THE Tuner manifold has RS6 TB option, also to note, the grind marks are from me being obsessive and smoothing out some of the casting, it comes very nice as is.
RS4 is paired with a Porsche TB, cheaper and easier to get.
Throttle Body Diameter, Area
THE Tuner 82mm, 5281mm2, +11% RS4, +21% S4 Late
RS4 74mm, 4301mm2, +9% S4 Late
S4 Late 68mm, 3632mm2
Entry Diameter, Area
THE Tuner 51mm, 2043mm2, +63% RS4, +101% S4 Late
RS4 40mm, 1257mm2, +23% S4 Late
S4 Late 36mm, 1018mm2
Outlet HeightxWidth, Area
THE Tuner 30x58mm, 1547mm2, +16% RS4, +54% S4 Late
RS4 27x55mm, 1329mm2, +32% S4 Late
S4 Late 27x43mm, 1005mm2
Throttle Body - plate diameter, measured at the plate/shaft
Entry - runner entry, measured inside the plenum at the velocity stacks, when you remove the bottom panel you can see them.
Outlet - runner outlet, height and width of the port that connects to the head
Left to Right, Top to Bottom
THE Tuner, OE RS4, OE S4 Late Model
