Page 98 of 162 FirstFirst ... 488896979899100108148 ... LastLast
Results 3,881 to 3,920 of 6461
  1. #3881
    Veteran Member Two Rings B5AudiVW's Avatar
    Apr 28 2005
    '15 Q5 3.0T, '11 A3 2.0T
    Morrison CO
    Got a softball for you guys, just need a couple answers. I'm sticking with my OE black optics package wheels on my 2015 Q5 3.0T, but am having them powder coated black and getting new tires. While I'd like to change the offset and go wider, I'm just not that interested in spending the extra cash on wheels that likely won't be as durable as the stock Audi rims. Giving some thought to spacers - have attitudes about spacers changed with tire shops? Last I checked they often won't even install them.
    1) So, with 20x8.5 wheels, are there any sizes I should consider other than the stock 255/45?
    2) The Conti DWS06 tires seem very popular in this forum but I've always been much happier with Michelins than any other make. Planning on going with Pilot Sport AS3 - change my mind?
    TIA
    09 Q5 3.2 | 10 GTI 6MT | 07 S4 Avant 6MT | 08 R32 DSG | 03 Passat 2.8 6MT | 06 S4 Tip | 02 A4 Avant 3.0 6MT | 99.5 A4 Avant 2.8 6MT
  2. #3882
    Jul 25 2009
    Bellevue, WA
    I am finding my dws06s to be really loud, fwiw. Could be they are getting worn and could be that I am running at the higher sq tire pressure (not sure why this is btw?). I know everyone here swears by them. They came on my cpo sq5 and I will probably go Michelin next.
    Sent from my SM-G973U1 using Tapatalk
    '16 SQ5 ROW/BilsteinB8 CH-R 9s; 997.2 spasm 6spd; '18 Macan S. Many, many audis in the past...
  3. #3883
    Aug 07 2019
    Minnesota
    Quote Originally Posted by notquiteanewbie View Post
    Thanks to Mops!
    HRE FF04 20x9 ET 25 Liquid Silver
    265/45/20 Michelin Pilot Sport A/S 3 Plus
    Did you need to use spacers with these?
    Sent from my SM-N950U using Tapatalk
  4. #3884
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by B5AudiVW View Post
    TIA
    I've been running spacers for over a decade with ZERO issues. In regard to shops, it's rare for them to be bothered these days. With proper spacers.... once installed - they're essentially extensions of the hub/wheel mount pad. Go 10mm front, 12mm rear and 265/45 rubber. Trust me
    Quote Originally Posted by wblaudi View Post
    Nope
  5. #3885
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Quote Originally Posted by scottst View Post
    I like them from perspectives of performance (they're solid in both dry and wet conditions), tread wear, and aesthetic. They're definitely not the most quiet option. I suspect you'll be very happy with a move to Michelin. You didn't mention size or preferred spec, so I'm guessing you've got that covered. But if not, you'll certainly get some good feedback here.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
  6. #3886
    Established Member Two Rings JavikoA4's Avatar
    Apr 24 2014
    Miami
    The Official Q5/SQ5 Wheel Thread - Post your setup!
    Anybody know if 20x10.5 might be too aggressive for B9 SQ5?
    Planing on changing my 20s black optics with my friends old 20x10.5 wheels.
    Planing on painting them black too. Thanks!
  7. #3887
    Jan 03 2007
    SF Bay Area, CA
    Quote Originally Posted by JavikoA4 View Post
    Anybody know if 21x10.5 might be too aggressive for B9 SQ5?
    Planing on changing my 20s black optics with my friends old 21x10.5 wheels.
    I'm going to give a 'yes' gut response, but it really depends on the offset spec of the 10.5 wheels. If you can share that you'll get some solid feedback.
  8. #3888
    Senior Member Three Rings Sport Line's Avatar
    Feb 07 2014
    BMW X6M F86,,,,,,,,,,,, SQ5 3.0T
    Cool
    It's all about the offset. They would look perfect if the offset is right. I have 295 dws06 on 9.5" -21 wheels. 295 on 10.5 would look perfect!
