Results 1 to 20 of 20
Thread: Brake Grease
    Mar 26 2019
    Ontario
    Brake Grease
    Does anyone have a good tutorial on how to properly grease the brakes on our cars? And the second question is how precise is the grease specification on these machines? I have heard a wide range of comments all the way from "Dude, brake lubricant is brake lubricant" to "If you use the wrong brake grease on these machines you're brakes will be toast".
    Veteran Member Three Rings Stazi's Avatar
    Aug 27 2019
    2012 Audi A4 S-Line, 2019 Jeep Grand Cherokee Altitude 4x4, 2017 Moomba Craz
    Michigan
    Use a good molybdenum high temp grease on the slider pins and you will be fine
    I sell grease and oil for a living.
    2012 Audi A4 2.0T S-Line
    K04 // IE Stage 3 K04 tune // USP HFC // Becker Cat-back // ECS Intake Pipe (w/modded airbox + K&N) // ECS Luft-technik FMIC Intercooler and pipe kit // GFB VTA // RS mesh grille // CF M4 style spoiler // ST rear sway bar.
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Quote Originally Posted by Stazi View Post
    Mar 26 2019
    Ontario
    Understood thanks.
    Feb 15 2016
    Cambridge,Ontario
    i have tried a lot of them , to be honest i find the best to be syl glide brake lubricant.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Ditto..
    Jul 16 2018
    Atlanta
    I used 3M silicone paste (08946) for the caliper guide pins and Ate plastilube for the back of the pads and on the guide pins of the caliper carriers (see TSB 2033674/8). Probably would have used Sil-Glyde if the packaged kit from FCP had not included the Ate, which is also a well regarded compound for its relevant uses (ie, nothing with rubber contact), and I had not already had the 3M laying around. As to Sil-Glyde vs Cerami-Glyde, I don't track the thing. I don't need 3000°F resistance, and I'm assuming the Cerami-Glyde is more expensive.
    The Audi part for replacement guide pins and boots actually includes a TRW package of grease for the purpose. But no idea what it is, https://germanoem.ca/parts/brakes/ca...8470b-trw.html Audi quotes anti-sieze G 052 560 A2 for the pad backs and carrier pins and lithium lubricant G 052 150 A2 for the caliper pins. But who likes using expensive Audi branded stuff.
    Feb 15 2016
    Cambridge,Ontario
    Also lithium would have been specked out during design many years ago and lithium has moved into the dark ages of grease.
    Sent from my SM-G973W using Audizine mobile app
    1976 Yamaha XS 360
    Feb 09 2020
    07 Ranger Mini Truck
    MPLS, MN
    Permatex #24125, or for you in Canada, Permatex #24126. Same same, its the purple. I use it all day long on customers vehicles and also my own fleet here in MN. I use this product for the slide pins and all moving components in a disc brake system. Biggest areas of concern in a disc brake system in regards to lack of lubrication are the slide pins and the brake pads in the caliper bracket.
    Mar 26 2019
    Ontario
    Wow okay thanks My Affair. So following up so when you say "...and the brake pads in the caliper bracket" you mean the BACK side of the pad and the short projections on either side of the pad that slide within the caliper then, eh?
    Mar 26 2019
    Ontario
    Sorry one follow up: so I have the Permatex ORANGE [Not purple]...yes/no?
    Feb 15 2016
    Cambridge,Ontario
    i have to say i have used the purple permatex several times and have found it TERRIBLE on the slider pins. Maybe its my environment but the most i can go with that is two years. I find the pins totally seized if i try and go longer than that. ( two of my lower pins were seized even at two years ) I now just put this on the back of the plates to use it up but exclusively use syl glide on the pins and no issues, even through cold slushy Canadian Winters.
    just my experiences.
    I did a write up on how to do rear brakes and i specifically had to go back and tell people NOT to use the permatex purple as i felt guilty telling them what i used.
    I do realize YMMV
    1976 Yamaha XS 360
    Mar 26 2019
    Ontario
    Hmmm...so My Affair...how would you respond to that?
    Sounds like a pretty contentious debate brewing in the high profile world of a-hem brake grease...lol...
    Nov 20 2016
    I do realize YMMV
    Well I don't know if anti-seize, which is what that is, is all that good as a lubricate for something that needs to glide as efficiently as possible. I've always used syl glide on slide pins as well with great success. That's a silicone based lubricate.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Bee8point5 View Post
    not really, everyone just shares there experiences. , don't stir up shit ...
    1976 Yamaha XS 360
    Aug 30 2018
    ATE Plastilube is the only thing you need for the backs of the pads and hardware. Been using it a decade and never disappoints.
    https://www.fcpeuro.com/products/brake-pad-silicone
    2019 Audi Q5 - 28k; Arctic White; Black Optic
    2003 Mercedes ML350 - 166k; Gray
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by ps2cho View Post
    I really like ate products and would have likely tried that if it were readily available..
    I have a few cans of super blue I hoard like it's gold.
    1976 Yamaha XS 360
    Aug 30 2018
    Jealous...ATE Super Blue was the greatest brake fluid invented, until the morons in government decided arbitrarily (like many other legislative decisions) they didn’t like the color and banned it.
    Now we’re stuck with guessing if all the old fluid is out because the color is close to impossible to tell when it’s clear.
    Next time you do an order pick some up. The other thing I like about it is that it doesn’t feel “gross” on your hands like grease does. If feels like it wipes off your hands clean and doesn’t get into every groove and is there for days.
    Nov 20 2016
    I had an old can of the ATE Superblue I just finished using up. Best fluid ever.
    Jul 16 2018
    Atlanta
    Well, it appears the statue is at least 30 years old (https://www.nhtsa.gov/interpretations/nht90-443). That ATE was either ignoring it or intending the stuff for race/off-road use (where the statute doesn't apply) is a who knows. But Continental at some point decided itself to pull it. The statute does allow a color range, though not as stark as was previously possible. Did ATE transition to Super Red and Super Amber? It's not like they didn't have a path if they wanted to take it.
