I’m coming up on 75k miles. The Sunset-Audi Tech who had inspected my car agreed that I’m probably on 2nd set of pads on front with original rotors, and probably first set of pads in rear.
On my upcoming brake job I’ll need to replace rotors for sure on front, but rear rotors can probably just be turned.
On a past vehicle, I really liked the Akebono Euro Ceramic pads. Of course low dust and noise, and they seemed to be really kind to rotors. Some folks complained they didn’t have as much initial bite as stock Mini Cooper (BMW) pads, but I thought they were fine. They had no problem with applying enough torque/friction to engage ABS, even from highway speeds on a dead cold morning. And after they get just a little bit of heat in them, they will slow the car with less pedal effort, and remain very predictable, even in hot days with repeated hard braking.
I also felt it was easier to modulate brakes as they were so linear and I like having that level of control.
On a spirited drive, it was easy to predict exactly how much pressure on the pedal will be needed to brake as hard as possible without engaging ABS.
On my Porsche, I went with OEM (Textar), as I wanted to try that awesome initial bite everyone talks about. It was very awesome, but also very abrupt. I didn’t care for it as much. Being *smooth* is the name of the game, right? Also more than once I found myself getting into ABS area when I didn’t mean to. I think maybe the Textar pads friction coefficient changed increasingly with temp changes?
At any rate, I’m an akebono fan, but can’t seem to find them for A3 8v
Are the x23 people talk about comparable? Easy on rotors, very linear and predictable in bite?
I’ve considered RedStuff too, but from what I’ve read, they need a little more heat for a cold bite. I’m way out in the country, often driving for a long period of time without ever touching the brake pedal. I worry with RedStuff I could be going 80 MPH on a 35^F morning and encounter a deer, and just simply not have enough cold bite to get the job done. This was not a concern with Akebono though.
Sorry, just kinda spitballing here as I consider options for brakes, and interpret your experiences with your fav pads. Either way, I’m strongly considering the Porsche Macan Caliper upgrade. If I go for the 2 piece floating rotors, I will for sure want a pad that’s gentle on rotors. I think we all know it’s tires that will make the most difference in reducing stopping distances, so for a street brake pad I just want something that has a decent cold bite, linear and predictable feel, and take enough heat to handle repeated hard braking on canyon runs without fade.
AlexQS
2015 Audi A3 2.0T quattro Premium
2014 VW Passat TSI Wolfsburg
