Results 1 to 25 of 25
    Apr 28 2020
    Colorado
    Tips for Removing 8mm Triple Square Banjo bolt for HPFP- Cam Follower?
    Greetings Audi Vets & Enthusiasts!
    A month ago, I bought a 2006 Audi A4 2.0T Quattro (Brilliant Red) with 201k. With help from my dad, we have replaced the power steering rack due to 3 different tears in the bellows causing leaks, replaced the timing belt and water pump, serpentine belt, and a handful of other maintenance related issues, including oil, coolant, air filter changes.
    We realize it's critical to check the cam follower within the high pressure fuel pump (HPFP), BUT... we can't seem to be able to remove the 8mm Triple Square Banjo bolt from the HPFP. HELP!!
    We purchased 2 different Triple Square bits and played with various lengths of extenders for sockets, but still can't seem to crack it. We're even more concerned about tightening it once loose.
    I've read through some stickies and searched for a bit, BUT... please, any advice for this Audi novice would be GREATLY appreciated!
    Perhaps a stubby bit and socket set for the triple square or simply 1/4" extenders???
    Thanks in advance,
    DluA (James)
    Veteran Member Four Rings KMPRSSD's Avatar
    Dec 19 2010
    E10 2002tii, 2010 VW Touareg Lux Limited
    Connecticut
    The trick is to get the bit to sit fully and square in the bolt. Its been a while since I have done a cam follower, but a combination of wobble or universal joint sockets and lengths should give you the correct angle. You can also try a touch of penetrating oil on it overnight. Also are you quite sure it is a triple square?? I don't seen to remember it being one.
    ll B8.5 S4 l 6MT l IE STG ll SP l Daytona Grey w/ Magma l Sport Diff l Black Optics l B&O l AWE Touring w/ non res DP l 19" AG M590 l Luft-Technik Intake l P3 Gauges l EuroCode SS l RS4 Grille l Carbon Valance l DeAuto Fogs l RSnav ll
    May 15 2019
    2007 Mercedes C230 Sport, 2006 Chrsler Serbring, 2006 Volvo S60 2.5T, 2006 A4 Quattro 2.0T
    Bellevue, WA
    If you don't have experience in removing the banjo, I would suggest you to buy a couple banjo bolts before starting this. If the banjo bolt falls down into the black hole of the engine bay, it's hard to find. You don't have to buy any special stubbies. All you need is about 12-15 inch long 3/8 or 1/4 extension depending on the socket. You need to move the coolant tank and pcv breather hoses aside, put the socket with extension from rear( bottom side of the engine). Use a screw driver to guide the socket into the bolt, a magnet to catch the bolt before it falls off. People say you need some electrical tape I'm the tip of the socket to hold the bolt firm but I don't like that as it's a bad way to strip a bolt.
    Watch this video.
    https://youtu.be/XJ7wcj7oi_4
    May 15 2019
    Bellevue, WA
    First time, it's feels like there is no way that a socket and extension will fit in the tight place. If you are using 3/8 socket, hold the socket with magnet near the bolt then push the extensions from the bottom to clip into the socket.
    Apr 28 2020
    Colorado
    Appreciate the advice fellas! I did find that video previously, but will try again. Thanks for the input about having multiple banjo bolts and using a magnet upon disconnecting.
    Veteran Member Three Rings IbisB7stage2's Avatar
    Mar 20 2013
    Bay Area
    If jeevans ideas don't work, pull the intake manifold off. It's way easier then you think, gives more access to the banjo, and you'll want to check carbon build up on the intake valves.
    Sent from my SM-G920V using Audizine mobile app
    ~John
    B7 A4 quattro 6spd, k04 w/ meth, PSS9 coils, S4 recaros, basically everything else
    C5 S6 Avant 6spd
    May 15 2019
    Bellevue, WA
    Quote Originally Posted by IbisB7stage2 View Post
    Pulling the intake? It clearly takes around 2 hours to do it if he had never done it before. Not to mention, a bunch of tricky bolts which needs magnets and 1/4 sockets, Changing injector seals. Either way, OP is better of using 1/4 extensions and sockets
    It's a good idea to clean the carbon buildup but I hope he has time for scraping it. I did mine last week first time In it's 160k mile lifetime, it took me 3 hours to scrape off the buildup with powertools and screw drivers lol( I don't have an air compressor to do media or walnut blasting)
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Quote Originally Posted by DluA View Post
    Thanks in advance,
    DluA (James)
    Let get one thing straight before you and your dad go on a voyage together.
    The boots on the power steering rack are not there to keep fluid in. They are there as dust boots for the inner tie rod.
    The fluid in the rack is contained by seals the are further inboard than the dust boot.
    Make sure you know what parts do before you get all excited about stuff and potential spread misinformation.
    End rant/
    Now the banjo bolt, i dont know, i ditched mine and replaced it with the soft line on the later model B7.
