Results 1 to 31 of 31
    Stage 2 Banner Advertiser Three Rings Brian@Unitronic's Avatar
    Jan 11 2019
    PA
    Saxon 2018 TTRS build thread
    I have gotten quite a few questions from customers about my car, so I figured I'd create a build thread here that I can update easily.
    2018 TTRS
    Fall 2019
    I bought the car in Texas with a full stage 2 package from a competitor and drove the car 20+ hours home
    I then installed Carbon Ceramics on the car, since I wont be tracking the car the Ceramics are very light which work great for drag racing
    I then installed a set of 17" slicks and ran a 9.989 @ 135.84
    NO WEIGHT REDUCTION besides wheels/tires
    mods:
    Unitronic stage 2 ecu (10psi , 3800 rpm launch)
    Unitronic stage 2 tcu
    Unitronic injectors
    4" intake
    4"inlet
    catless downpipe
    upgraded fmic
    (all parts from previous owner)
    Since I met my goal with the car it was time to transfer over my built motor setup from my RS3
    Current setup:
    (Eurocode setup)
    Carrillo Rods
    Mahle Pistons (standard version)
    Ferrea Springs/retainers/valves
    Iroz Engine oil Catch can
    Unitronic Port injectors
    Unitronic 4 bar Map sensors
    Wavetrac front lsd
    Stock clutches
    Iroz DSG catch can
    Iroz Motorsports 850s Full Frame kit (Xona 8264s)
    Iroz 4.5" inlet
    Unitronic 4" intake
    STM 1000hp core FMIC (needs serious mods to fit a ttrs)
    Iroz LPFP
    KW HAS with 80-180 rear springs
    034 street mounts
    Ece blue dog bone mount
    034 rear inserts
    18x9 Volk te37 with 285/35/18 Nitto 555R tires
    Stock exhaust
    Current results from testing (local track isnt open yet, not all are from same pass)
    Rear seats taken out and lightweight battery installed , still has stock exhaust
    0-60 2.3 seconds
    60-130 4.37
    1/4 mile - 9.34 @154mph
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Established Member Two Rings cantcatchtomm's Avatar
    Jul 31 2017
    Portland, OR
    Awesome car and excellent results Brian. Love the wheel/tire setup too. 80lb Rear HAS or 800lb?
    Jan 11 2019
    PA
    Quote Originally Posted by cantcatchtomm View Post
    Oops thanks for catching that, it's their 80-180 spring which is around 450lbs
    Jul 31 2017
    Portland, OR
    Quote Originally Posted by Brian@Unitronic View Post
    Thanks for the info. I’m running 900# in the rear for cornering and the setup definitely hasn’t helped it hook off the line when launching. Are you using stock dogbone, inserts, engine, and trans mounts?
    Jan 11 2019
    PA
    Forgot about those as well, I've spent way too much money ha ha
    034 street mounts
    034 rear inserts
    Jul 16 2013
    Ho
    Beast!!!
    2018 TTRS (Nardo Gray)
    Previous:
    2018 TTS (Daytona Gray Pearl / Express Red)
    2008 TT MKII 2.0T DSG (Ocean Blue Pearl)
    Nov 03 2014
    BMW i3, Golf 1.4T, TT RS 8S
    Mexico
    Congrats in such an amazing setup!
    Regarding to the KW HAS springs, do you have a link to them?
    For a TTE 700 or TTE 777 would you recommend an engine built? Thanks!
    Jan 11 2019
    PA
    New updated time with video
    Jan 11 2019
    PA
    Quote Originally Posted by BeTTo RS View Post
    I dont have a link to them, however if you search that part number you will find them.
    I recommend building a motor for any hybrid build as it gives you peace of mind as well as will allow you to turn up the turbo to maximize the torque
    Senior Member Three Rings VancityAudi's Avatar
    Feb 14 2019
    Surrey/BC/Canada
    It is truly amazing what you've done with that car. I REALLY look forward to seeing you put that power to use on a track once they open! Just amazing bud.
    Nov 03 2014
    Mexico
    Thank you very much for your advise and support!
    Jan 24 2013
    In for TTRS sexy time.
    Email: [email protected]
    Call or Text: 914-243-1993
    Jan 11 2019
    PA
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    ^^ In my opinion one of the most shocking aspects of your car build is that you are running a stock drivetrain(untouched transmission, driveshaft, axles), it is just crazy how strong the DQ500 seems to be, I only seen a picture of the broken flywheel that Iroz posted but I think he was pushing more power.
