Results 1 to 3 of 3
    Established Member Two Rings vw754's Avatar
    Jan 18 2008
    stoke on trent
    AIRBAG FAULT HELP
    hi,all cars had a front end collission after getting it fixed,getting this airbag fault below.
    new bonnet hinges/igniters have been fitted,which are brand new and from audi.
    any help on this problem would be appreciated 2014 A3 TDI.
    Friday,05,June,2020,20:18:44:22644
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
    VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
    Data version: 20200331 DS317.0
    www.Ross-Tech.com
    VIN: WAUZZZ8V1EA175244 License Plate: A3 8V (2014)
    Mileage: 108113km-67178mi Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
    VIN: WAUZZZ8V1EA175244 Mileage: 108113km-67178miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    BB-Door Rear Drv -- Status: OK 0000
    BC-Door Rear Pass -- Status: OK 0000
    Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
    Part No SW: 04L 906 021 AL HW: 04L 907 309 B
    Component: R4 1,6L EDC H22 6546
    Revision: 84H22---
    Coding: 02190012032501092000
    Shop #: WSC 06314 790 00021
    ASAM Dataset: EV_ECM16TDI01104L906021AL 002011
    ROD: EV_ECM16TDI01104L906021P.rod
    VCID: 6FBBD14797188B33BA1-803A
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
    Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
    Component: ESC H31 0457
    Revision: 00000000 Serial number: 607940000015F1
    Coding: 12F18AA224270A710179060441C72548512450806082A4F202 4100080608
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
    ROD: EV_Brake1UDSContiMK100IPB_033.rod
    VCID: 7BA3F517D360E793069-802E
    Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
    Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
    Component: AC Automat H13 0052
    Revision: 20026000 Serial number: 00000000280249
    Coding: 03100104002000011000000000001100
    ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
    ROD: EV_AirCondiFrontVaAU37X.rod
    VCID: 323D183344AAE6DB95F-8066
    Relative humidity sensor in fresh air intake duct:
    Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Serial number: 46090E17000000000001
    1 Fault Found:
    262658 - High Pressure Sensor
    B10AE 31 [009] - No Signal
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 195
    Mileage: 108113 km
    Date: 2020.06.05
    Time: 20:09:24
    Outside air temperature: 13.5 °C
    Engine speed: 0.00 /min
    Compressor current: actual value: 0.000 A
    Temperature after evaporator: 31.0 °C
    System run time-Engine running time: 0 s
    System run time-Terminal 15 on: 135 s
    Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
    Component: BCM MQBAB H H16 0124
    Serial number: 00011408601121
    Coding: 07040A42C24122FD03844004B31C07A8000000000000000000 0000000000
    ASAM Dataset: EV_BCMCONTI 012001
    ROD: EV_BCMBOSCH_012.rod
    Control Unit For Wiper Motor:
    Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
    Component: WWS370 140321 041 0580
    Serial number: 140324180223
    Coding: 0A47F7
    Rain Light Recognition Sensor:
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 22437376
    Coding: 00006C
    Light switch:
    Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
    Component: E1 - LDS MQB H05 0032
    Serial number: 11 01 2014 00001268
    Sensor For Anti Theft Alarm System:
    Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
    Component: Sensor, DWA 005 0315
    Serial number: 000000000ZY1402118TT
    Alarm horn:
    Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
    Component: Sirene, DWA 004 0311
    Serial number: 00000000000029276776
    Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
    Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
    Component: PARKHILFE 4K H09 0033
    Revision: -------- Serial number: 60831409101679
    Coding: 0000040001
    ASAM Dataset: EV_EPHVA14AU3700000 002018
    ROD: EV_EPHVA14AU3700000_002_VW37.rod
    VCID: 38292A1BA2D60C8BABB-806C
    Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
    Component: AirbagVW20 011 0361
    Serial number: 003M2R05ZAR2
    Coding: 98CCC0000C0000005C5400CA00C800000065
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
    ROD: EV_AirbaVW20SMEVW37X_VW48.rod
    VCID: 4BC365D7C3409713F69-801E
    Side Sensor Driver Front:
    Subsystem 1 - Part No SW: ----------- HW: 480 002 003 14
    Component: SideSensor_Df 001 0887
    Serial number: 35767000000647304F0O
    Coding: 2D2D2D
    Side Sensor Passenger Front:
    Subsystem 2 - Part No SW: ----------- HW: 480 002 003 14
    Component: SideSensor_Pf 001 0887
    Serial number: 35867000000747304F0Q
    Coding: 2D2D2D
    Side Sensor Driver Rear:
    Subsystem 3 - Part No SW: ----------- HW: 480 401 903 14
    Component: SideSensor_Dr 001 6149
    Serial number: 3516502A914D3E72E0DQ
    Coding: 2D2D2D
    Side Sensor Passenger Rear:
    Subsystem 4 - Part No SW: ----------- HW: 480 401 903 14
    Component: SideSensor_Pr 001 6149
    Serial number: 3526502BF142B1B2E27I
    Coding: 2D2D2D
    Front Sensor Driver:
