Results 1 to 9 of 9
    Junior Member Two Rings
    Sep 24 2018
    Brake wear light reset
    I installed new pads/rotors a while back but the brake wear light is on. The new pads do have the sensor and it's plugged in. How do I reset this light? I have an OBDEleven device. I've been unable to find anything on RossTech or OBDEleven forums. Anyone?
    Jun 11 2014
    Ny
    def interested in a response, I tried clearing the same thing on vcds but the brake light never clears ..
    Veteran Member Three Rings kevin#34's Avatar
    Aug 11 2019
    Rome, Italy
    if the connector is properly connected, the brake warning light must disappear.
    you can make a temporary bridge on the connector coming from the vehicle, to understand if the reason is other than a faulty brake pads connector or broken pads wire
    2020 TT- RS
    ex 2018 TTS
    Jun 11 2014
    Ny
    not to hijack a thread, my bbk front pads don't have a sensor, so the dashboard brake light stays on. I run vcds and it tells me its there's an error then clear it, yet it the dashboard light remains!
    1,
    Sep 24 2018
    Quote Originally Posted by kevin#34 View Post
    I have G-Loc street pads (TTRS). Both sides have the sensor, even though the driver's side is the only one with a plug. Plug is secured, but I did not try the passenger side pad to test for a faulty sensor in the driver's side pad. If it should clear on its own, then perhaps the G-Loc sensor is bad....
    I may try running some long wires to the other side of the car tomorrow and test.
    '18 TTRS // '10 GTI // '01 Ducati Monster 750
    Senior Member Two Rings shifu22's Avatar
    Aug 28 2016
    B8-S4, MK3-TTRS
    Coquitlam
    Following. I would like my light out too without having to just bridge the wires together
    2018 TTRS
    B8-S4
    MK3-TTRS
    Junior Member One Ring
    Sep 03 2019
    UK
    If your new pads don't have a sensor then you have no choice. Make it reversible by making a frig by cutting the plug and a couple of inches of wire off the old pads. Solder the two ends together and insulate. Then plug it in and tie it back out of the way. Now if your next set of pads do have a sensor you can take the frig out and use the sensor on the new pads.
    Sep 24 2018
    G-Loc won't respond to me anymore after I confirmed the sensor is bad. Laughable at best, i'm not pleased. I'm probably just going to bridge it.
    Veteran Member Three Rings Thumper3's Avatar
    Nov 27 2014
    1983 Porsche 944
    Missouri
    I upgraded the brakes earlier this year after trashing the OEMs in 10k miles (and several track days lol) and thought we could defeat the warning with VCDS like other vehicles but I have not been able to. It's funny that you can deselect the option for a wear sensor, but all it does is change the font and size of the warning in the display. lol
    Anyway, I didn't keep my old pads so I have no harness to clip and solder. I found this which looks like the same design as the connector but it is not listed as fitting the MK3.
    https://www.urotuning.com/products/f...#collapse-tab5
    I guess if it doesn't work I'm just out $15, but what do you folks think, should this work?
    If not....um.....anyone want to sell me their old pad with wear sensor harness I can clip off? lol
    '23 A4 Allroad Prestige | District Green | Black Optics | 034 Dynamic+ Springs
    '18 TTRS - Mexico Blue | APR Stg 1 e85/TCU Tune | RSe10 Bronze | Girodisc rotors front/Neuspeed 350mm Rears | Black Optics/Sport Exhaust | Red Calipers | Red Stitching
    '14 VW Touareg TDI R-Line - White | Euro paddle shift
    '12 VW Golf R - White | Stg 3 APR | Too much to list here
