Results 1 to 32 of 32
    Senior Member Two Rings Justadam's Avatar
    Feb 26 2017
    Atlanta
    Is stage 2 worth it?
    So I recently went with Integrated Engineering Stage 1 with the TCU tune for my 2014 S5. The car runs great, lots more power and way more responsive. Now with everything going on, I have the time and space to move to Stage 2 and wondering if I should. What are the pros and cons to going to stage 2?
    Its a daily driver, and I get stuck in traffic, is there any additional wear on the cooling system? I would be going single pulley only, is that OK for a daily? Do I really need to upgrade my cooling system? I dont really get on the car, but when I do, Id like it to perform, thats the only reason Im thinking of going Stage 2.
    Thanks for your opinions.
    Established Member Two Rings s3lman's Avatar
    Jan 23 2017
    kenosha/wisconsin
    I daily my '14 S5 as well. I went stage 2 towards the end of August and I really like it. There's a pretty big difference between stage 2 and stage 1's top end pull that you'll notice right away. I have a merc racing heat exchanger and crank ready to install but just haven't gotten around to it so I've been rocking the stock one and it hasn't killed performance for me yet. If you ever go dual pulley or you live in an area that gets really hot and humid I would recommend it, but here in Wisconsin it's not too bad to be able to run stage 2 without a heat exchanger as long as it isn't beaten or tracked on too much. That being said, it's a good idea to at least give cooling a thought. I would definitely recommend going stage 2 and if possible dual pulley. It really wakes the car up.
    IE Stage 1 | CTS Intake | Catless DP's | TGK Motorsport Dumpbox
    Established Member Two Rings Devorak13's Avatar
    May 31 2019
    I've got a stg2 EPL tune w/ single pulley.
    Absolutely 0 issues daily driving it for 4mo
    Established Member Two Rings spensley's Avatar
    Mar 15 2017
    North Carolina
    APR stage 2, dual pulleys (~1yr).
    Daily driver.
    No problems at all.
    Veteran Member Three Rings Brozee's Avatar
    Oct 12 2009
    Oxford, MI
    I'm stage 2, isn't my daily driver but in the months of late April to November it just about is. I've had it tuned for 2 years, really wakes up the car. You don't need to do cooling unless you're really going to push the car hard for a considerable amount of time. Random quick sprints and launches are completely fine on stock cooling. With the info you provided, you don't need upgraded cooling. Honestly, if you already went stage 1, just go to 2. Last step before pure bliss. Or even better, go straight to ultra-charger, might as well.
    2013 S5
    APR Stg. 2+ Ultracharger, DSG, CPS | Full AWE Touring Exhaust | Roc-Euro Intake | H&R Coilovers | MRR GF6 | 034 Trans + Diff + Subframe Inserts | Apikol Rear Diff Mount | CR-15 | Full Eurocode USS Suspension | DEVAL CF Rear Diffuser | Adams Rotors / Akebono | Stoptech SS Lines | RS5 Grill | Tint | LED Interior, Reverse + Turn | HID Fogs | Escort Max 2
    Feb 26 2017
    Atlanta
    Quote Originally Posted by Brozee View Post
    I like how you think!
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    I daily mine. EPL stage 2 ECU and TCU, upper pulley only so there was no need for improved cooling. Definitely well worth it, and a noticeable difference. I ran the stage 1 for about a month before pulley and stage 2.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Oct 12 2009
    Oxford, MI
    I went from bone stock (engine with no tune) rest of the car was fully modded suspension, etc. wise. Went to Stage 2 with ultracharger and the TCU tune and wow what a difference. Expensive as heck but worth it in the long run. I wouldn't worry so much about your cooling as I would about your cats burning up, its no't if it's when.
    2013 S5
    Established Member Two Rings S5Black's Avatar
    Mar 24 2019
    2014 Audi S5 S-Tronic, 2020 Jeep Grand Cherokee
    Nevada
    I'm Stage 2 dual pulleys and haven't see any real difference in IAT with the stock heat exchanger.
    Jul 17 2015
    Colorado
    Quote Originally Posted by S5Black View Post
    You'd certainly notice a difference on the track or after extended spirited driving.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Mar 24 2019
    Nevada
    Quote Originally Posted by HazeMyth View Post
    I have a gauge and have been watching it closely, don't plan on tracking either.
