I'm working on the TT and I know this is the A4B8 forum, but that forum seems dead and the folks here seem to be life long Audi fans. So I hope to get an answer here. Help please!
The outer cv boot is torn and while the axle is out I want to do the inner boot so the axle will be gtg. The inner cv boot has the boot attached to a metal flange. The CV joint is then capped by a metal housing on the other side. No gaskets. This looks simmilar to the B8 driveshaft to diff attachment, but the B8 driveshaft has a gasket on the flange.
So Audi calls out a sealant on the metal cap and I beleve it is D454300A2. This is a solvent free "hausing sealing compound" . In true Audi fassion it is around $90 for a tube.
Does anyone know if there is a permatex equivalent? Is this just an anerobic sealant? Looking not to spend $100 on a tube of sealant that will go bad before I need to use it again.
