To give you a background on the car, I got it about 6 years ago in a trade, sight unseen with 180K. I had no experience with B5's or Audis other than having wanted one since they came out. I got lucky in what I received. I traded an old, but very cool WWII Ford Jeep that I was having trouble getting a title for the car. Its a 99 Prefacelift care (late 98 build), 1.8T TIP, sport package, cold Weather package, and was in pretty good shape. Ultimately, I needed something I could get my old german shepherd into easier than a lifted jeep for occasional trips to the park or vet. The car drove well but would buck and act funny. I swore it had transmission issues and was slipping among other things. This was my first turbo vehicle so that took some getting used to. It turns out the pancake valve, pcv valve, n75, etc were all bad. Several vacuum leaks. I started going through the car and repairing the things that were failing or were likely to fail. I also learned that working on the car meant breaking some unrelated piece of plastic that you have to order a replacement for. So I slowly replaced all the plastic hoses with silicone, 2.0 coil upgrades, silicone tip, etc. The basics. I had a stage 1 tune on it and it was fun to drive, but the tune wasnt right, it was lean a lot. I found a small port gasket in my large port intake manifold and some other oddities that showed that the head had been off. I had replaced and upgraded almost everything on the outside of the engine, before something went wrong on the inside. I also went through 3 MAFs before finally getting one that ran right.
