Results 1 to 10 of 10
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    DIY Upper control arm bushing replacement with solid "poly" bushings
    Here's my latest video, this time I swap out the bonded rubber, problematic upper control arm bushings with a set of Powerflex "race" bushings into my Stern adjustable upper control arms. I'll a few details for the how to part later.
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
    Established Member Three Rings shortyolsen2017's Avatar
    Jul 31 2019
    2013 Audi S5 Premium Plus stage 3+, and 04 Ranger Edge Tremor
    Denver, Colorado
    One of the better videos I've seen. Looking good..
    Sent from my SM-N960U1 using Tapatalk
    Jun 24 2017
    San Antonio, TX
    Thanks shorty!
    Tool wise, just make sure you have a few 16mm wrenches. Audi always likes to use "unusual" sizes.
    The basic set of tools is as follows:
    -(2) 16mm wrenches, ratcheting version very helpful
    -basic metric socket set but you really don't use it
    -impact driver, mine's a smaller size, 1/4" shank so you don't overpower everything
    -low profile jack
    -jack stands
    -work lights
    -Bushing/bearing press kit https://www.amazon.com/WINTOOLS-Univ...9065300&sr=8-9
    -penetrating fluid
    -Krytox lubricant https://www.amazon.com/Chemours-Kryt...9065239&sr=8-1
    Parts I used...
    OEM nut and bolt kit from ECS Tuning https://www.ecstuning.com/b-genuine-...t/n10425302kt/
    Powerflex "black" bushings, part number PFF3-203BLK https://www.powerflexusa.com/shop/pr...s-bushing-2777
    These are the individual part numbers for the Audi stretch bolts if you want to try and source them less expensively. Probably just easier to purchase the ECS kit.
    (4) Upper control arm inner bolts, # N10425302
    (4) Upper control arm inner nuts, # N10286110
    (2) Steering upright pinch bolts, # WHT007963
    (2) Steering upright pinch bolt nuts, # N10272302
    Apr 06 2014
    Ca
    Can you let us know if the bushing made a big difference thanks
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    I think I'm going with these when I start putting my RS5 back together. I had purchased new Lemforder arms for my RS5 but I stole them for my S5 so I still need to do the RS5.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Jun 24 2017
    San Antonio, TX
    Since installing, I've taken the car in for an alignment as things were definitely out enough that I noticed. I also raised my car by 5mm all the way around.
    Have to say I'm really happy with these bushings and the new alignment. I used to have this "dead" area, just off center, which didn't provide linear turn-in. I'd start to turn the wheel and not much would happen. Just seemed a bit sloppy, lethargic, until the wheel's angle was a bit further along. The new bushings mostly cured this. I don't have the Alu Kreuz (the ONE supsension mod I don't have!) but I'd imagine the difference before and after is probably similar. May do the Alu for weight loss alone.
    I've gotten two hard drives in with the new alignment numbers and I'm quite happy. Haven't had the chance to see if the triple digit, hard on the brakes rear wag is gone. But the entire car feels much tighter and sharp overall than it did prior. Looking at my alignment going in, things were pretty off. Shitty roads and of course, removing the upper control arms.
    New numbers
    Numbers from my previous alignment
    Absolutely no extra noise but I'm not expecting any for at least a year or two based on my last test.
    Jan 10 2008
    Roy, WA
    That's good to hear. Audi's in general have fairly precise steering if set up right but they really lack in any kind of feedback. My old '74 911 Carrera, now that car I can tell when I run over a spec of dust. I'll go ahead and order the bushings this week.
    Your specs look good. I just had my S5 done and it looks very similar to yours.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Jun 24 2017
    San Antonio, TX
    Agree...I CAN feel the granularity of it. I can feel the road surface but it doesn't load up like a hydraulic system does as you go through the different phases and tire loading in a corner. I've had a few exceptional cars in that regard and have driven a few 911's so I know what you're referring to!
    Jan 29 2019
    St. Petersburg, FL
    Necro-bump, but just wanted to see if there were any updates after close to two years?
    Jun 24 2017
    San Antonio, TX
    Bushings are still good, zero issues, zero extra noise. I know one other RS5 owner who used them in the lower control arm, main bushing, and had problems with them. Not sure what the cause or point of failure was though, still waiting on diagnosis. Seems to be a good option for the front upper control arms.
