I'm still fighting the misfires issues.
I had the carbon clean done yet again about 300 miles ago, and nothing changed.
I took the car toi the dealer for an airbag recall notice, and while there I asked for a second opinion.
They determined it was my aftermarket air filter, clogged and dirty, they put a stock one and the misfiring occurrences were significantly reduced to thee point it took about 3 days until the all cylinders misfires reared the ugly head yet again and has not comeback, and what I mean is that it's only happened once as opposed to several times.
The CEL came on under hard acceleration. I plan on erasing the codes and see what happens.
The dealer ruled out the crank position sensor as the possible culprit.
Replacing the air filter made sense since it was soon after I installed it that the issues began.
Today a friend hooked up a vag com on my car, and I'm going to let you guys look at it and see if you can shed new light on this.
Sunday,23,August,2020,16:36:07:18907
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WUARU78E97N905468 License Plate:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WUARU78E97N905468 Mileage: 144040km-89502miles
Address 01: Engine Labels:. 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 A HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0060
Revision: 57H15--- Serial number: XXXXXXXXXXXXXX
Coding: 01040009180F0160
Shop #: WSC 08316 444 999999
VCID: 244CED7BE792246FDD-8070
1 Fault Found:
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 144042 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 105.0°C
Temperature: 75.0°C
Absolute Pres.: 830.0 mbar
Voltage: 11.684 V
Readiness: 0000 0000
Address 11: Engine II Labels:. 079-910-560-BNS2.lbl
9 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 143870 km
Time Indication: 0
Freeze Frame:
RPM: 3548 /min
Load: 85.8 %
Speed: 115.0 km/h
Temperature: 90.0°C
Temperature: 37.0°C
Voltage: 13.335 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 143870 km
Time Indication: 0
Freeze Frame:
RPM: 3548 /min
Load: 85.8 %
Speed: 115.0 km/h
Temperature: 90.0°C
Temperature: 37.0°C
Voltage: 13.335 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 143870 km
Time Indication: 0
Freeze Frame:
RPM: 3548 /min
Load: 85.8 %
Speed: 115.0 km/h
Temperature: 90.0°C
Temperature: 37.0°C
Voltage: 13.335 V
000776 - Cylinder 8
P0308 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 143870 km
Time Indication: 0
Freeze Frame:
RPM: 3548 /min
Load: 85.8 %
Speed: 115.0 km/h
Temperature: 90.0°C
Temperature: 37.0°C
Voltage: 13.335 V
000775 - Cylinder 7
P0307 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 143870 km
Time Indication: 0
Freeze Frame:
RPM: 3548 /min
Load: 85.8 %
Speed: 115.0 km/h
Temperature: 90.0°C
Temperature: 37.0°C
Voltage: 13.335 V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 143870 km
Time Indication: 0
Freeze Frame:
RPM: 3548 /min
Load: 85.8 %
Speed: 115.0 km/h
Temperature: 90.0°C
Temperature: 37.0°C
Voltage: 13.335 V
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 143876 km
Time Indication: 0
Freeze Frame:
RPM: 3120 /min
Load: 31.8 %
Speed: 101.0 km/h
Temperature: 93.0°C
Temperature: 39.0°C
Voltage: 13.589 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 143885 km
Time Indication: 0
Freeze Frame:
RPM: 4172 /min
Load: 22.0 %
Speed: 82.0 km/h
Temperature: 94.0°C
Temperature: 42.0°C
Voltage: 13.335 V
000774 - Cylinder 6
P0306 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 143910 km
Time Indication: 0
Freeze Frame:
RPM: 2090 /min
Load: 23.5 %
Speed: 80.0 km/h
Temperature: 94.0°C
Temperature: 40.0°C
Voltage: 13.716 V
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N0G0PFNP
Coding: 0432607
Shop #: WSC 06335 000 00000
VCID: 3C7C351B7F227CAF85-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 3HSUT
Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
