First, I tried spraying electronic cleaning solution, which helped a little bit, but didn't fully fix the issue. I'd go ahead and give it this a shot first because if this doesn't work, you'll need the electronic cleaner anyway:
Since the spray cleaner didn't work, I had to take apart my center console. Follow these directions, and as the guy said, the console should first pop off with the cup holders. The console comes out as a whole piece:
To remove the MMI control from the console, you will need to remove the cup holder after following the steps above. There are two screws for the cup holder and 4 screws holding the MMI controller. Once those 6 screws are removed, then you may go ahead and pop off two console pieces separately. Sorry, I didn't take a picture of this step before I put it back together.
Once you have the MMI controller removed from the center console, remove the 9 silver screws. There is NO need to remove the rubber molding on the edge of the MMI control. I accidentally removed it, but it was a waste of time.
After removing the back cover, you should have access to the circuit board. Remove, the white clip, flip the controller over and the board should come out.
Remove the circuitboard and rubber circuitboard protector. If you see any gunk on the rubber protector, you may clean it with mild soap and water. Do not spray with electrical cleaner as it may warp the rubber.
These four pieces fell out when I removed the circuitboard. They're used for the toggle Nav/Tel and Radio/Media switches. Use the following picture when putting back together. They only go back one way so don't worry about inserting it incorrectly.
Depending on which button is stuck, go ahead and spray with electric cleaner. Don't be afraid to overspray as the circuit board is removed and the cleaner will not damage the plastic. I also used a screwdriver and my finger to push the buttons back and forth after spraying. To get to small areas, I used a needle to scrape off any gunk that I found. I almost thought that I didn't fix the issue until I thoroughly removed the dirt. The smallest amount of debris will cause the buttons to stick. I've marked the parts where I pushed with a screwdriver after spraying to move my stuck keys back and forth:
When checking if the buttons are no longer stuck, everything but the screws must be put back together. Don't be discouraged as I had to repeat the process of spraying, cleaning, and putting back together several times before the buttons were finally to my liking. Also, when putting back together, make sure that these wires are in their appropriate slots as everything might not close correctly:
One last note: make sure you put EVERYTHING back together before restarting the car. I forgot to put the shifter and got a "P Button" error message. I drove the car around my block, parked, locked it, and went in my house for a few minutes and the code went away on its own. Good luck!
