I'm thinking I've 2 options. Either replace the entire brake line from the hose to the ABS unit or cut the line and splice it. The first one is not an option cause there's no way I can get to it. There's a million things in the way and it runs alongside the rear of the engine. The second option is doable. But I can't get anything in there to cut the line. The steering rack is kinda in the way. I guess I could use a small and then use a connector nipple to join both lines. It shouldn't have to be cut dead straight
Any other options or advice?
A6 2000 2.4
I'm pointing at the location with a screwdriver
