Hello all,
a6 PP 2013
2 L TFSI
I used to get this code intermittently. today when I went to a place and after my stop, I was having a hard time starting the car. The car did not start right away, but it did after 5/6 cranks (a little longer than usual).
Checked the code and found P0016. But if I clear the code (with ACC on mode) and then the car starts right away like normal and then code come back. What I notice there are no other codes but feels less power in the motor and little noisier.
CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 00 [175] - Incorrect Correlation
Also checked camshaft phase adaptation found wired degrees, people are talking 5 degrees is bad but I got -26.94. It has 120,000 miles, always runs great. I swapped the Cam position sensor but no luck. Just ordered a crankshaft position sensor.
Any response appreciated, thankyou.
[IMG]C:\Users\mainudding\Downloads\Capture.PNG[/IMG]
1 Fault Found:
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 199241 km
Date: 2020.05.30
Time: 22:28:27
Engine speed: 1033.50 /min
Normed load value: 13.7 %
Vehicle speed: 16 km/h
Coolant temperature: 72 °C