    Sq5 looks massive on 295! But than I look at my 325's (soon 335) on my x6m and the 295's doesn't look that massive anymore
    BMW X6M F86 * SQ5
    ~~~Audi History~~~
    2013 S6 * 2013 Q5 3.0T * 2012 A7 3.0T S Line * 2012 Q5 3.2 * 2008 TT 3.2 * 2007 A6 4.2 S Line * 2001 TT S Quattro 225hp
  9. #3889
    Apr 24 2014
    Miami
    Quote Originally Posted by VroomVroom View Post
    Was searching for old posts and found out they are ET30, 20x10.5, 295/40/20
  10. #3890
    Senior Member Three Rings ADG05's Avatar
    Oct 17 2008
    Santa Monica CA
    Its going to be pretty aggressive and by that I mean a lot of poke. I would also be concerned that you may not have the inner clearance at that offset. If that's the case, you'll have to run spacers and then it's going to look nuts!
    I came across a guy on Instagram that is running 22x10.5 et35 but he had to run 265's
    Check out his page: @gaaberap
    Also, MOPS is going to be the best source of exactly how it's going to sit.
    2021 SQ5 Daytona Gray | Instagram: @raudi_sq5
  11. #3891
    Veteran Member Four Rings buggravy's Avatar
    Jun 25 2016
    Mountain bikes and snowboards
    Calabasas, CA
    I think that offset might be your saving grace. ET30 seems to be the magic number with 295s on the B9. From memory I only remember seeing 10" wheels on the B9, but for me it's really tread poking out that starts to look whack, and that's obviously not effected by wheel width. Especially if you drop it down a little lower with links or the Cete module I think the slightly more aggressive fitment might work. I believe you'd be the guinea pig though.
    '23 S4 Prestige - Chronos Grey
    '24 Q4 55 e-tron Glacier White
    '24 Q5e District Green
    TOTALLED: '21 Q5 P+ - Glacier White (wife's)
    SOLD: 21 S4 - Mythos Black
    SOLD: '19 SQ5 - Quantum Gray
    TOTALED: 21 SQ5 - Ultra Blue
    SOLD: '19 e-tron - Typhoon Gray
    SOLD: '16 SQ5 - Sepang Blue w/Black Optics
    IG: @gravysq5
  12. #3892
    Veteran Member Four Rings freesole's Avatar
    Oct 30 2011
    Agreed that the DWS are not quiet but they are an awesome tire. The only other tire that I can find that might be a good option from Michelin is the A/S3+. They are slightly more expensive but are they a good tire?
    Current
    '22 RS6
    '22 X3M Comp
    Gone
    '19 SQ5
    '18 S5 Sportback /// Build Thread
    '16 Q5 3.0 /// Build Thread
    Insta: @frees5ole
  13. #3893
    Veteran Member Three Rings 4-ring-sleepers's Avatar
    Feb 17 2018
    2018 SQ5/2021 SQ8
    Central FLorida
    Thanks to Mops!
    Welcome to the rare Azores Green Club! Mine has 22x9 and "CETE" module is highly recommended if you have air suspension package!20190724_111251.jpg
    Sent from my SM-N950U using Audizine mobile app
    2018 SQ5 Prestige - AWE Carbon Intake, AWE Touring Resonated Exhaust, RedStar Exhaust HFC Downpipe, Turbo Systems Stage1 Hybrid Turbo, Forge Motorsports FMIC, Forge Motorsports Transmission Insert, Cete Active Suspension Controller, EPL Stage 3 (beta) tune, Carbon Fiber (w/alcantara sides) Steering Wheel, Vorstiener VFF-110 20x9 et35 Zara Gray, APR 10mm Spacers, Ti extended Lugbolts, Suntek Ultra PPF, Cquartz Finest Reserve, Full Cquartz Interior, Formula One Stratos Tint 30%
  14. #3894
    Aug 07 2019
    Minnesota
    Nope
  15. #3895
    Veteran Member Four Rings Chris.green's Avatar
    Aug 09 2017
    Atlantic Canada
    I'm going to be picking up a 2019 Q5 soon and I'm wondering if anyone can give me some input on how 20x10 et40 with 275/40 tires would fit?