    Nov 27 2015
    UK, West Berks
    @Justadam - if you decide to go stage 2 then consider uprating the crank pulley instead of the supercharger pulley because if you are not aware, there have been enough reports of OE crank pulley failure to warrant getting rid of it.
    2015 monsoon grey S5 sportback (yes the one with 4 doors)
    - MRC stage 2 (189mm Vdamper/Fluidampr crank pulley)
    Feb 26 2017
    Atlanta
    Quote Originally Posted by Dippy View Post
    I didn’t know this, I’ll look into it. You mean get a larger crank pulley? I have the IE tune, does this work with their tune?
    Veteran Member Three Rings carrrnuttt's Avatar
    Mar 24 2019
    2013 Audi S5; 2009 Mazda RX-8 R3; 2022 Dodge Durango R/T AWD
    Phoenix, AZ
    Correct me if I'm wrong, but Stage 2 usually involves a dual pulley setup, hence replacing the supercharger AND crank pulley.
    Adam, I have no idea how summers are in Atlanta, but there was NO way I was going Stage 2 in AZ without additional cooling. But that's me being extra careful with it. I also knew I was very likely going to up my tune from the base 91 octane to my current 93 tune. The extra cooling has definitely helped with my peace of mind.
    2013 Audi S5 Brilliant Black 6-spd Sports Diff
    APR Stage 2 Ultracharged (93 tune) - CPS Cooler - Carbonio Intake
    ECS light flywheel
    Spec Stage 3+ Clutch Kit
    JHM Short Shifter
    034Motorsport Insert Kit - Trans Mount
    • Custom Exhaust
    Jul 17 2015
    Colorado
    Stage 2 does not require dual pulley. Stage 2 single pulley does not necessarily require improvements to cooling and is also less likely to melt the cats, as well. So, single pulley stage 2 is a good option for people who want a lot of extra "umph" without having to do a lot of other improvements.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Veteran Member Three Rings mikedizzzo's Avatar
    Nov 03 2016
    So Cal
    I’m on stage 2, single pulley with TCU tune. No upgraded cooling need like HazeMyth said.
    -MikeDizzzo
    2016 S5 Premium Plus | Florett Silver | Black Optic Plus Package | DSG | ADS | Carbon Atlas | B&O
    Mods: GIAC Stage 2 | TCU | SC Pulley | Bilstein B16 Ride Control Coilovers | AWE Touring Exhaust 90mm | Maxton V1 Front Lip | 034 Transmission Insert | Brakes - Hawks Pro with slotted/dimpled rotors | Relak Paddle Shifters | Ceramic Pro 9H | LED interior | 2 x Audizine 5' stickers | Audi All Weather Mats
    Mar 24 2019
    Phoenix, AZ
    Ah, I see.
    I jumped from a Chipwerke that I bought two days after I bought my S5 straight into Stage 2 DP Ultracharged, which happened within two months of owning my S5, so I have no experience with the in-between.
    ECS light flywheel
    JHM Short Shifter
    • Custom Exhaust
    Junior Member Two Rings
    May 21 2019
    North Carolina
    I'll be going stage 2 here shortly. 187mm cp, stock sc pulley with a chipwerke pro. I'll post my thoughts afterwards. Just have to find time to install the pulley.
    Nov 27 2015
    UK, West Berks
    For those who don't know:
    OE s/c pulley is 63.25mm diameter. The OE crank pulley is 162mm diameter. This gives a ratio of 2.56 turns of the supercharger to one turn of the engine. So when the engine is at 7,200rpm (which may require a TCU remap) the s/c is at about 18,500 rpm.
    Stage 1 "simply" keeps the s/c bypass valve closed for longer, allowing the boost to rise above the stock level. To go even higher then the s/c needs to turn faster at the same engine revs. This is done by increasing the drive ratio.
    This can be done by reducing the size of the s/c pulley. The only problem with that is if its too small the belt can slip. On this engine it seems that 57mm is the smallest to be safe, and this would increase the ratio to 2.84 and at the top end the s/c will now be doing about 20,500rpm.
