Results 1 to 3 of 3
    Junior Member Two Rings fredsta's Avatar
    Jan 28 2020
    london UK
    Fault code: U111300 - no air con
    Hi all, I recently bought an A7 but the air con was not working. I since went to get the air con regassed and the mechanic said that I have an error code of U111300.
    Has this happened to anyone else or know if this is a common error for the A7?
    Sent from a phone, because you needed to know that.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    You'd need a full scan with details to get any real help.
    It is basically like saying something is wrong, or idiot light is on.....without details it is completely unknown.
    U111300 Function restriction due to faults in other modules
    U111300 - Function limitation due to received malfunction value static
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Jan 28 2020
    london UK
    Ahh ok thanks. I'll get it scanned at a garage.
