If it were me I'd feel I'd want at least an RS5 SB for the power which may swing too much the other way. The S7 being more "balanced" the RS5 being too "track focused". Not to mention with options the RS5 can cost as much or more than an S7. So no savings there. I understand the S5 would be different.
In stock form the S7 air suspension might be considered too soft by some, but lower it a bit and get some sway bars and I think it is the best of both worlds. Stiff and flat in dynamic when you want it and still plush in comfort when you need it.
As for tech, personally I am a bit old school. I have zero desire for touchscreens or carplay. The virtual cockpit I think is pretty neat, but the analog gauges do the job too and with hud I barely need to look at them anyway.
I see your previous 5's were manual that may be some of what you miss about the platform. Not an option any more. Do you drive around the S7 in manual mode? While it doesn't make the 7 handle any better it does make it feel different and being in the right gear in manual mode while accelerating with the sport diff around a corner is a different feeling that just driving around the same corner. I get the appeal of the slightly smaller platform but only you will be able to tell if it is what you truly want.
Some numbers if interested:
Based on APR's measured stock output with 93 octane.
S5SB 397HP 395 ft-lbs @3925 lbs or .101HP/lb (9.89lbs/HP)
S7 480HP 451 ft-lbs @4508 lbs or .100HP/lb (9.99lbs/HP) Almost the same.
RS5SB 458HP 469 ft-lbs @4057 lbs or .112HP/lb (8.86lbs/HP)
just for fun...
'17 R8 553HP 398 ft-lbs @3700 lbs or .149HP/lb (6.69lbs/HP)
'17 R8 @6500 ft. elevation 445HP @3700 lbs or .120HP/lb (8.31lbs/HP)
S7 Stage I 563HP 627 ft-lbs @4508 lbs or .125HP/lb (8.00lbs/HP) Better than an R8 at high elevation.
(Irrelevant I know.)
