Results 1 to 20 of 20
    Jul 31 2013
    Lititz, PA
    Alignment after bumper removal?
    I want to respray my front bumper cover. Shop said I have to hat an alignment because of the sensors. Anybody pay $600 for the alignment and recalibration?
    Oct 22 2014
    Atlanta, GA
    If you have Adaptive Cruise, the radar sensors are mounted to the bumpers. Remounting after painting, will inevitably alter the alignment and will require re-alignment. Audi Atlanta charges $500 for that job. You might get lucky and the system won't realize, but don't bet on it. I've had my bumper replaced twice due to damage, and needed alignment both times.
    May 03 2011
    El Paso, TX
    Like spectre said, an alignment is the right answer. However I’ve had my bumper off a couple times now, and as long as you’re careful and don’t start the car with stuff unplugged, everything should still work fine.
    Jan 31 2009
    2016 RS7-P
    I expected to have to realign the ACC after repainting the RS7 front bumper but was surprised it hasn’t popped up as an error and the system works perfectly fine. This is with removing the ACC sensors from the bumper not just disconnecting them. On my previous S6 with RS style front bumper it did need realignment but that’s moving to entirely new sensor positions.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Same here, no alignment needed after bumper repair. 2015 S6 w/ all driving aids.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    May 22 2016
    N/A
    I had front bumper repainted with lane assist /ACC. Battery was unplugged before bumper removal, plugged back in after bumper was put back on. Car has been fine for about 8k miles since, use ACC and lane assist whenever I drive.
    Veteran Member Three Rings GasMan's Avatar
    Jan 13 2019
    Michigan
    I was planning on having Audi calibrate ACC after I get my bumper repainted. They do a 4 wheel alignment at the same time and mine is just ever so slightly off. This makes me wonder if it's really worth the money since the alignment isn't THAT bad.
    2016 RS7 - Gone to car heaven
    2023 Taycan GTS
    Mar 29 2014
    Hampshire, UK
    Quote Originally Posted by GasMan View Post
    Alignment of the ACC sensors is something completely different to drive train alignment.
    As a general rule, if you’re removing the bumper and do not remove or disturbed the ACC sensors, then the likelihood is that you wont require An ACC alignment procedure.
    If your removing the bumper for any repair or modification work that includes repainting and an oven curing process, then the sensors will be removed to protect them from the heat process. This will require a specialist alignment procedure.
    If you don’t align the sensors, and throw codes, you are likely to get a whole bunch of associated failures since ACC is integrated into a number of car safety systems.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Jan 13 2019
    Michigan
    My dealer told me they have to do wheel alignment at the same time. Cost for that plus ACC calibration is around $500.
    Sound right, pricewise?
    2023 Taycan GTS
    Veteran Member Four Rings digdah's Avatar
    Dec 11 2017
    DFW
    My bumper has been off at least 5 times in the last rolling calander year with no ACC alignment done. In fact, I even replaced the grill and the sensors in one of those removals and no issues.
    Jan 13 2019
    Michigan
    Quote Originally Posted by digdah View Post
    Do you disconnect the battery each time? What's your method to keep the computer from wigging out?
    2023 Taycan GTS
    Jul 31 2013
    Lititz, PA
    I was quoted $600 so that sounds about right
    Jul 31 2013
    Lititz, PA
    Thanks for everyone responding.
    Jul 06 2018
    Santa Clara
    Search "ACC sensor adjustment" on Google, you'll find a post that could save you $600 if you have a VCDS.
    Dec 11 2017
    DFW
    I have not been present for all but one of the takedowns and I can tell you for sure when replacing my grill and sensors the battery stayed connected throughout. Just do NOT start the car when stuff is disconnected.
    Aug 06 2014
    NJ->CO
    FWIW I can almost guarantee the shop turned my car on with the bumper removed, probably moving it around the shop, there was a ton of codes when I got it back. After I cleared them though, no issues.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Dec 07 2009
    Denver
    On a similar note, does anyone know if you can paint the ACC covers?
    Current: 2016 RS7- Panther Black
    Past: 2012 S4 - Ti Package
    Past: 2002-2011. A4 1.8T
    Dec 11 2017
    DFW
    Yeah same happened when I changed out my turbos. I was very relieved when the errors didnt come back. Thank goodness for VGCOM.
    Quote Originally Posted by gk1 View Post
    Jul 31 2013
    Lititz, PA
    100%. Half the cars at the Audi shop are missing panels and sitting outside.
    Established Member Two Rings Ahad5058's Avatar
    Jun 23 2018
    Lakewood OH
    From my experience if you disconnect the batter BEFORE unplugging the sensors the computer won’t realize you disconnected them.
    Audi S6 c7
    Audi A3 Vr6
    MR2 Spyder
    Yamaha R6
    Ducati Diavel
    Lx470 SOLD