    As far is your overall build, I think your car will be forever a YouTube sensation specially with that clean low 2's 0-60 mph launches.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Nov 03 2014
    Mexico
    Hi Brian,
    Are the Ceramic brakes’ Calipers the same as the steel’s ones?
    Are you glad with your ECE pendulum mount? Why did you opt for this one vs. the other options in the Market?
    Amazing build, congratulations!
    Veteran Member Three Rings Chuckster's Avatar
    Feb 18 2017
    Socal
    I saw the TRC video over the weekend. Threw it up on the tv with surround sound too!
    2017 Audi TTS | Sold |
    2019 Audi Q7 | Baby seats |
    Junior Member Two Rings riden's Avatar
    Aug 26 2020
    Germany
    What a nice car!
    How are the Mahle pistons vs oem? Do you have more oil consumption?
    Jan 11 2019
    PA
    Hi Brian,
    They are the same physical dimensions but the pistons/boots are a different material.
    ECE mount is great, I chose this as i bent every other mount that was available at the time.
    Quote Originally Posted by riden View Post
    What a nice car!
    They work well, with my engine catch can I have yet to drain any oil from the engine. I still go through about 1 qt every 5000 miles or so.
    Nov 03 2014
    Mexico
    Thank you so much!
    Aug 26 2020
    Germany
    Thank you so much!
    @BeTTo Rs
    do you have Steel or Ceramic? Do you want to change the caliper?
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    a bunch of tools
    Monument, CO
    So then it would be possible to change pads pistons and boots if one were to pick up the ceramic rotors?
    2023 Q7 - Ibis White
    2024 SQ8 - Chili Red
    So many have come and gone…
    Nov 03 2014
    Mexico
    @BeTTo Rs
    Hi Riden,
    I have ceramics and I love them. A friend on mine and I where discussing about this since I read somewhere that they where the same (I believed that the only thing that changed where the pads) and the thing I don’t recall is the source I read this from. On the other hand my friend told me “Ceramic brakes might have bigger calipers”. So I thought that the best way to find out was to ask.
    I would loved that the rear brakes where ceramic as well. I know that these car’s heavy on the front end, so the most important brakes in this case are the ones in the front axle. Even though I would like to have them.
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Hi Riden,
    I had ceramics on my last TTRS and I loved them. That is a package I wish my new TTRS had. I want to retrofit carbon ceramics onto this one.
    Aug 26 2020
    Germany
    You can also save a lot of weight at the Front by using an other caliper. (I use a AP 5000R which is almost 3kg lighter each) On the other hand it will upgrade the brake performance and friendliness to the disc at the same time by using the right pad vom Pagid. If you are interested in that I have a nice contact
    For the front and rear we are developing exactly what you/me and others want at the moment. It will be ready hopefully this year - a upgrade front and rear ceramic disc kit for maximising brake performance and saving rotating/overall weight. And all that for a fair price.
    I will show it on my Instagram when it is ready ore here in a separate threat if you want.
    Nov 03 2014
    Mexico
    That’ll be amazing! Subscribed for it!
    It’s funny I saw the Akrapovic install video You posted a few weeks before seeing you posting around here. The video is amazing even I don’t understand a thing (a couple of random words here and there).
    Jul 19 2018
    Sky
    Any issues with 285s on the 9 inch rims? I'm currently on 265/35/18 RE71Rs and would love to move up to 285s if there are no issues. I know you have aftermarket suspension. I'm currently on 034 Springs and fixed camber top mounts, which give me -2.7 degrees up front. You think I could get away with 285s?
    Veteran Member Three Rings Trent212's Avatar
    Sep 10 2015
    AL
    Quote Originally Posted by Cloud IX View Post
    285s are a tight fit on 9in wide stuff, but they work.
    2018 TT RS - Nogaro Blue | CF Inlays | Black Optic | Design Selection Interior | Red Calipers | Technology Package
    APR E85, Intercooler, Inlet, And intake
    TVS Stage 3 TCU tune
    SRM TB Inlet
    SRM GTX3582
    SRM/Eurocode fuel system
    Nov 03 2014
    Mexico
    Quote Originally Posted by Trent212 View Post
    That’s what I thought!
    Jul 19 2018
    Sky
    Let me rephrase my question. Is it ok to run 285s on a 9 inch rims going all out on the track?
    Sep 10 2015
    AL
    Depends on the tire really, and is a 285 vs a 275 going to make or break your day? Because most 275s are cheaper and fit better.
    Keep it close to stock tire diameter and you should be good. Tire compound is an important thing to keep in mind also.
    Active Member Two Rings JimPotts's Avatar
    Mar 04 2020
    1996 Dodge Viper GTS
    Weston
    What are the specs for the 17" rims you run the slicks on??
