Anybody running an 18-inch wheel with a minimum width spacer that allows 18-inch wheel clearance with the front caliper, as well as not allowing the tire edge to hit the fender edge during full lock turns? Is there such a configuration?
I've had it with the 19-inch tires and want the 18-inch tires with their additional sidewall to help eliminate some of the bad roads situation and reduce the surface noise level.
-Rod
