Originally Posted by
Theiceman
Charles this is what i was referring to ....
https://www.europaparts.com/spark-plug-bkr7eix.html
For the record they ran fine, i just found gas mileage went down when running these and gas in Canada is expensive ... well,,, was ,,,
Could running them in cold climate make a difference ? anyway there is enough empirical evidence that these plugs are not an issue.
a handy chart if anyone is interested .
As boost and timing are raised above stock level, heat goes up exponentially. A plug that had a copper center electrode will wear out much faster. Platinum withstands high heat better, and iridium fine wire tip even more so. While copper has a marginally better ability to conduct the spark, this comes with accelerated wear if boost and timing are higher. That means on engines with higher than stock boost or timing curves, copper plugs wear very quickly.
That means you will be lucky to get 5,000 miles before they need replacement. In this application once you get to stage 1, and especially stage 2 tunes, platinum plugs are lucky to last more than 10,000 miles. Iridium plugs a bit better, maybe 15,000 miles.