  16. #3896
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by Chris.green View Post
    10mm inboard from this -
    I'm not 100% certain they'll clear the suspension, but no matter, with 5mm spacers you'll have a killer fitment.
  17. #3897
    Jun 14 2019
    Boston
    Quote Originally Posted by 4-ring-sleepers View Post
    Yeah I'm definitely thinking about the CETE module. It's third on my list of priorities right now though.
    1. AWE Intake
    2. APR ECU Tune
    3. CETE Module
    I was trying so hard to not spend money on this car too. Sold my F80 M3 to get something a bit more family and budget friendly. Oh well.
  18. #3898
    Oct 30 2011
    1. AWE Intake
    2. APR ECU Tune
    3. CETE Module
    I said the same about my Q5... then my S5... and now the SQ5. It's too fun to mod and hanging around in forums is like being around a bunch of (very friendly) enablers haha
    Current
    '22 RS6
    '22 X3M Comp
    Gone
    '19 SQ5
    Insta: @frees5ole
  19. #3899
    Veteran Member Four Rings DiscoDan's Avatar
    Sep 07 2018
    Colorado
    Mops... need some info for a potential winter setup. I'm looking to do BBS SX 0501, 19x8.5, ET32 - on 255/50 winter tires. Have photos of this setup/stance? If I want more fender fill what size spacers front and rear to push these a little further out?
    thanks
    2020 SQ5 - Prestige | Quantum Gray | 034 Stage 1
  20. #3900
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by DiscoDan View Post
    thanks
    I do not, but you can get pretty good idea looking at the 20x9 ET25 setups here. With 10mm spacers, you'd be pretty much pretty much flush, and equal to what 9" ET28 would look like. But for winter, you might be okay to run no spacer and be ~10mm inboard from flush. Or shoot for just short of flush with 5mm. BBS does the 66.6 PFS spacers in both 5mm and 10mm, so you're covered no matter.
    Here is 20x9 ET25 on 255 - https://www.flickr.com/photos/919992...7666682069297/
  21. #3901
    Nov 02 2018
    Nashville, TN
    I love it when I look back and the fitment looks just perfect...
    Thanks again Mops!
    MRR FS01 21x10.5 et 27
  22. #3902
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by dknick View Post
    Thanks again Mops!
    Looks amazing Daniel!! I could not be any more pleased with the result.
  23. #3903
    Veteran Member Three Rings mkasperzak's Avatar
    Jan 16 2014
    Transition Patrol Carbon, Transition PBJ, Commencal Furious
    huge fan of everything you've done here. Love the black on white theme. + great snap, reminds me of home
    2014 SQ5, BBS CH-R, GIAC DP 183 Fluidampr/57 AWE SC(3.18 PR), AWE Touring, Roc-Euro, Bilstein PSS10, 034 HX/X-Brace/RSB/Inserts, Thule Edge/Flow, Kuat Trio
    Build Thread / IG @thebird_sq5
  24. #3904
    Nov 02 2018
    Nashville, TN
    Quote Originally Posted by mkasperzak View Post
    Thank you!!!
  25. #3905
    Sep 20 2017
    West Virginia
    Question for you guys. Does anyone know if the Macan GTS Spyder wheels will fit a 2015 Q5 P+? I believe the specs are 20x9 ET26 fronts and 20x10 ET19 rears. I have searched all over for info on this and pictures but can't come up with anything. If you guys know of any pictures of this setup on a Q that would be awesome too! Thanks!!
  26. #3906
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by Parkinsteez View Post
    The specs are pretty solid. There is a 19mm F/R variance. I'd run a 10-12mm front spacer and call it sexy time.