    Subsystem 5 - Part No SW: ----------- HW: 480 400 602 14
    Component: FrontSensor_D 001 6149
    Serial number: 3556502B712AB1B3D32F
    Coding: 2D2D2D
    Pedestrian Protection Driver:
    Subsystem 6 - Part No SW: ----------- HW: 480 401 003 14
    Component: PedP_Sensor_D 001 6149
    Serial number: 2286502BB14D3E75932M
    Coding: 2D2D2D
    Pedestrian Protection Passenger:
    Subsystem 7 - Part No SW: ----------- HW: 480 401 003 14
    Component: PedP_Sensor_P 001 6149
    Serial number: 2296502BB14D3E75412G
    Coding: 2D2D2D
    Pedestrian Protection Center:
    Subsystem 8 - Part No SW: ----------- HW: 480 401 003 14
    Component: PedP_Sensor_C 001 6149
    Serial number: 23065029F14D3E72B15H
    Coding: 2D2D2D
    1 Fault Found:
    9451537 - Igniter 1 for pedestrian protection
    B1038 11 [137] - Short to Ground
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 108113 km
    Date: 2020.06.05
    Time: 20:13:03
    Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
    Part No SW: 8V0 953 521 BP HW: 5Q0 953 549 C
    Component: Lenks. Modul 002 0110
    Revision: -------- Serial number: 27031408491203
    Coding: A408
    ASAM Dataset: EV_SMLSKLOMQB 017001
    ROD: EV_SMLSKLOMQB_009_AU37.rod
    VCID: 094F9FDF89BCC503045-805C
    Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
    Part No SW: 8V0 920 970 N HW: 8V0 920 970 N
    Component: KOMBI H03 2220
    Coding: 27A40A002A8046000100A800100000
    ASAM Dataset: EV_DashBoardVDDMQBAB 008031
    ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
    VCID: 47CB59E7DF287373D21-8012
    Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
    Component: GW MQB High 125 1164
    Revision: -------- Serial number: 0001756239
    Coding: 030100040B0876005B000248080B0000000100000000000000 0000000000
    ASAM Dataset: EV_GatewLear 010015
    ROD: EV_GatewLear_010.rod
    VCID: 3FDB410787F83BB36A1-806A
    Alternator:
    Multi Function Steering Wheel Control Module:
    Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
    Component: E221 - MFL H02 0014
    Serial number: 15 03 2014 A0177455
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
    Component: J367-BDMHella H03 8043
    Serial number: 9791302903
    Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
    Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
    Component: TSG FS 020 0025
    Serial number: 22031401100362
    Coding: 00108E204001040000001002
    ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
    ROD: EV_DCUDriveSideEWMAXCONT.rod
    VCID: 40D942FBFA06444B13B-8014
    Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
    Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
    Component: EPS_MQB_ZFLS 122 1043
    Coding: 8103
    ASAM Dataset: EV_SteerAssisMQB 010031
    ROD: EV_SteerAssisMQB_010.rod
    VCID: 41DF47FFF10C4D431C5-8014
    Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
    Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
    Component: TSG BFS 020 0025
    Serial number: 23031401100322
    Coding: 001086204001040000001002
    ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
    ROD: EV_DCUPasseSideEWMAXCONT.rod
    Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
    Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
    Component: LWR-ECU 005 0080
    Revision: -------- Serial number: --------------
    Coding: 018E000001000000
    ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
    ROD: EV_HeadlRegulVWLWRMQB.rod
    VCID: 75B7E32FF544B1E370D-8020
    Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
    Part No SW: 8V0 035 874 B HW: 8V0 035 874 B
    Component: MU-S-ND-ER 040 0420
    Serial number: A7F02703142705
    Coding: 01730301FF00000021111101000A00002F0001460100010006
    ASAM Dataset: EV_MUStd4CPASE 002018
    ROD: EV_MUStd4CPASE_VW37.rod
    VCID: 3B23351793E02793469-806E
    Display unit 1 for multimedia system:
    Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
    Component: DU Std H49 0013
    Serial number: AUZ8Z9EY302ATW
    Multimedia Operating Unit:
    Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
    Component: ControlUnit_B H33 0037
    Serial number: C1000007031400030362
    Address BB: Door Rear Drv (J388) Labels:* None
    Part No SW: 5Q0 959 595 B HW: 5Q0 959 595 B
    Component: TSG HFS 020 0025
    Serial number: 20031402090233
    Coding: 000086204001040000001002
    ASAM Dataset: EV_DCURearDriveMAXKLO 006003
    ROD: EV_DCURearDriveMAXCONT.rod
    VCID: 42DD48F3F40A565B05F-8016
    Address BC: Door Rear Pass (J389) Labels:* None
    Component: TSG HBFS 020 0025
    Serial number: 20031406070232
    ASAM Dataset: EV_DCURearPasseMAXKLO 006003
    ROD: EV_DCURearPasseMAXCONT.rod
    End----------(Elapsed Time: 01:17, VBatt start/end: 12.1V/12.1V)------
    Dec 25 2004
    Earth
    The code spells it out:
    1 Fault Found:
    The igniter 1 for pedsetrian protection is at fault. Might be bad...not connected...bad wire...
    Also what ever shop did the work...the car should be returned to them to fix!
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Dec 25 2004
    Earth
