Results 1 to 13 of 13
    Apr 17 2020
    2017 Fiat Abarth 500 | 2005 Ford F-250
    North Carolina
    Common issues with a 15 RS5?
    Hey guys, I am looking at purchasing a 2015 RS5. It has 36,xxx on the clock. Other than the carbon cleaning every 40-50K is there anything else I should be looking for/be aware of? And if possible can y’all post what average cost of said maintenance / repair items are? Thanks in advance!
    Nov 03 2016
    CA
    Changing the DSG oil every 30k is a mandatory thing.
    Eventually like most Audi’s you’ll have to do stuff like water pump, fuel pumps, thermostat, injectors, etc. as the car gets up there in age and mileage.
    Labor costs will get you not parts since the V8 is crammed in there with not much room to work.
    2011 Audi S5
    (GONE) 2011 Audi A5 2.0T [APR STAGE 2] [034 MotorSports HFC]
    Established Member Two Rings Leedaar's Avatar
    Jul 08 2014
    2012 Prius daily (I know...), 2014 RS5
    Sacramento
    Took my RS5 in for 75k service today (major service that includes DSG, rear diff fluid), and they found bad control arm bushings. I’m happy that it was all they found since I purchased the car without a proper PPI. I researched and found out that some members on this forum had similar issues too. The bushings cannot be replaced, the whole control arm needs to be replaced.
    Previous S5 (v8) oil changes: $120 (should be the same for rs5)
    Current Rs5 75k service: $1200/1500, quoted from two dealers near me.
    Good luck with your purchase!
    2014 RS5 Misano Red - JHM Full Exhaust, JHM springs, Maxton front lip and rear diffuser, Xpel ceramic tint.
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    Quote Originally Posted by Leedaar View Post
    Which control arms? Pretty much every bushing in the front suspension can be replaced. Sometimes it's just more cost and/or time effective to replace the whole arm with a "rebuilt" unit. Just realize that most of the bushings are dirt cheap. I'm actually replacing all of my upper control arm bushings as we speak with aftermarket poly bushings which'll last a lifetime but squeak like hell every two years until I lube them.
    On things to look for, regular service is mandatory. Things that are known issues...already have the carbon cleaning listed, upper control arm bushings tend to wear, injectors can go bad but usually do so at higher miles. Some of the small coolant hoses coming off the overflow reservoir have gone bad, the transmission mechatronic can have issues, especially if you don't service the car regularly. There's a gear sensor on the mechanical (gear) side of the transmission which has gone bad on some cars but it's very rare. Cars that sit tend to have more issues. I think the multitude of sensors tend to oxidize with time when not run through a heat cycle. McClaren was having issues with cam sensors on brand new cars that were sitting more than three months. So drive it!
    Honestly, overall, it's a very reliable car. I've had exactly one issue in almost 70K miles, that being a bad injector. The upper control arm bushings weren't looking great so I'm replacing them myself. Other than that, literally not one issue. Just regular maintenance.
    I do recommend changing the oil every 5,000 miles and do not go the full 10K between changes. That'll only add to the carbon buildup. I also recommend servicing BOTH sides of the transmission every 20K. There is one side that takes ATF (auto trans fluid) and one side that takes MTF (manual trans fluid). Same for the differential. Spark plugs probably every 35K and i's not uncommon for a coil to go bad. Easy to replace though and I'm still on my originals.
    If the car has the specs you're looking for and is the right color, go for it. They're truly wonderful cars.
    I have lots of tech and DIY videos on my Youtube page if you're interested. https://www.youtube.com/channel/UCrV..._as=subscriber
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
    Apr 17 2020
    North Carolina
    Quote Originally Posted by Ape Factory View Post
    Thanks for the reply! It definitely has the right things that I’m looking for. I’m doing some research today to see if the proper services were done to it. I will definitely be taking a look at those YouTube videos if I go through with the purchase.
    Apr 17 2020
    North Carolina
    I am hoping since this is a 1 owner car that the previous owner had all the services done like he should.
    Apr 17 2020
    North Carolina
    Also, I actually have been watching your videos already of the exhaust on your car lmao. You have got a very clean RS5!
    Jul 08 2014
    Sacramento
    Hey Ape! It was front lower wishbone bushings.
    On a side note, the dealer didn't list rear differential ATF and gear oil in their 75k check list. Supposedly, my Audi dealership discussed with AOA and the decision was rear differential service (both sides) should be done at 55k miles and 155k miles thereafter. I didn't believe it, so I had to call and verify if it can be done anyways while my car was there. The Audi tech did the rear differential gear oil (G-052-145-S2 -Axle oil) but not the ATF for clutch hydraulics oil (G-055-515-A2). He stated, "it's a very small amount of fluid anyways and we don't do them on all of RS and R8 cars."
    Anyways, I'll have this done at JHM once I'm ready for stage 2 ECU, full JHM exhaust at RMR transmission cooler.
    Sorry for the thread hijack ThatDieselGuy..
    Mar 21 2018
    Straight from Audi USA's website: https://maintenance.audiusa.com/#/search
    Somebody along that chain messed up.
    2015 RS5 | Daytona Grey Pearl Effect | AWE Track
    Jul 08 2014
    Sacramento
    Quote Originally Posted by BigAngryBananas View Post
    Tell me about it!!! I even showed them Audi’s recommended service website in person and through email...
    Apr 17 2020
    North Carolina
    All good. That service schedule that was posted is a nice thing to have.
    Junior Member Two Rings
    Nov 07 2017
    West Vancouver,BC
    just did my 71,000km service on my 15'(supposed to be my 85k service).... $1500cdn....ouch! But made a very noticeable difference.. Running so much meaner and cleaner.
    Jun 24 2017
    San Antonio, TX
    Quote Originally Posted by ThatDieselGuy View Post
    . Awesome and thank you! I have more coming. Amazed at how well the car holds up overall. Most people can't believe I daily drive it. I do try to go well above and beyond taking car of her. My neighbors think all I do is either "fix" the car or wash it. I'm probably a bad brand ambassador as they think my car is broken all the time. Nope, just checking things out and developing new products!
    Ah...the front lowers...yeah they're a pain but can be replaced. Rare for those to go out. The front end does take lots of punishment due to all that engine weight. It's like a Porsche 911 in reverse.
    The rear diff fluid change, both ATF and MTF, is at 35, 75 and 115K miles as BAB posted. I do performance maintenance and I do it every 20K miles along with the transmission service. It adds, maybe $70 to the cost so it's a worthwhile investment for me personally. Plus it's really easy to change if you use the drain and measure method.
