    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    A6 3.0T Brake Torque Launch
    A6 3.0Ters who have attempted brake torque launches -- please respond:
    1. Are you stock or tuned? If tuned, stage 1 or stage 2 (pulley upgrade)?
    2. Do you launch with traction control disabled (full ESP off)?
    3. What RPMs do you see before torque converter lock up?
    4. What is car's behavior upon launch?
    5. What RPM does car shift at for gears 1-2 after brake torque launch?
    6. Any noteworthy issues (slow shifts, short shifts, limp mode, etc.)?
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
    Established Member Two Rings pewpewprince's Avatar
    Nov 14 2018
    DC
    Quote Originally Posted by Ynnekdude View Post
    u can launch our ZF only if boost is hidden from ECU. If u have like 2100hpa+ requested boost, all car will do is just a lil jump till 5mph, then for 0.1 sec will close da throttle, then floor it again. That means u won't get better acceleration than start from idle.
    The only way way to get better 0-60 is to start from 1200-1400rpms and simultaneously flooring and releasing da break.
    Audi A6 C6 2011 3.0tfsi turbo'ed with gtx3076r
    Dec 10 2008
    Chicago
    Quote Originally Posted by pewpewprince View Post
    Thank you. That's what I've noticed as well. My best 1/4 times were all after launching from idle. Always saw odd results when I brake torqued on launch. Recently was doing some testing and gave brake torquing another go. The car ended up lurching forward before going into limp mode.
    Established Member Two Rings audi1031's Avatar
    Dec 02 2009
    2000 GSXR 750 , 1994 Chevy Impala, 1994 Chevy 1500, 2008 Range Rover Sport, and host of other motorc
    Austin Texas
    Glad someone taken time to reply as i just purchased a dragy. Not many on here post 1/4 mile times for these models. Once I work out these errors 01314 will report with my conclusion as well.
    Sent from my SM-N950U using Audizine mobile app
    Nov 14 2018
    DC
    Here is launch with boost. Very fast, less then 3.9 sec 0-60mph (4.07 sec 0-100)
