Results 1 to 13 of 13
    Veteran Member Three Rings TheDude420's Avatar
    Mar 07 2018
    S3
    Florida
    How do I clean this rust in the wheel area?
    I've had this rust ever since I bought the car from the owner in the wheel area and I don't know how to clean it. I now have black Neuspeed RSE102's and the rust stands out even more than on the OEM wheels seen in the picture because the gaps are wider in between the spokes now:
    2016 S3 P+, Tech Pack, Black Optics, Super Sport Seats, Mag-Ride, Facelift-Style Headlights, APR Stage 2 High Torque & DSG Tune, Carbon fiber Intake, Intercooler, RS3 Coils, RS7 Spark Plugs, Boost Hose System w/Bypass Hose, Catch Can, AWE Downpipe, AWE Switchpath Exhaust, 034 Motorsport Dynamic Lowering Springs, RSB End Links, Neuspeed RSE102, Dogbone Mount Insert, Neuspeed Rear Sway Bar, EMD Carbon Fiber Diffuser, Carbon Fiber Spoiler, Milltek Cerakote Black GT-100 Exhaust Tips
    Veteran Member Three Rings TheMysticWizard's Avatar
    Aug 15 2016
    '14 MINI Cooper (F56 B38)
    East Bay, CA USA
    Buy new rotors with coated hubs
    Mar 07 2018
    S3
    Florida
    Quote Originally Posted by TheMysticWizard View Post
    Do you have any recommendations? I don't know really know what to look for. I found these:
    https://www.ecstuning.com/b-ecs-part...928ecs01-02kt/
    Veteran Member Four Rings EvoToSQ5's Avatar
    Aug 09 2018
    2017 Audi SQ5
    Leominster, MA
    Take the rotors off and spray them with a high temp coating on the hub.
    Junior Member Two Rings pauloi's Avatar
    Apr 04 2020
    Northern Virginia
    Quote Originally Posted by EvoToSQ5 View Post
    This^ after hitting them with some steel wool.
    2016 A3, Tech Package, Black Optics, IS38, APR Stage 3 High Output ECU tune, APR IS38 DSG tune, CTS Turbo Inlet, 034 X34 Carbon fiber intake, Mishimoto Intercooler, APR Catted Downpipe, APR Midpipe, Audi S3 diffuser/exhaust with Milltek exhaust tips, Stainless Steel Brake Lines, EBC Red Pads, Neuspeed RSE102s, Airlift Performance 3P, CTS dogbone mount, ECS Carbon Spoiler, RS3 Grille, ECS Carbon Engine Cover, Metal Oil Pan, Spulen spacers, S3 Steering Wheel
    Apr 03 2020
    FL
    I’d buy new brake rotors instead of DIY paint. Cleaning it out is temporary fix and rust will come back. You don’t have to spend $1000 if you are just looking for better looking rotators. You can hit eBay and buy black coated rotors for less than $200 to match your spacers. You can also check out R1 rotors that offer black and grey costed rotors with two different types of coating, zinc and geomet. StopTech offers rotors with black coated hubs if you are looking for a better quality part and name brand.
    Jan 02 2017
    Lanc PA USA
    When I clean my car, I always hit the wheels with some gyeon iron remover
    https://clean-garage.com/gyeon-q2m-i...SABEgIOy_D_BwE
    I also spray the hubs generously,
    this helps break down the rust somewhat, then you can give it a good scrubbing and they turn out looking pretty good.
    Of course it will come back if you don’t keep up on it.. but I’m surprised, especially after going through the winter months when I don’t hand clean my car.. it can build up quite fast.
    Hope this helps👍
    Dec 25 2004
    Earth
    Anodized aluminum hat rotors
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Established Member Two Rings AlexQS's Avatar
    Jan 10 2020
    Pacific NW, USA
    Wire brush. I’d try brass brush first, less likely to scratch. Steel brush may work, but be gentle. Then paint. Rustoleum makes a flat-black high temp paint,... painted my bbq with it once. Held up well for a couple years.
    If looking for performance gains, ECS has a two-piece rotor which is a number of pounds less weight than factory rotors. Spendy though.
    AlexQS
    2015 Audi A3 2.0T quattro Premium
    2014 VW Passat TSI Wolfsburg
    AlexQS
    2014 Volkswagen Passat TSI Wolfsburg
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Zimmerman Z-coated discs
    Quote Originally Posted by TheDude420 View Post
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Mar 07 2018
    S3
    Florida
    Thanks everyone for the info. Now I have to decide if I want to clean and paint the rotor hubs but have the paint chip and hub rust in time or buy new black coated rotor hubs that won't rust. The later is much more expensive though. I'm thinking about the ECS rotor hubs I linked to because they are lightweight and I already have lightweight wheels so the weight reduction and handling will be even better.
    Aug 09 2018
    2017 Audi SQ5
    Leominster, MA
    Can’t go wrong with a few hours and $20 to paint the hubs. Just make sure you keep all the brake components on the same sides they’re currently installed on.
    Apr 10 2019
    My experience on OEM hubs. Sand the rust to smooth (not bare metal) and brush paint with Tremclad Rustoleum flat primer which matches the original color fairly well. I did it at seasonal tire change and it took less than 30 min. and has now held up for 2-1/2 years. I am not adverse to repeating at the interval. I should note that I live in a fairly dry climate where salt is not used often. The original rust came with the 2 year old car from the Canadian Pacific coast.
    It seems people are quite happy to spend your (big) money if you follow their advice but I don't see reports of actual experience.
