    Nov 21 2013
    Buffalo
    B7 a4 ecu compatibility
    01: Engine Labels:. 06F-907-115-AXX.clb
    Part No SW: 8E0 910 115 P HW: 8E0 907 115 D
    Component: 2.0l R4/4V TFSI 0020
    Revision: 5EH13--- Serial number:
    Coding: 0104010A180F0120
    Shop #: WSC 40232 444 83866
    VCID: 2E050F0CBC140F176B9-807B
    Above information if from vagcom on my 2007 a4 2.0t 6 speed car.
    At the junkyard today, I got an ecu from a 2006 a4 2.0t 6 speed car part number is 8e0 910 115 M. The security bolts were cut to accept a flathead making me think it may be tuned.
    1) would this ecu work for my car?
    2) how would I determine if this ecu has a tune? Is there someone I can sent it to?
    3) say it would work for my car and Immo is defeated, if I changed the vin in vagcom would it hypothetically be plug and play in my car?
    Thanks, been out of the Vw/audi world for a while, but did search and didn’t find anything like this.
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    It’s generally a bad idea to use a different ECU than what your car cams with. There are VIN specific sensors and other parts that might have problems.
    For example, you have a B ECU and install a M ECU that has the immobilizer defeated. Now your flap motor for the intake manifold will have issues and your fuel rail pressure sensor might have issues.
    To avoid potential problems, use the same ECU part number as the ECU you’re replacing.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Senior Member Three Rings BeeSevenKyle's Avatar
    Feb 24 2019
    2011 Dodge Journey R/T AWD
    Ontario
    ECUs are NOT interchangeable if the p/n suffix letter is different. Ex. If yours ends with "D" a replacement ecu will need to end in "D".
    If you get it immo defeated (unitronic does it) it should just plug in and be good to go. Otherwise, you will need to have it installed at the dealer to have the immobilizer paired to your cluster and key.
    Sent from my VOG-L04 using Tapatalk
    Nov 21 2013
    Buffalo
    Thanks guys! Well if anyone needs a 8e0 910 115 M ecu I have a spare
    Oct 24 2015
    Perth, WA
    You can do it with a BDM scanner / interface. But total pain in the arse.
    My respray thread
