi SQ5
    Retired:
    2003 Audi A4 3.0, 2004 Audi allroad 4.2, 2004 VW Jetta, 2008 VW Jetta Wolfsburg, 2010 Audi S4, 2012 VW GTI, 2014 Audi S4, 2015 VW GTI PP, 2016 VW Tiguan R-Line 4MO, 2018 Audi S3, 2018 Audi SQ5
    May 23 2020
    alberta
    Quote Originally Posted by A4_n00b View Post
    i hit the start button > turn on engine > dynamic mode( this is where im having issues explained below.)> hit start button which stops the engine and shuts the car down > hit the start button again to turn the car on but no engine running to get access to coding. i looked into the long code and under exhaust valves it says "active"
    while running i shove a stick into the exhaust and i dont think they are open as i seem to tap the valve in there and hear the difference when i knock it but could be wrong or its actually hitting the open valve and slightly closing it. i tried stuffing rags into the open ends to try build pressure against the valved ones but dont notice any difference on the valve side
    Oct 01 2014
    Audi Q5
    chicago,il
    Is your still enable? Start the car put in dynamic and trans in drive D. Put it in drive now shut of car (foot on brake) turn ignition without starting car. Now put it back in Park now go to obd11 and check disable exhaust valve and save.
    Veteran Member Three Rings TheDude420's Avatar
    Mar 07 2018
    S3
    Florida
    Getting in on this topic because I tried the exhaust flaps mod via OBDeleven last year and gave up because it wouldn't work. I have a 2016 S3. I drive in dynamic mode always. When I cold-start my car and rev the engine after a couple of minutes of idling or if I start to drive my exhaust flaps don't seem to be open. I have the pops & bangs tune and to get that to work I have to cycle through the drive select options while driving even though I'm already in dynamic mode. Once I cycle through comfort, individual, auto, and back to dynamic mode that opens my exhaust flaps and only then can I hear the pops & bangs.
    This is frustrating but on one hand it does mean pops and bangs isn't constantly on so I'm not always obnoxious and can have it off if I want.
    2016 S3 P+, Tech Pack, Black Optics, Super Sport Seats, Mag-Ride, Facelift-Style Headlights, APR Stage 2 High Torque & DSG Tune, Carbon fiber Intake, Intercooler, RS3 Coils, RS7 Spark Plugs, Boost Hose System w/Bypass Hose, Catch Can, AWE Downpipe, AWE Switchpath Exhaust, 034 Motorsport Dynamic Lowering Springs, RSB End Links, Neuspeed RSE102, Dogbone Mount Insert, Neuspeed Rear Sway Bar, EMD Carbon Fiber Diffuser, Carbon Fiber Spoiler, Milltek Cerakote Black GT-100 Exhaust Tips
    Jun 27 2020
    Sydney
    Anyone visit this on VCDS?
    May 27 2007
    Pittsburgh, Pa.
    Quote Originally Posted by barbalatte View Post
    I changed mine with VCDS using the steps in my earlier post.
    I reversed it about a week later though as also having the resonator delete makes the drone unbearable if you’re anything less than full throttle.
    Current:
    Retired:
