Results 1 to 6 of 6
    May 16 2013
    Michigan
    Help for 2018 Audi S5 Prestige. How to tell if has Full Matrix LED headlights?
    Like title says. In North America/USA, how do you tell if the 2018 S5 SB Prestige has the Matrix LED headlights? Is it standard for Prestige trim?
    Established Member Two Rings BrainDr's Avatar
    Jan 03 2019
    Midwest
    On the 2019 it is standard for prestige. As far as how to tell, I'm not sure.
    Sent from my SM-N975U using Tapatalk
    2019 Audi S5 SB Prestige BO
    Feb 08 2019
    Houston, TX
    Matrix LED lights are not available in the US for 2018 or 2019 on A/S/RS5 - they are just regular LED lights. You have to retrofit some (very expensive) E-codes to get matrix functionality in the B9 in the US.
    2019 RS5 Sportback / Misano Red /Black+Crescendo Red
    Veteran Member Four Rings pwdrskr's Avatar
    Aug 21 2010
    Carlsbad, CA
    Quote Originally Posted by MR_RS5_SB View Post
    This. I know as I just did this switch. Unless you are buying from a private seller who expressly tells you he/she converted to matrix headlights, then you have LED lights. Not only are they expensive, converting to matrix requires significant coding changes to get them to work properly and avoid getting fog and high beam errors.
    '19RS5 Coupe: Prestige, Daytona Grey, Blk Interior, Carbon Pkg, Driver Pkgs, APR+/TCU/Intake, CETE AVC, ABT Coils, Vossen EVO-1R 20x10et20
    '22RS6: Glacier White, Blk/Gray Interior, Blk Optics, Exec, Driver Pkgs, Sport Exhaust, APR+, Akrapovič Exhaust, CETE AVC/ASC, Vossen GNS-1 22x10.5 et7, Stealth wrapped Piano Black Interior
    Veteran Member Four Rings SHCKR's Avatar
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Unless something had changed, Matrix LED technology is illegal in the U.S. (DOT mandates that low and high beams must be separate lights/bulbs). So, 2018's didn't have them yet, it's a 2019+ release, however the matrix lights that come on those models don't actually come with matrix functionality. That's why Audi website says matrix-design headlights, not matrix technology headlights.
    '18 S4 Prestige; all packages
    Feb 08 2019
    Houston, TX
    For the B9 line in the US, I don't think even the 2019 models have matrix functionality (even if disabled by software). I believe only the B9.5 face lift have the matrix design and that's the 2020 model.
