Hello everyone. As the title suggests I'm interested in upgrading the brakes on my B8 S5, and I've come up with two options I'm interested in going with. With either set up, I'm going to be going with some stainless brake lines and likely some EBC red stuff pads, since they seem to have the best balance of stopping power and lack of dust.
The first option is going with some JHM light weight, two-piece, slotted rotors. They're factory size, so its plug and play. They'd save a total of about 25 pounds of rotating mass, which is quite an improvement for vehicle handling, acceleration, and even helps with braking of course. They're plug and play, super easy to install.
Alternatively, I've been considering doing an "RS brake upgrade." I'd get some used RS5 front calipers, and put some OE rotors on. The problem with this route is that it's not exactly plug and play. I believe the front set up is, but I'm pretty sure the rear set up doesn't bolt right up as the RS has a different rear hub. So I'd need to do some research into the rear set (or perhaps import the B8/8.5 RS4 rear caliper and rotors) which makes the process a bit more complicated. Also, though this set up probably has better heat dissipation, I believe it doesn't really weigh any less. It would "look better," seeing as it fills the wheels better, especially if I ever jump from 19's to 20's.
What's everyone's thoughts and input?
