After pulling the Engine cover off to investigate low coolant\no heat from vents, I filled up the almost empty reservoir tank, and started the car.
The engine wouldn't idle smooth and would miss-fire and shutter. Throwing a code found by Carista P12A2 and 05658.
Code P12A2 = The Engine Control Module (ECM) monitors the Fuel Rail Pressure Sensor. The ECM sets the OBDII code when the Fuel Rail Pressure Sensor is not to factory specifications
I guess when I pulled the engine cover off, I leaned the cover too far to the right and broke this sensor off.
After leaning over to look, a bad hissing\sucking sound was heard and the engine cover must of cracked off the sensor on the manifold.
Placing the sensor back in worked great, but I need to replace the bracket and while I'm at it...the sensor.
Used some RTV to stick it back in place for now. It's just a friction fit when the bracket is not broken.
QUESTION. What sensor is this? Looking at numerous google pics diagrams and searching the code. There isn't any definite answer.
