Results 1 to 11 of 11
Thread: B7 A4 Roof Rack
    Sep 28 2006
    Lexington
    B7 A4 Roof Rack
    Looking to put a roof racking on the car. What's the best brand/easiest way to install?
    Thanks
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Sedan or Avant?
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Feb 26 2019
    Laguna Niguel CA
    Following for sedan options.
    Sent from my SM-G973U using Tapatalk
    Dec 25 2017
    Sweden
    I would go with Thule - you can use the selector on thule.com to filter for your model year.
    I have had a few different models over the years on my various cars including squarebars and wingbars.
    Depending on your budget I would get whatever is most aerodynamic (less noise) and make sure I get locks with them.
    Audi A4 Avant Quattro 400 CHP build thread.
    Sep 28 2006
    Lexington
    Sedan
    I don't already have the post that run across the top (I think that's one avants), but is this a hard install?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Dec 25 2017
    Sweden
    Quote Originally Posted by AudiTurbo View Post
    Sedan
    You can get a rack that installs on a car without rails or without mount points. I had that on my STI. Only problem is, with time it will cause some imperfections in the clear coat of the car because of dust and whatnot. If you take that route put some tape in between or remove rack on occasion and clean.
    Why do you need a rack in the first place?
    Veteran Member Three Rings bwdysart's Avatar
    Sep 05 2017
    B7_A4
    Richmond VA
    I am a roof rack user on my B7, you can fit anything on top of your car, here I have a 9’ whitewater kayak and a roof box to keep gear in.
    I use Thule aero bars, but their square bars are fine too, you do not need avant roof rails to install racks. The car has built in mounting points behind the door frame.
    Sep 05 2017
    B7_A4
    Richmond VA
    B7 A4 Roof Rack
    The rack towers (the bit that goes between the roof and the the cross bars) are the same for every sedan, but they make a fit kit that is specific to B6/B7 cars that hooks into little holes in the roof between the two white triangles.
    I don’t have my racks installed right now as I usually don’t run them in winter since I don’t get on the river much then. And with covid I’ve had no need to put them on
    Junior Member Two Rings IceCoast's Avatar
    Nov 03 2019
    Audi B7 A4 6MT *Quartz Grey* BMW Z3 3.0i MSport pkg 5MT *Black*
    Pennsylvania
    This is the best photo I have of mine it’s a Thule with snowpackXL works great easy to put on. If you want specific pictures of it lmk.
    2006 B7 A4 6MT
    2001 BMW Z3 3.0i MSport Pkg 5MT
    Sep 28 2006
    Lexington
    Quote Originally Posted by bwdysart View Post
    Where did you get the aeros? I didn't find them on the site. Thanks
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Sep 05 2017
    B7_A4
    Richmond VA
    It seems like they are called wingbar evo now
    https://www.thule.com/en-us/roof-rac...o-135-_-711420
