Results 1 to 2 of 2
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    TPS/ Throttlebody wiring diagram
    Can anyone point me to a pin out or wiring diagram for the 3.0t?
    I am switching my oem TPS connector from
    4H1973713
    To
    4H0973713 so I can run an iabed upgraded throttlebody.
    I was thinking it would be a straight forward swap since they’re both 6 pin but unfortunately the wire colors are different and the 4H1973713 pig tail I got only has 4 wires used so I’ll need to swap over the ones from my oem connector
    If anyone knows where I can find or buy a wiring diagram or Pinout please let me know
    Thanks
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Senior Member Three Rings ed1380's Avatar
    Mar 16 2009
    ATL
    bump
