Results 1 to 12 of 12
    Feb 12 2008
    Michigan
    ML55 rotor sources
    wondering where everyone buys there ML55 rotors from or better yet if there is a source that will also increase the center bore when you buy them? Not the 2 pice JHM rotors, those are out of my budget:(
    May 20 2010
    I used a die grinder, although many use a flapper wheel. I bought my discs from partsgeek.com
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Jan 24 2010
    Paramus,NJ USA
    Why ML55 rotors?? are you using 17Z calipers?? Also have they been modified in anyway?? IIRC I took off 3mm of the ears from the 17Z and Im using e350 4matic sport package or amg package rotors. No modification to rotors.
    330x32mm rotors.
    Ziddy Autowerks
    Feb 12 2008
    Michigan
    18Z calipers from what I have read mate up with the ML55 AMG 350mm rotors, only modification needed is to enlarge the center bore to fit the hub
    May 20 2010
    No idea about OP, but I had 18Zs
    Jan 24 2010
    Paramus,NJ USA
    ahh 18Z calipers so your looking for 345 or 350mm rotors correct?? Just putting this out there you will need a 18 inch wheel at the least to use that setup. Let me see if I have any info what can be used without modification with that setup.
    if you dont want to modif an existing rotor you can use b6 s4 rotors. They are only 30mm thick. But That should not be a problem as airgap is taken up on first application of the brakes.
    2004-2007 Audi B6 S4 345x30
    Pros: cheap, no need to open lug holes or hub
    Cons: 30mm thickness rather than 32mm.
    Ziddy Autowerks
    Jan 24 2010
    Paramus,NJ USA
    Quote Originally Posted by Fast4esT View Post
    I think you need to grind the upright as well on the bottom IIRC.
    Ziddy Autowerks
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    B5 S4, but similar enough...
    I went 18Z with Power Stop EBR660XPR slotted/drilled ML55 rotors. Flapper wheel on a drill worked great for opening up the centerbore 1mm. ML55 rotors are 345mm, so if you use 18Z pads then you'll get a slight bit of pad overhang (18Z should be 350mm). I used 17Z pads and it's perfect.
    On my B5 S4 steel uprights, there were a couple spots I had to grind to remove contact between the upright and rotor. We're talking maybe 2-3mm, in an area that was roughly 1-2" wide and 1/2" tall.
    IIRC, the offset on B6/B7 S4 rotors isn't great and requires the caliper to be pushed outwards which will eat up additional wheel clearance. 30mm wide also can be a problem if the caliper is insufficiently centered over the rotor and the pads are fully worn... the pistons may overextend.
    Lastly, EuroxS4, you're not entirely correct that you have to use 18" minimum wheels to clear 18Z. I am running TSW Bathurst 17x9 ET35. There is plenty of clearance:
    https://photos.app.goo.gl/FXhsYCqRDvTWjMUV6
    2001 Corvette (C5) Z06
    Jan 24 2010
    Paramus,NJ USA
    Depends on wheel and offset. I was reffering to stock wheels.
    Ziddy Autowerks
    Senior Member Two Rings Natejo91's Avatar
    Apr 05 2017
    Porsche Cayman S, Toyota 4Runner, Suzuki SV650
    I have 18Z calipers and just bought some Mahle brand brake rotors for the ML55 from Amazon or something.
    Took them to a machine shop and had them enlarge the center bore by 1mm for about $50.
    2003 B6 Quattro MT | Polar White w/ Ebony interior | B7 seat swap | B7 Center Console | JHM + Black Forest Shifter | B8.5 MFSW | RNS-E | Brembo 18Z calipers front | S4 rear calipers | S4 front sway bar | RS4 rear sway bar | Bilstein B8 kit w/ H&R sport springs | Bosch 550cc injectors | Tubular high flow exhaust manifold | K04 | 3" MAF | 034 Motorsport 3" test pipe | B7 Dual Sidemount Intercoolers and Motoza K04/Hybrid tune
    Feb 12 2008
    Michigan
    Have you installed the 18z yet?
    Apr 05 2017
    Yeah I've had mine on for about 2 or 3 years now.
    No issues yet.