    We'll be eagerly awaiting photos
  27. #3907
    Jul 25 2009
    Bellevue, WA
    I have an extra set of 20s from my wife’s Macan with winter tires that I am going to be test (on my sq) fitting this winter. Very curious to see how it looks. A little stressed about matching radius f and r.
  28. #3908
    Jul 01 2019
    Tampa, FL
    20x9 Vossen CV-10’s
  29. #3909
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Looks good! Nice ride height.
  30. #3910
    Sep 28 2010
    NW NC / DE
    Looks good Darth! 275 rubber? I didn't even know the CV10 were out until this week. And only because I sold a set of 22" ones for a Q7. More pics
  31. #3911
    Veteran Member Three Rings socialpro's Avatar
    Sep 26 2013
    2023 RS6 || 2022 XC60
    scottsdale, az
    Love a BLACK SQ5 !! Was my top choice between that and Quantum!!
  32. #3912
    Aug 12 2007
    Harrisburg, PA
    Picked up an SQ5 today and so excited to get started. Scoured through every page of this thread. Looking at a set of wheels on ECStuning. Will this size/offset be good or too aggressive? thinking about 265/45/20 tire to go with.
    Ferrada FR2 wheels
    20"x10.5" ET35 66.6CB 5x112 Matte Black with Gloss Black lip.
    Any advice/pics of similar set up is much appreciated.
  33. #3913
    Apr 26 2014
    DFW
    B8.5 or B9?
  34. #3914
    Aug 12 2007
    Harrisburg, PA
    B8.5
  35. #3915
    Aug 12 2007
    Harrisburg, PA
    I'm assuming the wheels on the silver are the 20x10.5. Do you know the offset and tire size?
  36. #3916
    Apr 26 2014
    DFW
    Quote Originally Posted by bpac55 View Post
    Ferrada FR2 wheels
    These will be fine on B8.5. Mine are this size, but at ET25. ET30 should be fine, but you may need small spacers depending on you tire selection. The ideal tire size is 295/40/20, but at ET35, you may want to try a 285 or 275.
  37. #3917
    Aug 26 2018
    Boston MA
    i have a fitment question for all the guru's here. I found an online deal on some winter tires and jumped on it. normally I'd buy wheels first and then tires to match, but didn't want to miss out on the deal so now I have tires and I'm in the market for winter wheels.
    the tires are 275/40/20. I'm aware that an Ideal winter tire would be a bit more narrow with a bit more sidewall, but I love the 295/40/20's I run in the summer and didn't want to stray too far from that look for the winter setup.
    So my question is, what's an ideal width for a 20" wheel on a 275/40 tire? I assume 9.5" or 10" would be great with et 25-30, but could I also get away with 9" or 10.5" without too much bulge or stretch?
    advice, opinions and ridicule all encouraged!
  38. #3918
    Sep 28 2010
    NW NC / DE
    Brad winters usually run quite chunky. So 10” would look square and pretty meaty with 275 winter rubber. Even 275 on 10.5 looks good as you can see on Matt’s SQ -
    MOPS on the Move!
  39. #3919
    Aug 26 2018
    Boston MA
    thanks mops.
    i was originally going to throw these on my CH-Rs and jump to a 21" setup for next summer, but i love these wheels too much to put them through a new england winter.
    i really like the look of silver rs5 rotors on a black q5, but those are only 20x9 et 26 so i'm not sure they'd work with 275/40/20 tires.
    if i don't go with rotors i'll probably just wait for a black friday sale and grab some 10" vossens or vorsteiners. if i could find a set of the old vorsteiner deep concave vff 102's in brilliant silver i'd be all over them, but the vossen vfs-1 in brushed silver is a similar look that might work.
  40. #3920
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by Salty Mope View Post
    thanks mops.
    The RS5 rotors on 275/40 would actually be pretty damn perfect. Should be spot on flush. If you did find some 102's, you'd have to run much more spacer than you'd like. Especially for winter. I'm pretty certain they need 10mm, 12mm worst case putting you at ET18-20. Not idea for winter.
