Hello everyone,
Hope you have been all well during these hard days all over the world.
As I have previously mentioned, I have oil consumption problem which has increased in the past year time. The car is 2010 a5 1.8 Tfsi (118KW/160Hp) manual, gasoline. And the mileage is around 63000 miles.
I know that this is a known issue and has been discussed several times before, but I am confused about the oil grade selection as the info I ve read did not answer my questions.
The manual is recommending Vw504 for Long Life Service which has been used since new (Castrol in the past and then Mobil5w30 C3 Vw504 oil).
The manuel is also recommending Vw502 for control service. But it then states that I should not add an A3B4 oil more than 1 liter.
I have been using Mobil 5w30 ESP since 3 years and last month I switched to Liqui Moly 4200 5w30 c3 Vw504 oil which did not make much difference.
So to reduce the oil consumption I am thinking to use a thicker oil...
Two Questions:
Can I use VW502 oil with A3B4 spec instead of C3 spec?
***Option 1*** Mobil 1 New Life is 0w40 and A3B4 with Vw502 approval.
***Option 2*** Mobil 1 ESP 0w40 is C3 but without Vw502 approval.
Between those two option which is a better or the only suitable option?
Depending on the answer I get here, if I can not find the Mobil I need from petrol station, I will be looking to buy a Liqui Moly (directly from the distributor) in that case and it will either be
*** Option 3*** Toptec 4100 5W40 (c3) with Vw502
*** Option 4*** Molygen New Generation 5W40 A3B4 with also Vw502
Which one of those four oils will be the right and best option to move from the current Liqui Moly 4200 5W30 C3 (VW504) inside the engine which already got consumed around 1.5 Liters (or 1.6 Qt I guess) in the past 2000 km or (1200 miles I guess).
Your opinions are very important for me.
Many thanks in advance.
God Bless
