Hi Guys.
My first post here and i will se if this can help me out. I have recently change my brake pads (front and back) And i also change my brake pad sensors.
After i have the warning symbol light up in my dashboard after.
I have tried everything, changed the sensors, sprayed contact spray in them, pulled them back and forth, And now also cut the cable short-circuit the cables without connect in the brake pads. Nothing is working.
So i am thinking of that i have damage on the cable somewere else on the way up in the engine room.
I haved try to found a wiring diagram were the cables are entering the engine room, so i can short-circuit thoose there and in that case easy se if i have a cable issue between that point and the sensors.
Can anyone help me with a picture or a wiring diagram were the cables are in the engine room so i short-circuit them.
Thanks in advance.