    Apr 28 2020
    Colorado
    Venom,
    While you are right that I did a poor job of explaining the reason for the PS leaks, let's also get straight that I clearly called myself an Audi NOVICE
    If you're taking what a brand new member said as gospel, then forums in general are probably NOT the place for you. With that said, thanks for your insight on the banjo bolt!
    Cheers
    Dec 04 2011
    Kansas City, KS
    Venom,
    Cheers
    Im not taking it as gospel at all. Im just helping you understand what that part is there for. Novice or not, take it on the chin and consider it tough love.
    Scrap the banjo bolt and get the parts to convert it to the new style barb. It'll save a lot of headache.
    Fuel line
    Soft hose
    Barb fitting
    Thats all you need to convert it.
    Sent from my SM-G960U using Audizine mobile app
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Feb 15 2016
    Cambridge,Ontario
    The banjo bolt is easy literally 10 seconds.
    But you need to know the trick.
    Triple square bit on a 12 inch extension. Go way down and hook under everything ..
    Use a telescoping magnet to grab it as it comes out. Done.
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Apr 28 2020
    Colorado
    Appreciate it fellas! Thanks for all the responses!
    I have 06D-109-309 C as the OEM P/N. Anyone recommend anything different for replacing the follower?
    Thanks again.
    Dec 04 2011
    Kansas City, KS
    Just get an INA follower. Been using them for years with no issues. And theyre about half the price of oem.
    Also on sale at ecs now.
    I literally just ordered one 5 minutes ago. Don't buy the kit its overpriced, get the follower and pump gasket individually and its not even $30 total.
    Feb 15 2016
    Cambridge,Ontario
    Because i am asked about this so often i just went down and snapped a couple of pics. it literally took me longer to take the pics than to get onto the banjo. One more tip . people get paranoid because it is fuel , do NOT over reef this thing. snug and a little extra is fine.
    tools needed .
    pics of how to access..
    you can even easily get a torque wrench on here if it makes you feel better.
    don't have to move coolant take or anything..
    there is a line of sight spot from above just stick your magnet in and grab the bolt as it comes out. i put it back in that way too and bring the bit up to meet it when i put it back together.
    1976 Yamaha XS 360
    Apr 28 2020
    Colorado
    VVenom- you saved me time and money! Bought 2 of each. Always nice to hit the discounted pricing. Once again, I thank you!
    Apr 28 2020
    Colorado
    Iceman- wow! Beyond what I expected anyone to respond with! You are the man! I’m sure this time and effort you took will serve many that come across this thread. I’ll let you know once we replace the follower and hopefully find this bolt to be “old hat.” Or replace it all together as VVenom suggested. I’ll be your wingman anytime! Maverick. lol
    Feb 15 2016
    Cambridge,Ontario
    actually this comes up a fair bit... i just never bothered to do the pics, you motivated me .. people think having that banjo bolt is a bad ting, until they realize its way quicker than the rubber hose version where you are fighting the pump becasue the rubber hose stays attached. .
    oh be VERY careful tightening the three fuel pump bolts, snug is all you need, they strip out VERY easily out of the timing housing.
    1976 Yamaha XS 360
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    I also always use INA followers. Theyre like $15 on FCP, and only need to pays for 1. Then use their lifetime free replacement. But I like haveing the rubber hose, I leave it on ta do the follower. Just remove hardline, valve, 3 screws, and remove.
    Sent from my LM-G710VM using Audizine mobile app
    Apr 28 2020
    Colorado
    Everyone- Thank you for the advice and ESPECIALLY want to thank ICEMAN for the detailed pictures that turned this banjo bolt into a breeze. Ordered the INA follower and gasket from ECS. Not too bad after that. Seems like I should get some mileage from this follower based upon my driving habits... Cheers!
    Feb 15 2016
    Cambridge,Ontario
    great work !!! pretty easy once you figure out the angle right !!!?? :)
    1976 Yamaha XS 360
    Senior Member Three Rings Nizmo's Avatar
    Oct 09 2015
    Boston
    Might sound silly but having both styles of these HPFP's I'd rather the banjo style. I hate fighting the rubber line.
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by Nizmo View Post
    The nice thing though is if ya don't need to actually remove the pump, ya font have to touch the rubber line. Like just checking/changing follower, I leave it attached.
    Apr 20 2020
    '04 allroad 2.7T, '07 A4 2.0T qt, '10 A4 2.0T, '10 TT 2.0T qt, '02 Ford Ranger 3.0L.
    Chino, CA
    I removed my '07 BWT engine HPFP twice, but both time left the bottom hose attached. You don't need to remove it like the JHms video to replace the follower.
    Mar 24 2013
    Oakdale, CT
    I always use two long extensions and come up from down my the axle like pictured above. I prefer working on the banjo bolt setup over the soft line.
    -Adam
    Feb 15 2016
    Cambridge,Ontario
    bumping this as this has come up again.
    1976 Yamaha XS 360
