Originally Posted by
Lilrckt
Pcv is covered under factory extended warranty. I believe 120k miles. Essentially a recall
Sent from my SM-N950U using
Audizine mobile app
Thanks Lilrckt. I started looking into it and I am trying to make a little more sense of it. So I know the list of parts that i would buy to do the job if I were to do it myself, but if I am having an Audi Dealer or Authorized shop do the work for the PCV under warranty, what parts from that list would I need to buy to complete the Oil Separator and Oil Check Valve? I want to make sure that I get the parts that I will be paying out of pocket for at a better price than a dealer would charge. This is the list I was planning to get to do the work on my own and what I know what will and won't be covered, and what I am unsure on. Do I have the full list of items that are needed, and for each of them listed I am pretty sure that everything is covered because it would be necessary for the PCV Valve work itself, aside from the Oil Check Valve, Oil Strainer and Crankcase Vent Valve Seal. Can anyone confirm for me? I will order the parts that would not be covered in the morning and get the work scheduled.
Oil/Air Separator - 079-103-542-E (covered under extended warranty)
Oil Check Valve - 079-103-175-C (not covered)
Oil Strainer - 079-115-175-G (not covered)
Crankcase Vent Valve Seal - 079-103-161-Q (not covered)
Driver Side Intercooler Gasket - 079-129-717-J (covered?)
Passenger Side Intercooler Gasket - 079-129-717-K (covered?)
Throttle Body Seal - 079-145-818 (covered?)
Bypass Valve Seal x 2 - 079-145-417-B (covered?)
Clamp x 2 - N-904-898-01 (covered?)
Clamp - N-904-095-01 (covered?)
G13 Coolant Gallon x 2 - GA137741GDSP (covered?)
Thanks again for all the info everyone. This has been super helpful.
