Results 1 to 18 of 18
    Senior Member Four Rings
    Mar 05 2020
    NewYork
    2011 A5 2.0T Quatro, will a faster engine drop right in?
    My car is dealing with the oil consumption issue and black smoke out of the tail pipe...
    I dont know much about Audi's, VW's... is there any more powerful engines that would just bolt right up? I mean might as well explore all my options before deciding to just change the pistons and rings.
    I drive a 2011 Audi A5
    Nov 03 2016
    CA
    2011 A5 got the ZF 8 speed trans, I wonder if the 3.0T supercharged V6 would line up and work since this combo was used in a lot of Audi models like the C7 A6,A7, the SQ5, and others
    2011 Audi S5
    (GONE) 2011 Audi A5 2.0T [APR STAGE 2] [034 MotorSports HFC]
    Mar 05 2020
    NewYork
    Quote Originally Posted by brilliant_black View Post
    Yea, id like to find out. If something gunna happen might as well try to make it faster.
    May 10 2015
    Pittsburgh PA
    No it's not that easy. Yes the supercharged v6 physically fits and will bolt right up but in addition to needing the transmission, differential, and all other drivetrain components from a donor S5, you also would need almost every computer module from the same donor S5 to swap into your A5. It's a large undertaking, people have done the 3.0T conversion to A4 Avants, you can research some of those threads and see all that's involved. Essentially though, you'd need to buy a wrecked S5 to donate its parts and your car would be out of commission for a long time.
    If your motor really is trashed, I would recommend getting a low mileage 2013-2016 2.0T and put a K04 turbo on it. That will get you a properly quick car and be a much more manageable undertaking.
    Mar 05 2020
    NewYork
    Quote Originally Posted by 19birel View Post
    I am not sure if my engine is trashed yet, its blowing black and sometimes gray smoke out of the tail pipe every time I take off. This happened after I over filled it with gas. Not sure if I need one of those new canisters or not. Stupid German cars... Also it uses a quart of oil every 400 miles or so.... Ive only owned it 2 months and starting to hate it already.
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Quote Originally Posted by NitroViper View Post
    I'm almost certain it's your piston rings that are toast, it's a well know issue on that engine and was a free recall to replace the rings.
    It would be much cheaper to have your engine stripped down, new rings and a clean up of the head (and a bigger turbo if you want some more power) than it would navigating your way through a transplant from a donor car.
    Get a new clutch in it while the engine is out and you will have good trouble free fun for some time.
    Mar 05 2020
    NewYork
    Quote Originally Posted by JamesRS5 View Post
    Well black smoke is gas, I am having a hard time understanding why people say its from the oil consumption issue. Its a weird coincidence it started happening the day I over filled it with gas? It happen all at once the smoke wasnt gradual. It went from one day no smoking to smoking every time I took off.
    Feb 27 2014
    Dubai
    You have around 5 threads currently running on here all related to maintenance on your engine, one of those is oil consumption, one is smoke one is loss of performance.
    Black smoke can be oil, depends how much oil is burning.
    You did a science experiment and ran sea foam when CRC valve cleaner was still active, is that a similar time to the fuel incident and smoke?
    Mar 05 2020
    NewYork
    Atleast Im making the forum active lol.
    No that was like a month and a half ago, the black smoke started immediately after over filling it with gas. I ordered a evap charcoal canister to replace mine used it was only $45.
    I also just ordered the new updated PCV valve.
    I only noticed the oil consumption issue because the oil light came on and I only recently changed the oil and was like WTF...
    Feb 27 2014
    Dubai
    http://casestudies.atlanticmotorcar....on-correction/
    Not sure one of your posts to drop this but have a read
    Veteran Member Three Rings weagle1856's Avatar
    Dec 15 2015
    Audi TT 225, Audi A4 Avant, VW CC, BMW X5
    Denver
    Yeah it should.
    Sent from my Nokia 9 using Audizine mobile app
    In addition to what 19birel said, I mean yes you're right, but no shit you're gonna need a new ecu and tcu unless you do a manual swap also.
    Those are small things to consider compared to doing an engine swap.
    Mar 05 2020
    NewYork
    Quote Originally Posted by weagle1856 View Post
    Yeah it should.
    Would need the ECU also, wonder what other issues that would cause.
    Veteran Member Three Rings carrrnuttt's Avatar
    Mar 24 2019
    2013 Audi S5; 2009 Mazda RX-8 R3; 2022 Dodge Durango R/T AWD
    Phoenix, AZ
    My personal opinion is: With what you're going to spend in parts and labor for this endeavor, just go ahead and do the minimal amount to get your current car serviceable and trade it in for the car you're trying to turn your car into.
    I myself have a personal goal to eventually swap a 4.0T into my car. But creating a largely unique combo like that that doesn't exist "in the wild" is different from you jury-rigging your car to match a car that already is pre-assembled for you in that exact config.
    That is, if you're continuing with the B8.5 3.0T swap. If you want to go even more unique with your engine choices, then more power to you.
    2013 Audi S5 Brilliant Black 6-spd Sports Diff
    APR Stage 2 Ultracharged (93 tune) - CPS Cooler - Carbonio Intake
    ECS light flywheel
    Spec Stage 3+ Clutch Kit
    JHM Short Shifter
    034Motorsport Insert Kit - Trans Mount
    • Custom Exhaust
    Mar 05 2020
    NewYork
    Some people just say put new rings in it, but the problem would come back eventually. If I go with rings and pistons then I read that you also need the connecting rods because the wrist pin is bigger. Thats where things get expensive. While its apart might as well do the timing chain work also.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    You are correct. Just replacing the rings won't cure the design flaw. Somewhere in one of my responses I linked to updated pistons that worked with the original smaller 21mm wrist pins and don't require the rod replacement. If you get genuine Audi upgraded pistons you will also need the rods with the larger wrist pins.
    Mar 05 2020
    NewYork
    Ill search for that post. That would save alot of money, atleast a few hundred $$
    Dec 28 2006
    Western Maryland
    Here ya go. Clicky click®
    Mar 05 2020
    NewYork
    Didnt realize it was in one of my threads, just sat down from being outside messing with the car.
    Thanks man.
