Results 1 to 16 of 16
    Apr 28 2020
    2.0tfsi Low Oil Pressure at Cam Adjuster
    Hey everyone
    Have a B8 A4 with the 2.0tfsi. This is the first Audi I've ever bought and the first I've worked on( I usually work on powerstrokes and ls motors).
    I got this car from a neighbor with what i thought was just a chain rattle that turned out to be a camshaft adjuster rattle.
    Ive replaced timing chain and tensioner, cam bridge, camshaft, and adjuster valve. Timing is Dead on. Oil and filter were along with these parts.
    Issue right now is when the engine is cold and I start to rev it I hear the cam rattle and the EPC light comes on along with a P0011 code. As the engine warms up I stop getting that rattle and the cam timing stays fixed at 28 degrees.
    I decided to pull the adjuster magnet and manually depress the adjuster valve and sure enough when its cold I can get the camshaft to adjust but when its hot I can depress the valve and nothing will happen.
    So my question is, is there anything between the cam bridge and oil pump that will restrict oil volume on these motors?
    Feb 15 2016
    Cambridge,Ontario
    sounds like a bad spool valve. take a pic of the spool valve with the magnet removed and post it .. it should all be perfectly flush, if there is a piece pushed out towards you its bad. Sounds like the spool valve is bad and it is over advancing the timing at idle.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Nov 21 2019
    09 A4 Quattro 03 VW GTI
    Erie,PA
    Heres an image of what the center "plunger" on the spool valve should look like
    This is what it shouldnt look like, notice the center "plunger" protudes outward
    Treat me as a fool for im still learning...
    Apr 28 2020
    Quote Originally Posted by Ejad View Post
    Spool valve is good. Forgot to mention I threw another one in just for kicks. My original one is functioning and the center isnt pushed outward.
    When I manually depress the valve nothing happens which would lead me to believe its an oil volume issue
    Feb 15 2016
    Cambridge,Ontario
    you can actually run the engine and press that spool valve with no magnet in place without oil spraying every where ?
    1976 Yamaha XS 360
    Apr 25 2020
    Orlando
    I have exactly what you're looking for
    Sent from my SM-G935F using Tapatalk
    Jul 16 2018
    Atlanta
    I suspect the default state of the plug is flush. When the N205 activates and extends the magnet, it pulls the plug outward. If the plug is projected out by default, it means the mechanism to pull it back to default state is no longer working and the system will be over advanced when it doesn't want to be. Pressing the plug inward is likely an invalid state. This is all speculation.
    Feb 15 2016
    Cambridge,Ontario
    Actually smac there is a Pin on the magnet side, when the magnet is activated it pushes the pin out is how i thought it worked.
    1976 Yamaha XS 360
    Nov 21 2019
    Erie,PA
    yes its essentially a solenoid actuator. When magnetized it pushes a pin which in turn pushes the center of the spool valve in.
    Jul 16 2018
    Atlanta
    Ok, so the protrusion that comes out of the N205 is not the magnet itself to pull the plug, the protrusion is pushed out by the magnet inside the N205 to push the plug in. It's been a long time since looked at this and going off too much memory. It's noisy as hell, that's the one thing I do know I remember correctly. :-)
    I wonder what a popped out state reflects; what has gone wrong inside. Because installing the N205 then is going to push it back flush. I assume a popped out one, though you can push it back flush, then cannot be pushed in further.
    Apr 28 2020
    Thats correct.
    There isn't much at all coming out. Its way less of a mess then it should be.
    Its almost funny how little its getting up there considering i'm not getting any oil pressure messages and still have about 20psi at idle.
    Feb 15 2016
    Cambridge,Ontario
    Sounds like your oil pressure is fine something else is happening. I wonder if your oil screen or check valve in the cam bracket his come apart and it is jamming a passage way. Or if it's that stupid check valve under the head.
    Sent from my SM-G973W using Audizine mobile app
    1976 Yamaha XS 360
    Apr 28 2020
    Didn't know there was a check valve in the head. Guessing that would mean the head has to be pulled to change it?
    Pulled the bridge already to check that check valve. It was free and shop air flowed through it fine.
    My original cam bridge had some pieces missing but most of the screen was there. Didn't find any signs of the screen in the spool valve or cam adjuster.
    Feb 15 2016
    Cambridge,Ontario
    Yeah there was a post here about a guy that had a bad one see if you can find it. I'm not sure the symptoms
    1976 Yamaha XS 360
    Apr 28 2020
    Alright wanted to update this and not leave a dead thread. Ended up just selling the car sadly. But kept in contact with the new owner. The new VW cam bridge I installed was somehow bad. A local dealership replaced the cam bridge and all was well
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Dscott16 View Post
    well it certainly sounds like we were all over it,, that check valve is inside that bracket.
    1976 Yamaha XS 360
