Originally Posted by
Dr. Jekyll
Is that a Torx nut on inner camber bolt? And do you happen to know the size?
I'm trying to make sure I have all the right tools for the job since I can't just run to Autozone mid-swap with everything being shut down.
It may be a torx and I did not have one that big, so I used a 12 point 21mm wrench for the rear facing nut, while the forward facing bolt head is an 18mm. The rear toe is a 18mm nut with an odd size shaft sticking out that I just used a vice grip to get a good grip and turn/adjust the toe. Actually the same style shaft protruding to the rear is how the camber is actually adjusted, although you can access the forward side 18mm bolt head with the plastic lower control arm guard off.
I finished the fronts this afternoon. Not too bad, just played around some on how to angle the damper to remove the spring and re-install the HAS kit. One thing I did, that many will not do, is to loosen the damper top rod nut while still attached to the strut tower, thus not needing to use a spring compressor in a tight space. I find that the Audi OEM springs are not loaded very much and there were no surprises for me. Not that I'm recommending this (do it at your own risk), but it worked well for me. I loosened the sway bar top connection and completely removed the lower sway connection bolt. Take the lower damper bolt/nut off, release the upper knuckle pinch bolt (I removed the upper control arms for more room, too, as I replaced them with adjustable 034 upper control arms for camber correction (not sure I really needed them with this relatively mild drop, but already had them from my S5). I also took the flat retaining spring off the damper that held the hydraulic line to the damper itself to allow more 'wiggle' room for the damper. This allowed me to maneuver the damper where I could complete removing the top hat and OEM spring/perch an replace with the HAS kit while still in the 'wheelwell.' Then proceeded to button her back up and do some rough alignment before taking her out for a spin. Will drive some miles to let things settle, then will go get an alignment at a shop I trust. I'll also get an idea relative to hydraulic pressure (DRC) and if needs adjustment and how well my cut rear bumpstops work. Initial drive felt good with no apparent issues. Good luck!
