Results 1 to 10 of 10
    Veteran Member Three Rings TheDude420's Avatar
    Mar 07 2018
    S3
    Florida
    2016 Audi S3 maintenance at 60k miles (what do I need)?
    I bought my S3 over a year ago at 44k miles and I've reached 60k miles. I need some help figuring out what maintenance I need to have done. I bought the car with APR Stage 2 already on it so if there is something I need to change for it please let me know. This is my first tuned car and I want it to last. The previous owner did the following:
    - Oil change every 5,000 miles with LiquiMoly 5w40 oil change kit from ECStuning with OEM oil filter.
    - DSG service (drain and fill; replace filter) at 35,000 miles with LiquiMoly DSG transmission oil, OEM filter, and OEM drain plug.
    - Spark plug change at 25,000 miles with OEM Audi RS7 plugs.
    - Four wheel balance and alignment done by AWE Tuning in June, 2018.
    - Haldex service (drain and fill; haldex pump screen clean)
    - Water pump replaced with all OEM components at New German Performance.
    I had the following done in July 2019 at around 54k miles:
    Motul oil and filter change
    OEM oil filter and Motul oil
    Check condition of Haldex/DSG trans fluid (was clean)
    April 2020:
    Wheel and tire mount/balance
    Finally, here's what's on my list to get done:
    OEM RS7 spark plugs
    Air intake replacement filter (engine) Is this what I need?: https://www.bmptuning.com/collection...ilter-rf100001 & https://www.bmptuning.com/collection...apr-sai-filter
    Brake fluid (flush/replace)
    Haldex fluid (check)
    2016 S3 P+, Tech Pack, Black Optics, Super Sport Seats, Mag-Ride, Facelift-Style Headlights, APR Stage 2 High Torque & DSG Tune, Carbon fiber Intake, Intercooler, RS3 Coils, RS7 Spark Plugs, Boost Hose System w/Bypass Hose, Catch Can, AWE Downpipe, AWE Switchpath Exhaust, 034 Motorsport Dynamic Lowering Springs, RSB End Links, Neuspeed RSE102, Dogbone Mount Insert, Neuspeed Rear Sway Bar, EMD Carbon Fiber Diffuser, Carbon Fiber Spoiler, Milltek Cerakote Black GT-100 Exhaust Tips
    Mar 07 2018
    S3
    Florida
    BUMP
    Jan 12 2020
    Sounds good so far. Maybe consider getting the intake valves scoped and having a carbon cleaning done if need be.
    Mar 07 2018
    S3
    Florida
    Quote Originally Posted by Ad615 View Post
    Thanks for the advice I'll make sure to have that checked.
    Sent from my SM-G981U1 using Audizine mobile app
    Established Member Two Rings AlexQS's Avatar
    Jan 10 2020
    Pacific NW, USA
    Seems like it’s been well maintained.
    Spark plugs, air filter and brake fluid seems right. And check if needs carbon cleaning.
    I like to run a tank of zero-ethanol-premium through every now and then. I think I read that recommendation in Audi owners manual.
    I’d say also do the cabin air filter, and check/clear any gutter drains. Top off windshield wiper fluid. Check tire pressure too.
    AlexQS
    2015 Audi A3 2.0T quattro Premium
    2014 VW Passat TSI Wolfsburg
    AlexQS
    2014 Volkswagen Passat TSI Wolfsburg
    Mar 07 2018
    S3
    Florida
    Quote Originally Posted by AlexQS View Post
    AlexQS
    Thanks a lot! I forgot to mention I did change the cabin air filter earlier this year but not the engine air filter. Since my S3 has a TPMS I've maintenaned my tire pressure.
    I also keep my windshield wiper fluid level with distilled water to avoid water spots. I've never heard about the zero-ethanol premium but I'll check it out.
    Senior Member Two Rings normcaldwell's Avatar
    Jul 31 2016
    There is a front and rear bevel box; takes gear oil.
    Might be good to drain and fill.
    2016 Audi S3, Misano Red Pearl Effect, Prestige, Black Optic, S Sport Seats.
    United Motorsport, 034 Motorsport, Neuspeed, StopTech, APR, AWE, ECS, IE, Ferodo, Motul, BC Forged, SuperPro, CFS, Carbontastic.
    Aug 02 2019
    Midwest
    I would change the DSG and Haldex fluid either way. Otherwise, I think everyone's suggestions are solid. I too recently changed the cabin air filter and wished I'd done it earlier. Very easy to do.
    I also think it's a good idea to change plugs more freequently when tuned. 25k miles seems good to me. Does anyone @ Stage 2 change them more frequently?
    B7 RS4
    B6 S4
    Junior Member One Ring HmanS3's Avatar
    Sep 29 2018
    '16 S3
    Chicago, IL
    Is the accessory belt on a replacement schedule?
    Jan 10 2020
    Pacific NW, USA
    Quote Originally Posted by HmanS3 View Post
    The 2015 Audi Maintenance Schedule says to do this first at 75k miles, and every 80k miles thereafter:
    Ribbed V-belt: Check and replace if necessary. Check tension of belt drive with a manual tensioner and retention if necessary.
    I’ve bookmarked this page for Reference:
    https://www.audiusa.com/content/dam/...RIL%202018.pdf
    AlexQS
    AlexQS
