I started my 2013 S7 a couple of weeks ago and was greeted with a multitude of error messages: TPMS, ABS, Sport Differential, Parking Brake, Air Suspension, and Cruise Control. The code reader confirmed "ABS Wheel Speed sensor Open circuit/short circuit to ground" as the primary cause. Open/short-to-ground usually means a harness problem, but I decided to try a new sensor - even though the old sensor tested OK with my multi-meter (5.7 k-Ohms if I recall.). The new sensor had the same resistance...and didn't fix the problem. Not an easy fix. Must be the harness.
I next removed the right front wheel liner and started to trace the harness back. The ABS wheel speed sensor has unique plastic-coated wires with rubber grommets that fasten to the suspension at various points. That ABS Sensor harness merged with other harnesses, which merged with other harnesses. All of them are covered with fabric tape. I never found a connector to disconnect the ABS Wheel Speed Harness from the main harness. This is where I'm stuck. Here's a picture of where the ABS wheel speed harness joins with the other harnesses:
Does anyone know the official harness repair procedure? My guess is that I need to continue unwrapping the fabric tape until the ABS Sensor Wiring changes from plastic coated to standard wire. Then cut the 2-wires for the ABS wheel speed sensor there. Then splice in (solder / heat shrink) the new replacement harness. Then re-wrap the entire harness assembly with fabric tape. Does anyone know if this is the correct procedure? Am I missing something? Here's a picture of the replacement service harness from an eBay listing (I haven't ordered one yet):
