Originally Posted by
jbullin2
That’s assuming the center of the wheel bearing is already inboard of the centerline of the wheel, and that there is zero camber. Has anybody measured the bearing center to hub surface distance?
Like you said though, any change would need to be extreme to have a measurable effect.
Well, as long as the camber is constant and ET is the only thing changing, I don't think it would matter. That would just reduce the applied torque slightly vs. a 90 degree angle for any distance from the bearing. At least that's my thinking
That is true about the wheel bearing position, though. It may be that you actually reduce the torque by increasing ET to some extent (if the bearing is "in front of" the center of mass of the wheel to begin with). That would depend a lot on wheel design and size though.
Either way its definitely not really a huge concern
