Results 1 to 26 of 26
    Veteran Member Three Rings Cyrik's Avatar
    Oct 03 2017
    2007 Audi A4 2.0T Quattro
    Abnormal amount of oil coming from throttle body hose... replace or upgrade?
    Hey guys,
    In the last couple months or so I've noticed quite a bit of oil buildup coming from where the N̶7̶5̶ SMIC meets the throttle body hose, it's sending oil all over the frame all the way down to the sway bar bracket... Figured that's probably not a good thing :( This issue has gone for probably about 6 months or so but hasn't been as bad until now, I know it's normal to have a bit of oil in your charge pipes but AFAIK it's not supposed to get your engine bay all dirty lol.
    I think it's mainly to do with my piping "peeling" where the clamps hold down the pipes (I'll post a pic soon for those who don't understand) but after years of having oil in my charge pipes my tubing has become really squishy and totally saturated with oil. Figured it's probably time to get around to fixing it even though I know it isn't a serious issue (I don't think I have boost leaks).
    Anyways, I found a pipe kit from 034Motorsport for the stock SMIC's for ~$250, could I get some opinions on just biting the bullet and going with a ~$500ish FMIC kit? (thinking CXracing) I feel like if I'm going to spend that kind of money on pipes I might as well upgrade. Car is also going Stage 1 as soon as JHM emails me back :)
    '07 A4 2.0TQ Tip: JHM Stage 2 Tune, 18" Sparco wheels, CTS Turbo 3" HFC w/ 2.5 - 3" custom exhaust, ECS Luft-Technik IC w/ custom AEM intake, GFB DV+, 034 control arms/tie-rods/strut mounts/engine mounts, ECS snub mount, Bilstein B4 shocks, BrakePerformance D/S rotors and have replaced LITERALLY EVERYTHING ELSE.
    Feb 15 2016
    Cambridge,Ontario
    Wouldn't it make sense if there is oil on the outside you would have an intake leak?
    Anyway mine was caked when I pulled my engine.
    Cleaned it tightened clamps moved on.
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    If you oil is being consumed check valve cover for cracks
    1976 Yamaha XS 360
    Oct 03 2017
    Replaced PCV and valve cover about a year and a half ago, when I swapped engines 3 months ago I checked the valve cover and it isn't cracked. Turbo inlet tube was replaced 6 months ago (surprisingly reduced my oil consumption a lot) and turbo was also replaced about 2 years ago. Oil is under halfway on the dipstick and I've been on the same oil for 2500 miles. Think it's safe to say I can rule these out. The oil is a thin thin layer on the driver-side of my engine bay, I don't think it's a lot but it's spread out and it annoys me.
    Not really sure what you mean here, are you talking about the intake manifold or the intake to the turbo? How would that cause oil being sent through the charge pipes?
    Oct 03 2017
    Also my mistake! NOT the N75 forgot it's under the turbo lol. It's leaking from the opposite end where the throttle body hose meets the driver-side SMIC.
    May 15 2019
    2007 Mercedes C230 Sport, 2006 Chrsler Serbring, 2006 Volvo S60 2.5T, 2006 A4 Quattro 2.0T
    Bellevue, WA
    Quote Originally Posted by Cyrik View Post
    do know where the oil is coming from( intake manifold or from IC)? are the other charge pipes are full of oil too?
    Oct 03 2017
    Driver's side, looking up, it's coming from above, hard to get a better angle on the ground:
    Here's the peeling:
    May 15 2019
    Bellevue, WA
    Here's the peeling:
    this hardly gives any clues. Try to get under the car and get more pictures. it could be anything from valve cover gaskets, oil cooler, Oil dipstick, power steering lines etc etc
    May 15 2019
    Bellevue, WA
    Quote Originally Posted by Jeevan View Post
    this hardly gives any clues. Try to get under the car and get more pictures. it could be anything from valve cover gaskets, oil cooler, cam plugs and seals, Oil dipstick, power steering lines etc etc
    May 15 2019
    Bellevue, WA
    if I were you I would degrease the engine at the bottom and pressure wash it first then wait for few days
    Oct 03 2017
    Will do, It's dark right now I'll post a better pic tomorrow 👍
    Oct 03 2017
    Here ya go
    And yes, all the clamps are tight.
    Feb 15 2016
    Cambridge,Ontario
    I'd still say clean it up and watch it..make sure oil isnt spraying from somewhere else. There are two.oil.lines in front of the engine Mount towards the front of the car that were spraying on mine. Oil lines were loose.
    1976 Yamaha XS 360
    Oct 03 2017
    I cleaned it earlier today so I'll double check the lines when I can, doing my front struts later this week so I'll see if I can get a better look at it.
    Aug 17 2015
    California
    Can anyone explain how a turbo inlet tube can reduce oil consumption?
    Oct 03 2017
    Quote Originally Posted by A4x View Post
    It's part of the PCV system and the one on my car has a check valve in it, some model years don't have a check valve. The one I had was bad since I was able to blow air through it either direction. As far as oil consumption goes idk. Thought it was worth mentioning I guess.
    Sent from my Pixel 3a using Audizine mobile app
    Oct 03 2017
    Update: It is 100% without question coming from my throttle body hose. Drove 60 miles since cleaning and checked it out a few mins ago. It was BONE DRY just last night. Oil/Power Steering lines next to this area is also dry.
    So I'll ask again, upgrade to a FMIC or just buy 034's charge pipe kit?
    Feb 15 2016
    Cambridge,Ontario
    crank it tighter ... lol
    1976 Yamaha XS 360
    Oct 03 2017
    Not trying to totally split a pipe today
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    I bought the 034 hoses when they were on sale, half price last fall. They are very good quality, I can tell ya that much. Rest is your choice.. But some cheap fmic's will actually be less efficient than stock. Not sure about cxracing.0317201354.jpeg0317201354a.jpeg
    Sent from my LM-G710VM using Audizine mobile app
    Oct 03 2017
    Quote Originally Posted by Jayz691 View Post
    Very cool! If they were on sale I would jump on them. I always thought a fmic has less restriction since the pipes are a shorter distance from turbo to throttle body?
    Jan 21 2018
    frackville, pa US
    I don't know how much shorter they are. A quality one will absolutely be more efficient, but not needed for a stage 1 tune. One thing that will help is pulling IC's off and giving a good clean. If your dripping oil, they're completely coated inside. CTS hoses are $180 for the set, and prob just as good. I just went 034 cuz they were $118, so I grabbed them.
    Account Terminated Two Rings
    Apr 29 2020
    Spokane
    anything with the name CTS is Junk
    Oct 03 2017
    Good to know, thank for the info! 😁
    Quote Originally Posted by hammond View Post
    I always got the impression that CTS turbos were really solid...
    Jan 21 2018
    frackville, pa US
    I was always under same impression, far as people experience with their stuff.
    Veteran Member Three Rings MALMGRDC's Avatar
    Dec 22 2016
    Colorado
    Please go on hammond, you have caught my attention...
    2001 S4 BEL 2.7t 6M
    - SEP RS6 turbos - Motoza E85 tune - SEP BiPipe - PB5 inlets - XS Power SMICs - 034 DVs - XSPower turbo back exhaust - JHM Clutch/Shifter - 034 fuel pump - Bosch 750cc - R888Rs on V710s - 12.5@117MPH 1.9 60' (fouled plugs, 5700ft DA )