    But we can go further because the Eaton s/c has a spec of up to 24,000rpm. Since the s/c can't get any smaller, the only option is to increase the size of the crank pulley, i.e. "dual pulley". With a 57mm s/c pulley and a 190mm crank pulley the ratio will be 3.33, hitting the s/c limit at that 7,200 redline.
    However from stock, if you want a ratio above 2.84, just use a larger crank pulley and leave the s/c pulley alone. At the extreme case a 210mm crank pulley will nearly hit the s/c limit at that 7,200 redline. But there are plenty of other ratios possible, depending on what tune you want and whether or not you are prepared to uprate your charge cooling.
    Oct 12 2009
    Oxford, MI
    Quote Originally Posted by On3Go View Post
    Any reason you're not just going straight to dual pulley?
    2013 S5
    Feb 26 2017
    Atlanta
    I decided to go stage 2 single pulley and going to see how it does with the stock heat exchanger. I ordered the ECS pulley to go with my IE tune.
    Thanks for everyone’s input.
    Sep 21 2017
    Merrick NY
    I’m a EPL stage 2, single pulley, ECU and TCU and not a hiccup.
    No extra cooling, here in NY.
    Enjoy the added performance, we’ll worth it.
    May 21 2019
    North Carolina
    Trying to hold onto my warranty for a bit longer before I start flashing, hence the chipwerke. Plus right now it was cost efficient to give stage 2 single pulley a try beings I got the chipwerke programmed to stage 2 for free, and the pulley at a good price. Also not quite ready to do a HX or jeopardize my cats quite yet.
    Established Member Two Rings Twotonicnite's Avatar
    Mar 21 2016
    NW Indiana
    To answer your question simply, yes it is.
    Twotonicnite
    *2015 S5 Prestige, black optic, manual, GIAC Stage II Tune, Vorsteiner V-FF 104s, Bilstein B16 w/ IRC Ride Control coilovers, Milltek exhaust, 034 rear swaybar, endlinks, differential, & transmission mounts, ECS carbon intake
    *2016 Q5 Premium Plus 3.0T, S-Line, Exclusive Derby Green Pearl
    *2019 A6 Prestige, Mythos Black, Night Vision
    *2008 Toyota Tundra SR5, bone stock
    Veteran Member Four Rings 2by2handsofblue's Avatar
    Jun 02 2019
    RIP my 98 saturn sc1 5sp that had 294k miles on it.
    serenity valley
    I'm on IE stage 1.
    I'm considering stage 2 sp myself.
    I'm also thinking of porting my sc too. But all this costs money lol
    we are the borg! resistance is futile.
    Feb 26 2017
    Atlanta
    Quote Originally Posted by 2by2handsofblue View Post
    I'm on IE stage 1.
    I ordered the ECS pulley and belt for $100. The upgrade from stage 1 to stage 2 is $100, so I think it’s a no brainer. I was more worried that there was either not going to be a benefit or make the car less daily drivable. Seems like I have nothing to worry about and everything to gain. I went and bought some 100mm bolts from Home Depot and should be good to go on the swap next weekend.
    I’ll let you guys know how it goes.
    Jun 02 2019
    serenity valley
    Quote Originally Posted by Justadam View Post
    So the stage 2 tune file is $100 from IE?
    Jun 02 2019
    serenity valley
    R u going with just a larger crank pulley and leave the OEM size sc pulley?
    I'm also thinking about getting the fluidamper. But that's pretty pricey. But it might be a peace mind. Even though a lot of other tuners doesnt have issues.
    Cant hurt other than your wallet lol
    Feb 26 2017
    Atlanta
    Going from stage 1 to stage 2 with IE is $100 more. And I’m just changing the supercharger pulley, nothing else. Well, for now lol.
    Jun 02 2019
    serenity valley
    Well I might as well do the same lol. So the sc pulley and belt and the cost of the stage 2 tune file is what all together?
    Feb 26 2017
    Atlanta
    both about $200. You need todo the work yourself, but it seems straightforward.
    Jun 02 2019
    serenity valley
    Well I have friend who will give me a discount lol.
    I'm thinking I'll go with vdamper way. But it's not cheap unfortunately.
    When u get it set up keep us updated
