Results 1 to 22 of 22
    Veteran Member Three Rings larry_fopps's Avatar
    Jul 29 2014
    MK3 2.9L Vr6 WIP
    Sayreville NJ
    Remote Start with Factory Key Fob - Key Port
    Put the Fortin Remote Start in my Wife's Q5. I went this route, because its only $160 all in, utilizes the factory keyfob, you don't sacrifice a spare key, simple install, and there are a ton of options that it allows you choose between.
    Remote Starter Kit - https://amzn.to/3bwlXzL
    Flashlink Programmer - https://amzn.to/2xuvfh5
    Veteran Member Four Rings ILVTRANCE's Avatar
    Dec 19 2012
    New York
    did the same thing. That key port killed me though.
    2014 SQ5 P+ | 034 Stage 2 ECU + TCU | 034 190mm crank pully | 034 Street Density motor mounts | 034Motorsport S34 Carbon Fiber Intake | Merc Racing HX V3 | Bilstein B8's w/ H&R Springs | 034 Trans insert | RSNAV 10.25
    NEW EDM MIX APRIL 2021 https://soundcloud.com/matt-scheinwa...in-my-basement
    Veteran Member Four Rings Tone-Dogg's Avatar
    May 06 2007
    2020 Q3 P+
    Hartford, Connecticut
    Quote Originally Posted by larry_fopps View Post
    Excellent work! Great video, was thinking about this the other day, very nice to be able to utilize the Audi key fob.
    Might be doing this soon.
    Sent from my Note9 using Tapatalk
    2016 Q5 3.0T Quattro P+ Sline Black Optic
    2020 Q3 2.0T Quattro Premium +
    Jul 29 2014
    MK3 2.9L Vr6 WIP
    Sayreville NJ
    Quote Originally Posted by ILVTRANCE View Post
    Yeah that was the only part where cursing ensued. Once that was back in its place, everything else went very smoothly.
    Quote Originally Posted by Tone-Dogg View Post
    I highly recommend. It was so nice having this for part of the winter.
    Established Member Two Rings snowzach's Avatar
    May 25 2004
    Columbus, OH
    I was just reading the instructions for this on their site... There's all these options about an alarm and what not. Does this disable the factory alarm from working? Is there any downsides/loss of functionality now that you've had it for a bit?
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    Might have to purchase this too as the price is pretty lucrative and not having to sacrifice a key fob is great.
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
    Mar 07 2020
    Minnesota
    Quote Originally Posted by choppstixxx View Post
    The EVO-AUDT1 only supports up to MY 2014: https://fortin.ca/en/products/evo-rs.../vehicles.html
    For 2015-2016 MY you'll need the EVO-ALL which requires a key. I don't see a key-box or vehicle-specific harnesses so there might be more required (in addition to the flashlink module).
    At least that's what I can figure out, not having actually done it.
    Apr 24 2017
    Hilton, NY
    Quote Originally Posted by Norskie View Post
    What I don't get is 2013+ Q5/SQ5's were all the B8.5 generation, so in theory a 2013/2014 had the same electronics as the 2015+. I might order the items above regardless and give it a try as another SQ5 owner installed it without any issues and all SQ5's were Push to Start.
    Mar 07 2020
    Minnesota
    Go for it! If it works I'll be following in your footsteps.
    One that isn't clear to me .. if a key is required .. how the keyless access is supposed to work. If there's a key in the car, I can't lock/unlock the car by touching the handles. I'd hate to lose this functionality.
    Dec 19 2012
    New York
    any remote start as far as I know is going to require you to use key fb to unlock, and lock when using the auto start feature. with that said I can now lock the car with the fob while it's running. I couldn't do this prior to the fortin unit I'm in a 2014 sq5 p+
    Dec 19 2012
    New York
    Pretty sure 2014-2017 SQ5 are B8 not B8.5
    maybe you mean the Q5 specifically?
    Apr 24 2017
    Hilton, NY
    Yea I kinda group the Q5/SQ5's together, so technically all SQ5's built before 2018 were B8's. Whereas 2013-2017 Q5's were B8.5 and 2012 and older were B8's.
    Mar 07 2020
    Minnesota
    But what about when not using the autostart? The spare key is still in the car.
    I expect I'll use the autostart a couple times a weeks in the winter, but I lock/unlock by touching the handles nearly every single time I drive.
    Maybe the point is that Fortin's instructions specify the valet key ... which presumeably doesn't have the proximity feature. But it doesn't whether it must be the valet or just any working key.
    Feb 27 2011
    Winnipeg
    you're supposed to remove the battery from the fob so the prox doesn't work.
    The Fortin stuff is great, I did the t harness install in my 13 Q5 3.0t does exactly what it says it would do, on the plus side I got a flash link programmer out of the deal, I just put one in my B6 A4 and my brothers 06 F150 today with the rf kits.
    Dec 19 2012
    New York
    I have two keys. Both stay in the house and both will start the car with 3 locks. You have to use the key fob to unlock the car after it has been auto started. That is for security, and a work around for not losing a key it makes sense to me that it works this way. you don't want to auto start your car and any joe blow can unlock your car and drive off lol. A bonus feature for me is now i can leave my car once started and use the key fob to lock the doors where as previously I had to manually use the key. During install the most PITA part is wiring to the keyport which is how I believe the fortin bypasses needing a key that stays in the car
    Junior Member Two Rings
    Jun 03 2008
    STL
    Can you use the keyless entry/exit if the car has not been auto started?
    Junior Member Two Rings Eur0fr3sh's Avatar
    Apr 26 2017
    DMV
    Quote Originally Posted by cbecker33 View Post
    I can with my install. (Fortin as well)
    Jun 03 2008
    STL
    Quote Originally Posted by Eur0fr3sh View Post
    Great, thanks!
    Junior Member One Ring
    Aug 18 2020
    Buffalo, NY
    so can someone verify this would work on a 2016 SQ5?
    Dec 19 2012
    New York
    Quote Originally Posted by Slocumrd2003 View Post
    Did you contact or check Fortins website?
    Dec 19 2017
    MN
    Looking at their website, the SQ5's 2015-2017 will need to give up a fob for it to be wrapped seems like... bummer
    2015 SQ5
    Apr 26 2017
    DMV
    Quote Originally Posted by Vehicle 1 View Post
    I took the valet key & the battery out of my remote, works well. I had to try like 8 different wraps of the wire though to get it to fit back in and work. This was my biggest hurdle on the install. Actually, that and having 1 ohm diodes. Make sure you buy them.
